Question about Kodak EasyShare C875 Digital Camera
I charge the batteries. i put the batteries in the camera. the camera wont work. i hook it up to the computer all day. it still wont work. the camera will stay on for 3 secs excact or wont turn on at all. why isnt my camera working?
    President:
  • 2,761 Answers
Your fix could be as simple as cleaning the camera's battery contacts, or it could be something more serious and expensive. Before you pay for expensive repairs that you may or may not need, check the Kodak Help Center by clicking on the link below. It uses a simple Q&A format to diagnose problems and propose solutions.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Posted on Aug 03, 2009
Could i over charge my camera
Normally you don't over charge a battery, when it is charged for some extra hours. The electronics should stop the current. And when your computer is still working it should not have killed your camera. But be aware that as long as the camera is attached to a computer or a charger you can't switch it on.
Depending on how old your battery is and how it is used in the past, the battery could be gone. But it is not only to blame on the last charge cycle. Try measuring the voltage of the battery with a multi meter. The voltage should be a few tenths of a vat above the voltage printed in the battery.
I think your battery will be like 3,7 volt, and when charged the multi meter should read 4 volt. Anything below 3,7 volt means the battery is dead. (at least not fit for your camera)
It is better and safer to charge the battery on an external charger in the future.
Dec 29, 2013 | Kodak EasyShare M853 Digital Camera
7 days ago i took my battery off to charge my camera and its fully chrged i put it back onto the camera and it just wont start up. I bought another battery and fully charged it aso and it wont turn on!...
Please make sure that the battery is clean and also the terminals within are clean. If you had been using the camera prior to the charging then the camera must work unless if the battery was spoiled by wrong charging. If you can use a multimeter to check the voltage which must be as specified on the battery label. Now make sure that the battery gets good contacts into the camera when inserted. If this wont work then it possible that there are errors within the camera and you need help from the nearest Nikon center.click the link below
http://www.nikonusa.com/Service-And-Support/Product-Support.page
Mar 28, 2011 | Nikon D3000 Digital Camera
My camera, a nikon d70s, wont turn on and work. ive taken the battery out and out it back in, still wont work. i then tried 2 charge the battery but still wont work. i then tried to re-set it but it still...
If the camera does respond when you hold down the shutter release, then the internal clock battery may have drained. As the manual says on page 17, charge your main battery, put it in the camera, and leave it be for up to three days.
Feb 15, 2011 | Nikon D70s Digital Camera
The manual says "your camera comes with a compatible charger, your only required to put the battery into the charger and charge the lithium battery directly from the outlet" The camera came with an AC...
You put the battery into the camera. Put the USB end from your computer cord into the end of the AC adapter hook it up to your camera. Ta-da! Everything should be working smoothly in the battery/charger department. :)
Dec 26, 2009 | Vivitar ViviCam 8025 Digital Camera
Camera turns on and then right off immediatly
first if u want to get ur cam to work use energizer rechargeable batteries after charging them for sure this is the best kind u can use powerful and last longer ,to get ur pictures out u can take memory off the cam and put it inside memory card reader then plug it to ur computer through usb ,computer will read it easy and u can download ur pics to ur pc
Mar 27, 2009 | Vivitar ViviCam 3750 Digital Camera
Psp wont charge or hold a charger
It could be a bad battery or you can check under the psp if you can turn it on and make sure that under Settings > System Settings > USB Charge is set to on. If it is and it isn't charging then it's a bad battery.
Dec 22, 2008 | Sony PlayStation Portable (PSP) Console
Camera Won't Charge
my finepixz3 got wet. but after a few days it worked! but when the battery ran out it wont charge. is it the battery? it turned on a few sec when its in the cradle but it wont last after a few seconds it would turned off. is it the battery or the camera itself?
Sep 01, 2008 | Fuji FinePix Z3 Digital Camera
Will not charge
i cant get music to go to my mp3, its hooked up to the scomputer, and i dont know how to transfer music
Jan 15, 2008 | Insignia NS-DA2G MP3 Player
Wont turn on
Possible failed battery showing fully charged but actually not -or even charger.No reset] Disconnect from the wall socket- re connect and tell us if the battery is now charging. If show full- replace battery. Also tell Sony customer support
Jul 31, 2007 | Sony Cyber-shot DSC-T10 Digital Camera
Kodak EasyShare C875 Digital Camera Logo
148 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
