Question about Tappan TGF320 Gas Kitchen Range
Top Burners have a poor flame. How do I access the burners to adjust the flame ?ps No Owners Manual available. Tappan Millennia.(w/digital clock.)
  • hoffmann_cha Jul 16, 2009
    Burners flames don't burn blue, but orange /blue. How do i correct them.
  • Uriel Tello
    Uriel Tello May 11, 2010
    do not adjust them instead clean the port holes nozless.
    President:
  • 1,922 Answers
You dont adjust the burners,either you have dirty burners and need service or your gas pressure is wrong,is the flame blue?or has it some orange flickers in with the blue,then you need to clean orfices and tubes
Posted on Jul 28, 2009
Tappan signature 2000 adjusting the flame from the burners they are burning yellow
yellow flames in gas burners indicates
1--insufficient gas pressure
2-- the position of the air shroud around the gas jet is wrong and needs to be moved forward or back to adjust the amount of air available for the air /gas mixture
correct mixture is a blue flame
Jan 09, 2016 | Tappan Kitchen Ranges
We have a Tappan gas range. Don't have the model number; it was in the apartment when we moved in. It is over ten years old. It has electronic ignition. The top burners all have orange-yellow flames...
Sorry to read about your problem, I hope this helps you out.
i would take all units out and clean them..clean all holes in the burners.
since you have the problem on all burners..air/fuel is not the problem at the adjustments..you may have a gas regulator problem
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 26, 2010 | Tappan MGF500PBW Gas Kitchen Range
I have a very old gas range top that i cook on in my barn. i dont want to replace it, i just want to fix it. the flame will not burn blue, ive tried cleaning, enlarging the air shutter , replacing the...
The burners need to be completely clean, unplug any holes near the igniter pilot
then adjust the opening near the knob. The most important, you have a nut that you turn with a rench
the adjustment of gas and air.
Dec 24, 2010 | Tappan 24 in. Freestanding Gas Range...
Hi, I own a Tappan oven..model #TGF364ASF..the
Hi an welcome to FixYa. I am Kelly.
If nothing lights... i.e burner or oven there are only 2 things that can cause this problem. A failed ignition module or a wiring problem. The wiring problem can be a simple short or a broken power lead. All of the stove top ignitors are in a series parallel connection and if one of the burmer control shorts you loose the stove top. With nothing is lighting oven and burners it sure points toward the ignition module or power to the module.
Thanks for using FixYa.
Kelly
Note... The ignition module itself is not cheap.
Apr 09, 2010 | Tappan TGF364AS Gas Kitchen Range
I have two dean sr142gps fryers and am looking for an owners manual. I want to know how to adjust the flame onthe burners.
The only way to adjust the flame is by changing the orfices on the burner tube manifold. Dean is owned by Frymaster & you can contact their technical Dept @800-551-8633
Jul 19, 2009 | Kitchen Appliances - Others
Poor burner flame
You have to adjust the air flow shutter on the burner tubes.
Jul 04, 2009 | Tappan MGF500PBW Gas Kitchen Range
Gas range top burners too hot
Get the installation manual for your range, and find the part on adjusting the low heat for the burners. On my Whirlpool, I found there is an adjustment screw inside the control knob shaft of each burner. The manual says turn the burner on low, remove the knob, then turn this screw until the flames are 1/4" high. Super-easy, it took me 5 minutes to do. I am sure all ranges have similar adjustments, might be in different locations - check the manual.
Feb 05, 2008 | Kitchen Ranges
Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Aug 14, 2007 | Tappan TGF363 Gas Kitchen Range
Tappan TGF320 Gas Kitchen Range Logo
413 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
