Question about HP Pavilion ze2000 Notebook
Does not recognize all of installed memory ??
    Scholar:
  • 75 Answers
Check that the installed memory cards are properly and securely located in their sockets. Also check that you have installed the correct specification of memory cards
Posted on Jul 16, 2009
CPU will not recognize the last memory slot in my FX4710
RAM, or random access memory, is the physical memory on the computer but only holds data while the computer is on.
The benefit of adding more RAM is that it generally makes your computer faster.
Almost all new computers recognize your RAM after you install it and restart the computer, but if yours doesn't there are a few simple things to do to get the memory recognized.
Check the type of memory you have.
Computer motherboards will work only with the type of memory they are designed for regardless if the memory fits or not.
There will be either a sticker on the memory or a listing on the packaging giving the memory type and speed.
Check the computer's or motherboard's manual for the type of memory that is compatible.
Install the memory and make sure it is tight, otherwise it may not get recognized.
The memory fits into slots on the computer's motherboard.
There are tabs on the side of the memory slots to release it.
Release the memory if it is installed and put it back in by pushing it down straight into the slot until it clicks.
Restart the computer and hit the appropriate key to enter the BIOS.
The key will be listed on the screen.
Go through the menu choices by using the arrow keys.
Look for the memory listing under hardware.
Make sure all memory listings are not listed as disabled.
If so, change them to enabled.
Choose anything listed similar to "Auto detect."
Exit the BIOS and restart the computer.
Jul 26, 2013 | Gateway FX4710-UB003A Core 2 Quad Q9300...
Hp pavilion g7 does not recognize all 8g memory
If only 3GB is recognized it isn't a 64bit OS.
Jul 06, 2013 | Computers & Internet
Not all installed memory recognized
Open your computer and install one memory stick and try powering on the computer. Try one stick at a time to determine if you have a bad memory module or a defective memory slot on the motherboard.
Jul 03, 2012 | Dell Precision T5500 PC Desktop
Poweredge 700 will not recognized memory
Unless only one 256-MB memory module is installed, the modules must be installed in identical pairs. If you want 512MB total, you will need to populate by using two identical 256MB modules or use the same technique for larger memory sticks. That model supports up to 4GB ram of the following type;
PC3200 ECC DDR SDRAM DIMMs
May 21, 2012 | Dell PowerEdge 700 Server
I installed two new 1 gigabyte memory sticks into a Dell Inspiron 6000, which previously only had 2 256 megabyte memory sticks installed. When I first installed the 2 gigs of new memory, the laptop turned...
Once you installed the memory, did you enter into the System BIOS Setup screen? Do this and verify that the system recognizes the newly installed 2GB RAM. This should let the system access the new memory once you boot.
Jan 01, 2011 | Dell Inspiron 6000 Notebook
Usb device not recognize
You mentioned that you uninstalled the unknown device from the Device manager. If you uninstall it then connected your usb flash drive you will see an error again on your device manager. This means that the driver for your usb port is not properly installed.
To install it, visit dell website, look for the model of your machine and locate the driver, download it then install from your machine.
Jun 02, 2009 | Dell Inspiron 6400 Notebook
Memory won't initialize on a HP Laserjet 2605DN
I found this page in the User Guide. Maybe it will be helpful.
"If the printer has a new memory DIMM installed, all Windows users of the printer must set the printer driver to recognize the newly added memory. Macintosh computers automatically recognize new memory.
To enable memory for Windows
1. On the Start menu, point to Settings, and click Printers or Printers and Faxes.
2. Select this printer and select Properties.
3. On the Configure tab, click More.
4. In the Total Memory field, type the total amount of memory that is now installed.
5. Click OK."
Give this a try and if it doesn't work, let me know and I'll keep looking.
Feb 18, 2009 | HP Hewlett Packard LaserJet 2605dn Printer
New memory is not recognized
Switch off the Laptop completely . Remove the Battery as well .Now replace the memory module and ensure it is properly seated in its slot.
May 07, 2008 | Compaq Presario R3000 Notebook
Memory Recognition
The BIOS recognizes the same speed chip. Say, "PNY 512mb 333mhz 12ns". If you mix and mismatch, the BIOS won't see it even though your motherboard will take the differant type chips. They should all be the same.
Jul 10, 2007 | MSI MS-6547 Motherboard
Memory count problems
Take out the 512mb and leave in the 256mb and 128mb and see what happens. Switch the memory around to other slots. It may be the speed of the chips. They should all be the same.
Jun 25, 2007 | Foxconn NF4K8AC-RS-1.0 Motherboard
HP Pavilion ze2000 Notebook Logo
75 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
