Question about Adesso Computers & Internet
Interrupted connection. letters aren't received by computer
Some of my letters aren't working on my blackberry
i found that take your phone apart the board that has the contacts on it take a pencil eraser and clean the little black contacts put back toghter and try it it worked for me on tv remotes also satl cards ect.
Mar 08, 2013 | Cell Phones
When I turn the system on the CD Drawer keeps going in and out repeatedly by itself. When I load a CD it won't recognize it and won't play it and keeps going in and out opening and closing by...
Hello
Check all connections, such as from player to amplifier or receiver and receiver to speaker. Check and clean contacts on RCA jacks and cables and try a different input on the amplifier or receiver.
Clean the lens. Use only a special CD lens cleaner and follow the instructions carefully.
Check the traverse assembly (the metal rod that the laser travels along and the gear that drives it) if CDs aren't recognized or won't play, frequent skipping occurs at random, CDs randomly get stuck in one spot, the player can't find tracks correctly, or cleaning the lens doesn't work. Dust and lint may be interrupting its function.
Have the laser-head assembly checked by a repair person if the traverse assembly seems intact and free of debris.Look for broken plastic parts, such as gears and clips,look for loose or broken internal connections.possibly have gears and belts replaced.
Jun 09, 2011 | Audio Players & Recorders
I need instructions on removing the cover to replace the battry.microsoft wireless notebook laser mouse 7000.
  • Press the "button with the star symbol" while prying up the top cover of the mouse's body to replace the batteries. If the batteries have power, the LED on the underside of the mouse will illuminate.
  • 2 Plug the receiver component into an open and working USB port on your computer. Your computer should make a noise when the receiver is connected, and the system tray will show that you have connected new hardware. Some USB ports may not be compatible, so it is important to try several ports to find one that works.
  • 3 Press and hold the "connect" buttons on the underside of the mouse and on the receiver for several seconds to refresh the connection. An interrupted connection will cause jerky or inconsistent on-screen performance of the Microsoft Wireless Laser Mouse 7000.
  • Read more: How to Troubleshoot the Microsoft Wireless Laser Mouse 7000 ' eHow.com http://www.ehow.com/how_6803319_troubleshoot-wireless-laser-mouse-7000.html#ixzz1K9LY5L4u
    Apr 20, 2011 | Computers & Internet
    Motorola Razr Bluetooth Error- Failed: Connection Interrupted
    Some phone service providers block the transfer of files. It depends on who your service is through. I know Verizon and Sprint block them when I try to send from my phone to others with those providers.
    Jun 06, 2009 | Motorola Mobility RAZR V3
    What is the audio interrupt in lead wire ?.remote turn on lead ?.and were do i hook them up ?
    The audio interrupt lead = A wire that is typically is connected to a hands free cell phone system.
    The turn on lead = Is an activation wire that is typically is connected to an optional amplifier.
    Hope this helps.
    Good luck...
    Feb 23, 2009 | Alpine CDA-9887 CD Player
    New computer won't type letters.
    Normal 0 Press the Receiver button (and the lights will start flashing.
    Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
    If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
    Hope this helps. Bud
    Jan 22, 2009 | Computers & Internet
    I have a tom tom 720 after connecting it to my computer. it will not turn on a white cross in a red circle keeps flashing
    Ah, another case of the Red X. No worries, it can be fixed. Most likely your connection was interrupted during an installation or removal of software features. Follow this guide to get your TomTom back up and running.
    Dec 02, 2008 | Tomtom XL 330 Car GPS Receiver
    How to make logitech keyboard & mouse work??
    Hi there: I was also facing the same problem. But when you see on back of the keyboard the instructions are there. or follow these steps.
    1. insert new batteries both in keyboard and mouse. 2. decide what device you want to connect 1st (Lets connect Keyboard first) 3. Pres and Hold the connect button for both key board and receiver for about 5 secs. 4. don't press any key on key board till 10 secs (During this time it trying to connect with receiver) 5. Check the key board connectivity if it works then take it away or put it behind some barrier so that when you are connecting the mouse it don't interrupt. 6. now for the mouse do the same process as you have connected the keyboard.(step 3 & 4) 7. now check both key board and mouse they will work fine. Thanks
    Sep 21, 2008 | Logitech 967461-0403-PK Keyboard/Mouse
    I just installed an alpine deck and all i get is the word 'interrupt' on the display and nothing will play.
    When a device having the interrupt feature (such as a cellular telephone) is connected to the receiver, the audio signal will be automatically muted whenever the interrupt signal is received from the device. The supplied wiring harness contains a pink/black Interrupt lead that needs to be connected to the device's interrupt signal connection.
    Jul 27, 2008 | Alpine Car Audio & Video
    Computers & Internet Logo
    29 people viewed this question
    Top Adesso Computers & Internet Experts
    Alun Cox
    Pcm2048
    Chris Benedict
    Level 1 Expert
    Are you an Adesso Computer and Internet Expert? Answer questions, earn points and help others
