Question about Sharp EL-1801P Calculator
WHAT KIND OF RIBBON DOES THE SHARP EL-1801V USE AND WERE DO I FIND IT?
  • Cody May 11, 2010
    It uses model NUK-NR-42 for ribbon which can be found athttp://www.officeworld.com/Worlds-Bigges... Roll paper uses UNV-35720 which can be found athttp://www.amazon.com/UNV35720-Calculato...
    President:
  • 566 Answers
Ink roller type EA-772R
You can find it in any good (refer your machine make and model). There are compatible roller with different references. Also check online (do a gGoogle search or check Amazon.com and you will find several links fopr different seller.
Note that the same type of ribbon is use by diffrent calculators, evem from different brands, so lok for the image of the print roller to see if it looks like t he roller of your machine)
Posted on Jul 25, 2009
2 Suggested Answers
SOURCE: ribbon installation
I searched this online, and have found the following instructions:
1) Set the power switch to OFF
2) Remove the printer cover
3) Remove the ink roller by turning it counterclockwise and pulling it upward.
4) Install the correct color new ink roller and press it in the correct position. Make sure that the ink roller is securely in place.
5) Put back the printer cover.
Posted on Dec 29, 2008
Trying to put in a new paper roll
Turn off the Sharp EL-1801V.
  • 2 Cut the end of the replacement paper roll for a fresh edge and to ensure a smooth feed. Do not tear the paper roll, as feeding a torn paper roll can cause a paper jam.
  • 3 Insert the cut edge into the paper opening on the back of the Sharp EL-1801V. Hold the paper roll so that the edge being fed into the machine is coming from the bottom of the roll. Turn the power on.
  • 4 Press the "Feed" button until the paper is fed through the unit. Lift the metal paper roll holder up. Slide the paper roll onto the paper-roll holder.
  • Read more: Directions for Replacing the Paper Roll on a Sharp EL-1801V ' eHow.com http://www.ehow.com/how_7294657_directions-paper-roll-sharp-el_1801v.html#ixzz1eNqkJA8g
    Nov 21, 2011 | Sharp EL1801V Scientific Calculator
    Trying to replace the paper roll on a sharp EL1801V
    1 Turn off the Sharp EL-1801V.
    Sharp EL-1801V Calculator
    Change the switch to Rate Set, then input the mm.dd.yyyy then the clock/time button then hrs (military time).minutes then clock/time button.
    Apr 02, 2008 | Sharp EL-2630P Calculator
    Sharp EL-1801V 12 Digit 2 Color Printer
    if your trouble is repeated after you switch the calculator off and on again your printer needs service in workshop.
    Nov 01, 2007 | Sharp EL-2630P Calculator
    Sharp EL-1801P Calculator Logo
    2,637 people viewed this question
    Top Sharp Office Equipment & Supplies Experts
    Anthony Karuku
    k24674
    CheckitRight
    CheckitRight
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
