This not a DIY job. The display is a computer drive device and even if you knew the problem you can't buy parts to fix it. Check online for facilities that repair the center solid state control touch screen. You must send it out for repair.
I have a 97 buick skylark with 3.1 engine, car turns over but wont start, replaced crankshaft sensor, coil module pack and checked fuel pump, but still won't fire, no spark at plugs, has anyone went through this problem and what is the cure
If you can get it to a good Autoelectrician they will definitely find the problem quite quickly. 9 times out of 10 its either the battery is faulty or the starter motor needs repairing. Hope this helps, let me know how you get on.
most likely the electric motor that raises and lowers the window is defective, u will need to remove the door panel and replace the window motor, about a 2 hour job and $100 in parts.
these repairs are usually best left to an electromechanic but it can be doen by anyone with basic knowledge following the troubleshooting section in repair manual which can be purchase from local parts shop or online haynes or chiltons will do and get a multitester.
First check basics: are the fuses good to defrost blower? (fuse access refer to manual) then see if there is power to the blower/defrost switch use multi meter at 20V setting then see if there is power to blower unit under dash (see manual under interior section to access blower motor) probe using same setting to test for power on each wire ( as you turn blower setting from low to high you shuld notice the voltagre climbs aswell) if this checks out your blower motor is faulty replace and your good heres a few places to get the best deal on parts ebay.com Peach street autorecylcing 18003652341 www.godspeedmotorsportsonline.com
this sounds easy now i under stand that your windows and lights are working but let me tell you somethig speciel
if you have a motor in an remote control car it is not running then you go and check it in a torch and it works this is why
a starter motor on a car uses a lot of power and is very high draw (takes alot from the battery) a light or a power window motor uses less so it can provide the power needed where the starter motor needs more and it can not provide
hope you get what i mean
if i put a motor out of a corsa (1.4, 4 cylinder verry small motor) and put is in a bus it wont move it cause it is too hard then if i put it in a go cart it will fly tyr a new battery or see if you can borrow a friends to test it if it starts with a fully charges battery then all you need is a battery if not let me know more and i will do some home work for you
