Computers & Internet Logo
B
Brenda Rich Posted on Apr 04, 2016
Can the singer one plus computerized sewing machine be opened up to fix something on inside?
Re: part that fell inside the machine.
I cant seem to get rid of an error E6 it can take me up to 40 minutes of re threading it before it goes away
have you tried contacting singer about the problem, it could be a sensor, if it's malfunctioning, having it replaced may be the only way to fix the problem,, if it's still under warrenty, they may have you take it to a sewing machine shop to repair it..
here are 2 links to see if singer can help you with the problem
Contact Us Singer Sewing
Products Singer Sewing Co
1helpful
My Singer Quantum 9910 is completely locked up.The wheel can't be turn.
take it in far a warranty service check
the needle breaking may have altered something or broke something inside
Charge is flashing only two red lights
Find a Singer dealer and see if they can help. This is NOT something you should try to fix yourself. I wouldn't let them send it out. The repair shop needs to be at the dealer. Your machine is too expensive for DIY and any attempts will void your ability to have Singer fix it.
Brother CS6000i... the needle threader broke. A spring fell out and now it's loose and doesn't work. How do I get into it to fix it?
Contact your Brother dealer and ask if this is something you can fix.
If this mechanism is inside the machine, you may do more harm and that could result in more expense and invalidate your warranty.
My machine is not computerized. How do you fix
If the loops are on the bottom it means either the top tension is too loose or the lower tension is too tight. It can also mean that the thread is snagging on something in the bobbin case area.
sewman7
Thread breakage light keeps coming on
No, my problem is still not fixed, but being unemployed I can't afford to purchase a plan, I thought this information was free sorry. Thank you
Top Singer Computers & Internet Experts
TUSHAR PANDYA
TUSHAR PANDYA
Level 1 Expert
NOEL
NOEL
Are you a Singer Computer and Internet Expert? Answer questions, earn points and help others
