Question about Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
How do you calibrate a new internal scale in a modle 347002k/replaced scale now I need to calibrate it before putting machine back in service.
    President:
  • 180 Answers
From the main menu go to change default option,press 5454 then press enter key.after access to default nenu you have to select calibrate scal option.press again enter key then follow the on scree message.NOTE:FOR SCAL CALIBRATION YOU SHOULD HAVE 9KG/20LB OF WEIGHT.once you done so,press stop key to complete the prcess.
Posted on Jul 17, 2009
I have a supreme weigh sw02 digital pocket scale i need to calibrate and need help
500ml 0f water is exactly 500g, measure that volume and put it in freezer bag and use as calibration weight, or if you have friend with scales - borrow from him scale weights.
if you use water - accuracy of the scale will not be absolute, it may vary few g either way.
another way - go to shop and buy 500g block of butter - put it on the scale in the shop - remove or add as you need till you have exact 500g, shop scales are accurate on that weight within 2g
do not forget to vote if you find this answer useful...
Jan 02, 2015 | Health & Beauty
My shippng scale is not working and is giving me an error. I need to know what the error is
It needs calibration. Turn it on while holding done the mode button. The display will read CAL
Let the button go and put the weight on the scale it is asking for to calibrate
If the weight is to spec it will read PASS
Turn it off and back on to use
If it still shows error it make be damaged
Sep 05, 2012 | Royal EX330 Shipping Scale 29533D
34288 scale calibration procedure
the machine came with a calibration check weight in the menue you can check the calibration. if it fails contact your local service center the machines have to be calibrated with certified weights unlike the older machines.
Jul 07, 2012 | Robinair Cool Tech 34700Z Recovery,...
I have a Robinair 347002K abnd cannot access anything under defaults. Defaults show as a menu item, but I can not see or select anything else under that heading I tried the 5454 password i saw on another...
You may did not try in the right way! The access code (5454) is 100% right for 347002K/347112K and 34700Z new series machines. If keypad has oil injection button (old series machine) press 8787 on keypad.
However you can try as following: To access the change Defaults menu press 5454 (If keypad has oil injection button old series machine press 8787) on the keypad then press ENTER/START arrow key. Now display will change to "Calibrate Scale". Press up or down key to select option you wish to access from: Set Tank Tare, Output Test, Input Test, Keypad Test. Prepare to Ship. Reset Board Memory etc...
NOTE: DO NOT CHANGE 'SET TANK TARE' OR PRESS 'PREAPARE TO SHIP' & RESET BOARD MEMORY' IF YOU ARE NOT FAMILIAR WITH THIS MACHIN!
Hope this will help you. Good luck!
Mar 31, 2011 | Robinair Cool Tech 34700Z Recovery,...
During tank refilling
With switch on press YES/ENTER & STOP/NO key at the same time and watch the screen to come back as normal condition. If it is the same then you have to replace SCALE assy.
After replacing SCALE assy.you must CALIBRATE the new scal before use the machine. For calibration follow as bellow:
Form the main menu go to ''CHANGE DEFAULT'' then press 5454 & YES key (passwoed to access default option).Once you enter to default menu,go to "SCALE CALIBRATION" & press YES key. now follow the on screen text.
NOTE:you should have 9KG/20LBS of weight for scale calibra
Hope this will solve your problem & if my solution is useful to you please vote for it.
Jul 15, 2010 | Robinair Cool Tech 34700Z Recovery,...
Wont vacuum
With machine power OFF,remove old pressure transducer & replace new one.now power ON the machine & go for calibration.Calibration step for Robinair 34700Z machine.Form the main menu go to ''CHANGE DEFAULT'' then press 5454 & YES key (passwoed to access default option).Once you enter to default menu,go to "SCALE CALIBRATION" & press YES key.now follow the on screen help text.NOTE:you should have 9KG/20LBS of weight for scale calibration.
May 21, 2010 | Robinair Cool Tech 34700Z Recovery,...
New Scale out of box will not weigh correctly
Take a 5 pound bag of sugar, flour or what have you. Put it on the scale. If it is off, turn the scale so that you can check every possible place for an adjustment. Adjust and go for it!!! Good luck...Lee
Jan 16, 2010 | Jobar International Idea Works Wireless...
I have a chefmate nutritional scale that was working fine,then all of a sudden the screen started saying out2. replaced batteries but nothing so far.
It is not OUT2, but rather OUE2, which means your chefmate needs to re calibrate. To do that you will need the following:
a 2000 grams weight or 4.4 lbs, I used a 3lbs protein jug unopenened and a 600 grams glutamine bottle unopened.
Ok so turn your scale off then:
1) press the ON button and leave it press while simultaneously pressing once the TARE button (though it may need more than one or maybe leaving it press for a few secs thought try just hitting it once first), release the TARE and you should see a CAL on the screen (top left), release the ON and it will read:
2) the number 00000 on the first line will appear, click TARE
-this calibrates no weight first-
3) then it will read you another weight mine read 2000 grams, put that weight on top of the scale (NOTE every scale uses a different weight to calibrate i am giving you mine) once you put it there hit tare and it should read PASS
4) Remove the weight and it should read "0", mine read first 1 grm so i had to re do it again until i got 0.
5) You can try weighting different unopened things that you know the weight of, but if not just turn it OFF then back ON and it should read "0"
Congratulations your scale is now calibrated and ready to use again!!!!
NOTES: i have the electric scale if the on tare button does not works for you it may need a different combination to calibrate.
Sep 08, 2009 | Health & Beauty
Taylor 7530 scale wont turn on,i have new batteries
Basically, the frisbee comment is on the mark. I called Taylor. a nice person walked me through a calibration exercise: take batteries out; stand on scale for 7 sec.; get off; put batteries back in (assuming they are still good); step on scale and if it reads ---- step off again, then back on to weigh yourself. My scale's display was blank, not -----, so they said calibration was unsuccessful & so I mailed it back to the NM address on the bottom. It just fits w/ padding diagonally in a USPS flat rate box. Waiting to see if they replace it (lifetime warranty).
Dec 18, 2008 | Taylor 7532 Ultra Thin Glass Digital Scale
Calibration is off
My Weight Watchers digital scales model#ww39 has gone haywire. I put new batteries in it to no avail. You tap it and the numbers come right up then changes to 000.0 as it should, when you step on the scales the numbers flash as they should but either they weight you about 100lbs to heavy or the numbers continue to blink and the LCD goes blank. Can they be fixed? Can I fix them myself at home? Do I need to shoot them? Just throw them out in the yard? Please I need help!!
Oct 01, 2008 | Taylor Dgtl Body Fat Scale
Robinair  Cool Tech 34700Z Recovery, Recycling, Recharging Logo
579 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
