Question about Stanley Measuring Tools & Sensors
I own a Stanley compulevel and the screen is saying ''check cord''. I understand that it needs to be refilled. What is the ''estimated'' cost of such a service?
Satreece,
The only location that you can get service for the Stanley COMPULEVEL is from Technidea Corporation. A standard factory recharge for the Stanley COMPULEVEL 35-100 Elevation Measurement System is $150.00 and includes a thorough evaluation, R&R of the liquid, recharge of the pressurizing gas, testing, cleaning and repackaging, and complimentary return shipping via UPS Ground to all locations in the US and Canada.
An electronics upgrade is also available for your COMPULEVEL, allowing 2X faster and 3X more accurate measuring and significantly more stable readings. COMPULEVEL upgrades start at $195.00, plus the cost of the standard recharge.
For detailed instructions on how and where to send your COMPULEVEL for service, please visit www.ziplevel.com and click on the 'Service' tab at the top of the page. If you would like to upgrade your COMPULEVEL, please include a brief note with your unit when you send it in for service.
Contact information for Technidea is below.
800.805.LEVEL
760.480.4740 Office
760.480.4738 Fax
info@technideacorp.com
www.ziplevel.com
Posted on Jul 17, 2009
My Stanley electric stapler tre550 will not power on or do anything
The most common problem will be the switch that is hooked to the trigger mechanism.
Other than that, second most common is a bad wire, inside the machine or inside the cord.
Either way, you may need to take it apart to see.
Understand that they are hard to get back together.
If all of that is good, you will likely need to replace the stapler.
God bless your efforts.
Mar 13, 2017 | Stanley Tools & Hardware - Others
Half screen is black what's the cost to repair
depends on the brand and model---most flat panels use either two boards (one drives each side of the screen) or combine them into one larger board.
Understand the board should repair this but no promise--with this type of set it is buy and try a new board.
Keep in mind if a shop gets this the ONLY way they can know it to actually replace a board---if the shoot you a price they are guessing, that way they still charge the estimate even if not repaired.
On a typical set say over 32 inches I would guess 150 parts and labor and UP.
Dec 06, 2012 | Televison & Video
Selphy cp780 continues to say ink cartridge empty even after installing new one. Tried 2 new ones to be certain it wasn't the cartridge, same thing...tells me ink cartridge empty install new.
try and reset your printer,unplug the power cord and wait 10 min, then plug back in,understand that Canon has installed a chip so you cannot use refilled cartridges,or cartridges you refill,if this doesn't work,then contact Canon,and you could get the same message I got take it in to be repaired, (to costly), so I end up buying a new one,,
Oct 10, 2012 | Canon SELPHY CP780 COMPACT PHOTO...
My ice maker quit working today.
Check if compressor is running, if not check relay, capacitor.
If working and there is no cooling then check the pumping pressure.
Check gas in the system if low check for leak or refill.
If compressor is showing low pumping , the cost of replacement must be estimated so as to reach a decision.
Sep 01, 2010 | Frigidaire PLHS67EESB Side by Side...
Problem with USB cord, but the usb cord fits in printer and laptop fine. Computer screen says Printer ready, but when I try to print a message says check USB cord. Don't understand
Try using another USB port if you have one. If the others are full, disconnect one of your devices from the USB port and try your printer there. For some reason, switching the USB port sometimes makes devices connect. Good luck!
Mar 13, 2010 | Lexmark X2600 InkJet Printer
How can I make your 8500 pro accept a refilled HP cartrige.
The HP 940 cartridge is the new version of the HP 88 cartridge. Both have a chip that estimates ink levels. Once the chip says the cartridge is empty it will refuse to print, no matter how much ink is really left in the cartridge. This is a safety measure so you don't get air in your ink lines. If you get air in an ink line, that color will no longer print. We can refill the HP 88 because there are replacement chips available for these cartridges. I own a Cartridge World ink refilling store and I don't refill the HP 940s yet because I don't have access to a replacement chip. If you purchased a refilled HP 940 and it's not working, I would say the chip has not been replaced. I would wait until a reputable refiller (i.e.-Cartridge World, Office Depot, etc..) offers refills for this cartridge before you try anything off the internet.
Feb 16, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Estimated ink levels are incorrect
The simple solution is to buy the HP cartridges. Often times,.. MOST times, aftermarket ink cartridges and refill kits are an inferior product. The difference is not always noticeable right away, but almost always rears it's head in the end. This is usually due to the ink being of a different viscosity than the original ink. Which leads to sloppy prints, sensor errors, leaky or dead jets.
Personally I recommend everyone buy Laser printers. With prices where they are these days, there is no reason for anyone to buy an inkjet printer. Lasers will cost more up front, but are much cheaper per page and generally longer lasting.
Feb 15, 2009 | HP PhotoSmart C4280 Laser Printer
Broken Sansa e260 screen...
Well it should cost just about $200 because there'z 2 screens on the sandisk itz gonna take alot of dismantling so yer
well i g2g hope it works and guud luck :)
Sep 22, 2008 | SanDisk Sansa e260 MP3 Player
Cracked screen
Hey benno82,
You could call the manufacturer and they should have a list of authorized service centers in your area, or they could provide you with an address of an authorized service center you could mail the camera in to get serviced. You could also bring the camera to a Geek Squad® precinct in a Best Buy™ store and they could send it out to an authorized service center to have an estimate done. As far as how much it would cost it all really depends on what the new LCD screen cost and if there is any other parts that need to be replaced. I will say that digital camera repairs often exceed the value of the camera, but it doesn't hurt to get an estimate done. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 28, 2008 | Olympus Stylus 720 SW Digital Camera
Measuring Tools & Sensors Logo
1,833 people viewed this question
Top Stanley Measuring Tools & Sensors Experts
Lawrence Oravetz
Vernon Taylor
Andrew Taylor
Andrew Taylor
Are you a Stanley Measuring Tool and Sensor Expert? Answer questions, earn points and help others
