Question about Ingersoll Rand Type 30 Fully Packaged Ir Electric Stationary Air Compressor No. 2475N7.5FP 7.5HP. 80 Gallon Vertical Two Stage
Where can i find motor fan part # 2mtr and 3mtr ingersoll rand compressor ssr-ep25
    New Friend:
89264527 Cooling Fan 250mm 54480355 Cooling Fan 300mm
Posted on Jun 20, 2013
  • 142 Answers
I would try Grainger (www.grainger.com)
They sell IR compressors and always have a large assortment of parts
Posted on Jul 16, 2009
How to change from BAR to PSI on INGERSOLL RAND INTELLISYS CONTROL for INGERSOLL RAND SSR-6-20-125 AIR COMPRESSOR
Ingersolll Rand website support section should be able to provide a manual.
Failing that contact customer services.
Aug 03, 2016 | Ingersoll Rand Air Tools & Compressors
My air compressor wont start ssr up series 5-15 hp
does the motor hum? if so, the motor capacitor is faulty.
Motor completely quiet? Check for power at the motor using a volt meter.
Sep 22, 2014 | Ingersoll Rand Air Tools & Compressors
I have a problem on SSR M37...the unit shutsdown with a Low Sump Pressure display, what causes
you need to recalibrate the stepper motor on the inlet valve which only a ingersoll rand tech can perform cause it is kind of tricky .and if that doesn't fix it it could be just a simple adjustment or a bad stepper motor or a broken inlet valve arm or worse a bad control board good luck.
Mar 18, 2014 | Ingersoll Rand Air Tools & Compressors
Ingersoll Rand SSR compressor shuts down loaded or unloaded with no alarm, and then shows ready to start . Will not run more than a few minutes either loaded or unloaded. installed meter on incoming power...
When it shuts down, press DISPLAY SELECT button once and use the up down arrows to see the code just before shutdown.
HIGH AIREND TEMP
HIGH AIR PRESSURE
LOW SUMP PRESSURE
PRESSURE OR TEMP SENSOR FAIL
CHECK MOTOR ROTATION
MOTOR OVERLOAD
FAN MOTOR OVERLOAD
STARTER FAULT
I am assuming this has a Intellisys controller.
Aug 25, 2009 | Air Tools & Compressors
Ingersoll Rand  Type 30 Fully Packaged Ir Electric Stationary Air Compressor No. 2475N7.5FP 7.5HP. 80 Gallon Vertical Two Stage  Logo
270 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
