Question about Danby DPAC10031 Air Conditioner
The air conditionner won't stay on in cooling mode :(
Hi . The problem is that it won't stay on in cooling mode. After running for about 10 or 15 mins it just shuts off. And i have to unplug it , plug it and power it. And the same thing happen. The red light indicates also ''water full'' but when i check the internal reservoir ( water collector ), it's empty. Even when i connect the external reservoir, the same problem occur. The only solution is to open the drain plug ( the water is flowing from there ) and connect it to a reservoit thru a pipe. hat way it don't stop working. So, please can any technician give me the solution to this problem. Thanks.
  • 2 more comments
  • Adamyhy Dec 02, 2007
    Thank you for the advice. Is it risky if i continue using it by connecting a pipe at the water plug ? Is it costly to fix the sensor ?
    Thanks for the advice.
  • Adamyhy Dec 05, 2007
    Thank you very much. Please, do you think i can do it by myself ?
  • Adamyhy Dec 24, 2007
    Thank you so much
    Hi. I identified exectly now the model and finally it was not 10031 but 10030. So, i followed your instructions but it seem that the container is different and there is no switch there unfortunately
    :( I have been mistaken by the seller who sold me this air conditionner. Do you have an idea how to find the switch on this model, please ?
    Thank you so much for your help
  • 80 Answers
THERE IS A SENSOR THAT TELLS THE UNIT WHEN THE WATER IS FULL SOUNDS LIKE IT WHENT BAD
Posted on Dec 01, 2007
  • DAMIEN DOWLING
    DAMIEN DOWLING Dec 03, 2007
    Its ok to run it that way it will not hurt the machine. But the new switch takes 5 min. to change and costs about 6 dollars
  • DAMIEN DOWLING
    DAMIEN DOWLING Dec 05, 2007
    YES YOU CAN JUST LOOK AT THE CONTAINER THAT HOLDS THE WATER AND YOU WILL SEE A SWITCH THERE. THERE ARE ONLY TWO WIRES ON THE SWITCH TO MAKE AND BREAK CONNECTION THE SWITCH IS NORMALLY HELD IN BY A CLIP OR TWO SCREWS JUST REMOVE THE SWITCH TAKE THE TWO WIRES OFF TAKE THE SWITCH TO A LOCAL HARDWARE STORE OR ELECTRICAL SUPPLIER AND ASK THEM FOR A NEW ONE THEN REINSTALL THE SAME WAY YOU PULLED IT OUT
Air conditionner symbol chart
Well, that's pretty general but... USUALLY, sun=heat, snowflake=cooling, water drop=dehumidifing, fan blades =Fan only.???
Aug 15, 2017 | Heating & Cooling
Panasonic Air Conditionner will not work It will cool for 30 secs then the louver will close and the timer light will flash On heat mode it will work fine except the air is not as hot as it used to be
sounds like the air filter is dirty. Air flow is restricted and the compressor will shutdown if it gets too cold because the available air cannot warm up the evaporator enough. That could also be the reason it does not heat as well either. Since you do not mention that the air flow is lower than it use to be.
Apr 22, 2014 | Heating & Cooling
Duo Therm A/C (2009 Sabre RV) won't shut off
bad compressor relay on control board. The relay is not opening the circuit, allowing the compressor to stay running when unit is turned off. This overheats the compressor and opens a thermal disk shutting the compressor off. When thermal disk cools down, the compressor restarts under load and trips breaker.
Jun 06, 2013 | Dometic Rooftop RV Air Conditioner
Need a control remot for my 30000 btu Lennox unit
Hi jean, If you haven't found a remote yet then try Ebay OR Amazon..... The link below is an Ebay page showing a few different lennox remote controls, I hope this helps............CHEERS..
remote control for 30000 btu Lennox
Aug 26, 2012 | Danby DPAC8399 Air Conditioner
I i`ve got a haier split type air conditionner model HSU12XCA on R22 gaz which barely cools and freezes after a while. The suction pressure is at 120 PSI and it is freezing on the liquide line. I`ve clean...
The unit has a leak and is low on freon...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 12, 2011 | Haier HSU12XCA Cooling Only Mini Split Air...
Furnace is 7 years old. Will not stay running for more than 5 min. Will start up again after shutting off and then run for another 5 min. Suggestions?
Check the air filter. Jump out thermostat to see if it stays running longer, if so replace thermostat. Make sure all return air ducts are clear of debris. If furnace has a Fan/Limit switch, make sure tabs are set at 100, 140 and 200. Sounds like something may be heating up and shutting unit off till it cools back down.
Jan 03, 2011 | Ruud Heating & Cooling
FAN STAYS ON LONG (HOURS) AFTER COOLING TEMP IS ACHIEVED
There is a built in delay on all HVAC systems to evacuate conditioned air (hot or cold) from the ducts -- it's just more efficient that way... but if it's staying on for more that 4-5 minutes at most then there may be a problem with the fan relay... or possibly a limit switch.
Sep 02, 2009 | Heating & Cooling
9000 btu maytag portable AIR CONDITIONNER Model M6PO9D2B-B
Reasonalbe rule of thumb is a difference of 10 degrees Centigrade.
Charlie
Aug 18, 2009 | Maytag Electronic Portable Air Conditioner...
Error E559 on air conditionner Samsung MH026FWEA
Go to your outside unit and press the K3 button.
Oct 31, 2008 | Heating & Cooling
A/C switching to heat
I have the same problem, it may cool for 1 min or 5 min then go to heat mode. Once it goes to heat mode only way to reset is to shut the AC down and let it cool. It may or amy not work the next time.
Jul 10, 2008 | Dometic Rooftop RV Air Conditioner
Danby DPAC10031 Air Conditioner Logo
627 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
