Question about Electrolux EL5020 Vacuum
No power Hi, The power indicator light remains off on my EL5020, I have removed the fenders but what kind of screwdriver do I use for these "star" shaped screws? And would would be the likely cause to this, I have changed the plug. Thanks, Kent
    Scholar:
  • 78 Answers
Use a t6, or t4 screwdriver,
b4 u go on plz check the fuse of ur machine, or the power rating of it.
or check for the earthing.
Posted on Jul 17, 2009
THE POWER LIGHT WENT OFF BUT POWER STILL ON
Hi Carol,
I'm sorry to hear you're having difficulties with your Dyson vacuum cleaner. As DC25 doesn't feature any indicator lights, your machine is likely to be DC28.
If the machine continues to run and pick up as normal, but the on/off switch indicator light has gone out, it's probably best if you get in touch with us directly so we can provide further assistance. You can call us free on 1866MYDYSON, or email askdysonUS@dyson.com. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Nov 13, 2011 | Dyson DC25 All Floors Bagless Upright...
The grey pre-filter catch broke and we got a new one. now we don't know how to remove the old one.
Hi Sabine,
You can remove the remaining section of the original catch by levering it out with a very small screwdriver. The new one should then clip into place. If you need any further assistance, please give our Helpline a call free on 0800 298 0298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Nov 03, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
Have a power brush and cannot get the brush out to clean. I've taken off the main cover, but the brush is held in by a bracket. I can't take off the main cover as I don't have the right kind of...
I have a Miele STB-205-3 Turbobrush. After opening the brush cover using a quarter, I use a T-7 torx screw driver (shaped like star of David) to remove the main cover that is held by 4 screws.
There are 2 more screws holding the fan housing. After unscrewing them, you can take the whole thing apart and clean it. Make sure you clean all rotating parts as they collect a lot of hair, dust, etc,
Sep 13, 2011 | Miele S251i Plus Bagged Canister Vacuum
Miele Red Star model S314. Cord reel is stuck. About three feet of cord is out. The rest of cord is jammed inside machine? How do I get to where the cord reel is?
It is actually simple when I tell you, Here we go...
First, open the lid and take the bag, and hepa filter out of the machine.
With a slot screwdriver, pry the hinges of the bag door out a little and take the bag door off.
You should see one screw holding the black black panel, remove that. When that is out, you can pull the black panel off. It will give a little resistance to you, do not be afraid of breaking it, it will come off.
Next you will see 4 or 5 screws down the holes there, remove all of them and the final remaining red piece will come off. When you pull this off, it will have both the cord rewinder and the motor assembly attached to it. It will be heavy becasue of the motor. Before you pull out the cord rewinder, just have a look at it closely and you may be able to just fix it without removing anything else.
good luck with it.
Nov 05, 2010 | Miele Red Star Bagged Canister Vacuum
Electrolux Epic 6500/ handle clip broke....
The clip can be replaced by taking apart the handle. Small round plastic inserts cover up the screws that hold the handle together. Use a very small screwdriver to pry them off, then use a small screwdriver to remove the screws(Some of the screws may be star screws requiring a special screwdriver. The top part of the handle will then lift off and you will be able to change out the clip. Before reasembling the handle, clean the contacts which attach to the hose and be careful that you do not bend the contacts. It is kind of tricky to put back together.
Good Luck
Captaintek
Mar 26, 2009 | Electrolux Epic 6500 Vacuum
Electrolux EL5020A VacuumCleaner - taking apart
these[ things] you talk about are called lock clips.with a little force and a small screwdriver they open be careful not to snap them, take your time as you move along; the lock clips will start to reveal themselves more openly again take your time ,after the casing is opened it should reveal the electrical cord.;before you start this procedure make sure the electrical cord is unpluged from the power supply hope this helps you.adrian
Feb 16, 2009 | Electrolux EL5020 Vacuum
Brushes not turning Electrolux Intensity (EL5020)
it needs a new brush they get stripped out by hair and stuff
Nov 20, 2008 | Electrolux EL5020 Vacuum
Change cord on electrolux EL5020
In order to get to the cord that is disconnected you need to remove the screws that hold on the frame(the red shell). You will need to remove the "fenders" that are near the wheels. In order to remove the fenders get a flat tip screwdriver and pry up on the front part of the fender, there are three clips holding the left one on and two holding the fender near the cord. You will need to remove the left wheel (the wheel farthest from the cord). After you remove all the exterior screws and the four screws under the brissels the shell should be able to be removed. Next you will need to pull the cord all the way out and there will be a clear clip, use a flat tip screwdriver and release the clip in order to remove the clear piece that holds the power cord electrical ends. Reattach the clips of the power cord and be sure when you put the clear piece back in that the two contacts are not bending. You will need to use a screwdriver to guide the electrical clips back into place. I didn't count the screws there is a lot of them. I hope this helps you
Sep 20, 2008 | Electrolux EL5020 Vacuum
Miele white star canister vacuum - won't turn on, but isn't clogged
Miele white star canister vacuum - won't turn on,...
I have the above canister vac, which after my son tried to vac the stairs, it rolled down the stairs on him, but still worked, after turned off/on. Then after turned off maybe 10-15 mins., stopped working when we tried the switch. My father in law is our fix it guy, but still having a problem with the switch. Is there a wiring guide we could look at?
Thank you!
ALevy
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You can try to call the factory for the Miele S251i schematics / wiring diagram @ the phone number and website listed below or I put a few pieces of information listed below that might help.
1. The vacuum cleaner switches off automatically
A temperature limiter switches the vacuum cleaner off automatically if it gets too hot. Some models have a warning light (triangle) which comes on to indicate that it has overheated. Allow the appliance to cool down for approx. 30 mins. and remove any blockages to the air path.
2. The "Change dustbag" indicator stays on even when a new bag has been inserted
To ensure the dustbag change indicator gives a correct reading, lift the floor nozzle or power head off the floor slightly to prevent the vacuum created in the suction tube from influencing the reading.
3. The exhaust filter indicator is red
Change the exhaust filter and then press "Reset" to switch off the indicator light.
http://miele.com 1-800-999-1360 Customer Care
Toll-Free Contact Information
For a repair order, please contact us at our toll-free number (800) 999-1360, Monday through Friday from 8:00am to 8:00pm, Eastern Standard Time (EST).
www.AVACcorp.com 1-800-328-9430
Apr 18, 2008 | Miele S251i Plus Bagged Canister Vacuum
Electrolux EL5020 Vacuum Logo
171 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
