The door will not unlock. I unplugged for five minutes then hit cancel after I plugged in again but did not reset.
SOURCE: Error code E10 on the
E10 is a timeout code. I found the answer on google by refining my search criteria. The tap was not turned on enough for the washer to fill up in time before the timeout was reached. After restarting the washer and turning the tap on further, the washer cycle completed without error.
SOURCE: error message E31 on Electrolux I-touch front load washer
Hello kleveille
Welcome,
You said, your machine comes on but will not start
I need the model number to start to help you???????????????????
huuum
SOURCE: Washer lights are all flashing
Hi friend.....
It is an indication of an error code,,,,,,,did you see any error code on timer.........
thank u..........
SOURCE: 2009 Frontloading Electrolux washer door will not open!
When this happened in our home, we unplugged the machine, waited then plugged it in again. This reset the machine and the door immediately unlocked
SOURCE: error codes for Electrolux front load washer EWF 1087
E40 error is door interlock faulty, could be the lock or it could be the pcb u have to test them.
