Question about LG LFX21971ST Stainless Steel Bottom Freezer French Door Refrigerator
LG model LFX21971ST with bottom freezer. serious short circuit?
LG model LFX21971ST with bottom freezer. Daughter says this morning, "Dad, smells like something is burning in the refrigerator. Sure enough, light bulb covers are warped, plastic around metal where light bulbs sit is warped (from extreme heat). Unplugged frig. Took out both bulbs (still working before unplugged) and plugged frig back in and metal behind sockets again super-heated. Purchased in May 2006.
SOURCE: Refrigerator Lights Stayed on, Melted Plastic and Stopped Cooling
Same thing happened to us today. Call LG customer service they should offer you a one tiome extension on the warranty for parts only. DON'T ACCEPT! Tell them you need labor AND parts. I suspect there are a batch of bad relays in these refrigerators and they know it.
Posted on Jul 29, 2008
  • 12 Answers
The problem is with the main motherboard. It needs to be replaced along with the light socekt assembly. The new assembly has a temperature sensor that will cutoff power to the lights if it happens again.
Main board 6871jb1423n
Socket assembly 6621jk2003b
Posted on Oct 05, 2008
  • 531 Answers
SOURCE: Refrigerator warm and defrost heat sheath and coil frozen solid
check see if you have frost build up in freezer could be the heater or defrost thermostart or timer board call service
Posted on Apr 07, 2009
  • 10 Answers
SOURCE: Interior light bulbs stay on?
There is a switch on the inside of your frige that has gone bad. The switch is a slide type switch so when you open or close the door it makes the switch slide in and out, making the light come on and off. You need to write down the make and model # of your refrigerator and order a new switch either from the manufacturer or from the place you bought it. Once you have the new switch, unplug the refrigerator, take a flat head screw driver and gently pry the switch from the interior face, pull the two wires off and replace the old switch with the new. The switch is very inexpensive and very easy to replace. Calling a service technician out to do this could cost you more than you expect. If you are not very "mechanicaly enclinded" then just order the switch and have a brother, neihbor, or someone that is mechanicaly savy come over and fix it for you. It should not even take 5 minutes. ;-)
Posted on Aug 11, 2009
localwonder
  • 6784 Answers
SOURCE: lights stay on in fridge
HI. The door switch will be the culprit here.
The interior light in most refrigerators, and the fan in some, are controlled by a door switch. When the door is closed, the switch is depressed and the interior light goes off and the fan resumes normal operation. If the door is misaligned or the switch malfunctions, the refrigerator may become warm as a result of the non-operation of the evaporator fan and the heat generated by the interior light. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to zero when the probes touch the terminals. With the probes still touching the terminals depress the switch, the reading should change back to infinity. If it does not pass both of these tests, the switch should be replaced.
Posted on Dec 11, 2009
My side by side LG fridge trips CB after running for some time, it does this when fan stops. What could cause this?
It would appear that the defrost heater has failed. There is a heater element in the back of the freezer to defrost the freezer. If it has failed, it will either not heat at all or cause the circuit breaker to trip if it has shorted out. You will need to strip out the inside of the back of the freezer to get to it. The heater element fits around the bottom and side of the condenser coil.
Mar 28, 2016 | LG Refrigerators
Lower half of fridge is freezing food while upper half is fine
it needs room to breathe,too many things blocking air flow and turn it down a couple degrees,40 is good
May 30, 2015 | LG LFX21971ST Stainless Steel Bottom...
How do i reset the control panel for an LG model lfx21976st
if this unit is unplugged for 10-15 seconds, most times this will reset the controls, unless there is a problem with a control board (pcb).. if unplugging don't work I would call LG with model and serial numbers in hand and have them walk me through the process... some LG models are hard to figure out what their process is on the electronics..... hope this helps..... ken
Sep 30, 2014 | LG LFX21971ST Stainless Steel Bottom...
Water tastes bad from LMX28988 refrigerator
This is usually attributed to the filter needing to be replaced... once a new filter has been inserted it should clear up the taste problem.
Apr 19, 2014 | LG LFX21971ST Stainless Steel Bottom...
How do I reset the lg water filter indicator light on the control panel of my lg lfx21971st bottom freezer french door refrigerator?
i fixed the problem by asking my son. he has more patience than i and just held down the button longer and it worked.
Oct 14, 2009 | LG LFX21971ST Stainless Steel Bottom...
The refrigerator light will not turn off when the door is closed. How do I fix that?
THIS PROBLEM IS A SERIOUS FIRE HAZARD!!! And, apparently, it's a common issue -- one we had as well. Remove the bulbs immediately and call LG, stressing the fact that it is getting hot in there.
For us, they sent out a replacement circuit board and cover for the lights because the original one had MELTED.
Oct 04, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Burning Rubber smell coming from fridge
try taking the bottom panel off and vacuming all the dust on the coils. The dust may be heating up and burning. The coils are usually at the bottom of the fridge. Check to see if the fan is running also.
Jan 16, 2009 | Refrigerators
LG LFX21971ST Stainless Steel Bottom Freezer French Door Refrigerator Logo
49 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
