Question about Canon imageRUNNER 2270 Copier
Need part # for Canon ir 2830 main thermistor, it is not listed in my parts manual help
  • 4 Answers
In this copier you change the whole fixing on parts.
Posted on Aug 13, 2009
Hello sir I have canon ir 3300 in this code error is 000001-0002 so how can I solve this error
http://printcopy.info/?l=en&mod=erc&brand=canon&model=ir3300&code=E001-0002
Quoting from internet link:
Exploded Views and Parts List Free!
Code
E001-0002
Description
The sub thermistor detects about 295C or higher
Causes
The fixing film unit is faulty (i.e., the thermistor has a short circuit). The main power supply PCB is faulty. The DC controller PCB is faulty. Caution To clear the error, execute the following in service move: COPIER>FUNCTION>CLEAR>ERR.
Remedy
Check the interval between pin 1 and pin 2 and between pin 3 and pin 4 of the connectors (4-pin) of the thermistor for electrical continuity. Is it 0 W (short circuit)? YES: The thermistor has a short circuit. Replace the fixing film unit. If the thermistor has a short circuit, the indication in service mode (COPIER>DISPLAY>ANALOG) will be as follows from the start: FIXC= 250°C for the main thermistor; FIX-E=310°C for the sub thermistor. 2. Main power supply PCB, DC controller PCB Try replacing the main power supply PCB. Is the problem corrected? YES: End. NO: Replace the DC controller PCB.
Canon iR3300 Error Codes
May 01, 2018 | Canon Office Equipment & Supplies
The copier Ir 2570 its Opc drum in which copier is Equiverant to
The drum for Canon Ir 2570 is also equivalent to this machines: Like Canon IR 2230
Like Canon IR 2270
Like Canon IR 2530
Like Canon IR 2570
L ike Canon IR 3530
Like Canon IR 3570
Like Canon IR 2830
Like Canon IR 2870
Like Canon IR 4530
Like Canon IR 4570
Like Canon IR 3030
Like Canon IR 3025
Like Canon IR 3035
Like Canon IR 4035
Like Canon NPG 25
Like Canon NPG 26
Jul 30, 2017 | The Office Equipment & Supplies
Error code 0001-0002 canon 2830
Error code 0001 0002 ane par kya kare
Oct 09, 2014 | Canon Ir 2830 Digital Copier
E000225 0001
Oh, it looks like your ImageRunner's fixer unit (the heater thermistor it uses to regulate temperature) burned out or disconnected on you. http://canon-ir-6000.blogspot.com/2009/02/e000-main-cause-main-thermistor-th1-has.html
Find that little sensor leading up to the coils and replace it.
Otherwise, say that again in just Hindi?
Aug 04, 2014 | Canon Crtdg, gpr15, ir 2270/2870, bk
Canon ir 2830 e000003-0000
Low fixing temperature detection, The main thermistor reading is lower than 140oC when paper is moved. check fixing assy and replace with new one.
Apr 25, 2014 | Office Equipment & Supplies
I have ir4570 error code e00007
It is my pleasure to guide you.
Your Canon iR 4570 All in One Printer Manual iR4570
User's Guide can be downloaded at http://download.canon.it/manuali_operatore/files/iR4570_USR_ENG.pdf
Look at Chapter 3 Troubleshooting
List of Error Messages ..3-6
List of Error Codes without Messages. . 3-6
You will find the list of error codes.
Also, http://servisfc.blogspot.com/2010/12/detecting-error-e007-for.html
gives the following;
QUOTE
Detecting Error E007 at canon copier iR2270, iR2870, iR3570, iR4570, iR3530.
As part of its protective mechanism, the machine checks for the following error conditions.
Error Code: E007
Detail: 0000
Sympton: The fixing film rotates in an abnormal way.
Description: The reading of the main thermistor is in excess of 100 deg C with the fixing motor in a locked state and in addition, the machine fails to detect the marker signal for 6 second.
UNQUOTE
Good luck and please post back that you are successful, giving thumbs up, or that I can be more helpful.
Jun 09, 2011 | Office Equipment & Supplies
Canon ir 2830 coding out to E000007-0000 - what can correct this can I do it myself
CANON IR 2830 ERROR CODE e0007-0000 SIR PLEASE SOLUTION MY ERROR CODE
MOB.9636327398
EMAIL-M.KCOMPUTER31@GMAIL.COM
Mar 14, 2011 | Office Equipment & Supplies
Canon ir 2830 error code e 490
SIR CONON IR 2830 COMPUTER SE ATTACH HO SAKATI HE
Sep 03, 2010 | Canon IMAGERUNNER 3530 Copier
Canon ir 8500 cannot detect A4 paper in auto mode.any idea how to set this up?
there is a good possibility that the main thermistor and the sub thermistor has gone bad or is dirty. also it might need adjusted to be better placed next to the upper fixing roller.
May 12, 2010 | Canon imageRUNNER 8500 Copier
Canon imageRUNNER 2270 Copier Logo
222 people viewed this question
old marine
old marine
