Dell 1201MP Projector Logo
p
peter otieno Posted on Apr 04, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When the power button keeps on flashing blue light on my dell 1201MP project what could be the problem?
Ravi
Level 3:
  • Dell Master 1,682 Answers
  • Posted on Apr 04, 2016
Ravi
Dell Master
Level 3:
Answers
1682
Questions
Helped
580053
Points
8910
Blue. Light keeps flashing
IF THE POWER LIGHT IS BLINKING BLUE - The computer is in standby mode. Press a key on the keyboard, move the mouse, or press the power button to resume normal operation.
You can find its Service Manual here
http://downloads.dell.com/Manuals/all-products/esuprt_desktop/esuprt_vostro_desktop/vostro-420_Service%20Manual_en-us.pdf
3answers
My dell inspiron mini 10 won't boot.There is just a flash of white light then a flash of amber light when I press the power button. That's it, nothing else.
Remove the main battery and try again, also! the power adapter charger should be checked for correct voltage, if okay! pull one stick of ram and test, and the second piece not forgetting to put the first one back and power up, if all this fails you will need to get it assessed.
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
1201MP Projector in my daughter's classroom. The power button lights up the blue buttons on the top, but the lamp does not come on. We changed the bulb, same result. After a minute or so (we thought...
Clean the filters. Make sure that the vents are not blocked. fan are working? Make sure the lamp door is secured, Projector manufacturers will make the projector inoperable if the door isn't secured tightly. Reset the lamp timer. email me at [email protected] if you need a manual.
1helpful
Dell poweredge 1650 is beeping with blue flashing light
Flashing blue light is harmless - it simply means the Identify button has been pushed. There is a small button with a white, cursive 'i' on the front and back of the server - pressing this will make the light flash blue (or make it stop).
Go to Dell's support site and view the manual for the 1650 for an explanation of the beep code - identify the pattern of the beep.
If you are still able to get to Windows, use OpenManage Server Administrator to check the Hardware logs and RAID array.
Blue light flashing
Possibly the power board or the sustain board has died.
Power board failure does not stop the blue light from working as this is an LED on voltage side of power transformer. The set fails because it has detected a voltage difference in one o0f the other boards that controls the initial starup and convergence. Some transistors and capacitors are also possibly involved. Not a dIY unless you are skilled. Parts $300 labour ?
but about $400
If you are a DIY get a kit from this site, complete with step by step instructions This is an LCD rear projection set.The yellow blob may be from the drivers to the LCD display, dirt or object on the projection mechanism, stain on the mirrors or lamp; bad projection lamp - among others.If you are handy, get inside the set and see if you can observe any of the items mentioned above.
Ploease rate my help++++ Thanks for using FIXYA
With necessary connections of my laptop with my dell projector 1201MP my laptop is unable to see my dell projector 1201MP
Try pressing the Fn + F8 keys on the laptop, once the projector is connected and powered on.
7helpful
2answers
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
