Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
The self propelled feature does not work. Belts are OK but the drive wheels do not seem to be engaging. Is there a cable or something from the lever on the handle that needs to be replaced?
My vacuum cleaner does not turn on
could it be the motor out
i check the switch it ok not getting any power to the switch
Posted on Jul 19, 2009
  • dds_147 Jul 19, 2009
    the hoover vacuum clean started working but it stop when i came back from wal mart get a vacuum bag it had no power going to it... i check the out let on wall is ok check
    the switch to the vacuum is ok omg it out turn it off and on it has conitutity to it
    how much would a motor cost and could it be something else that mite be wrong with it
    email me back
    the belt are all ok just no movement of the motor at all
    daniel
    dds_147@yahoo.com
    or cell phone 559) 776-1563
I have the Hoover, self propelled vacuum. I have only used the self propel function a few times, but our babysitter used the feature and now the vacuum only works on the highest carpet setting. The middle...
Move the carpet height control switch to a higher position if the vacuum is difficult to push. If the setting is too low for the carpet being cleaned, the brushes press against the floor preventing the vacuum from moving easily.Set to a medium-high height setting then check.Slide the "Self-Propel" button to the "ON" position if the cleaner does not self-propel. -----------
The self-propel feature operates only when the cleaner switch and the self propel button are both ON. ---------- Try this settings and check.This should help.Thanks.Helpmech.
Jun 24, 2011 | Hoover Self-Propelled WindTunnel Bagless...
Just replaced the belts on my Hoover Windtunnel II self-propelled vacuum. The brushes are now turning ok, but the self propelled feature is not working. Squeals when when you lock it in the upright...
Check the plastic part, which the the self propelled cable is attached to. (release the handle, tilt it back. You should be able to see the cable attached by a screw to a black plastic arm.) It is either broken or the cable is lose.
Nov 14, 2010 | Hoover U6630-900 WindTunnel Bagless...
Self propelled feature does not work. I replaced
There is a cable from the handle down to the transmission on this machine that breaks all the time or the cable is mounted to a plastic piece that is broken. That will need to be replaced.
Nov 28, 2009 | Hoover U6476-910 WindTunnel Upright Vacuum...
Self Propel doesn't work on Hoover Wind Tunnel
Your self propel wire could be broken. Lean the vacuum back like you were using it. If you stand in front of the vacuum look down and to your left. When you move the selp propel button you should see a wire move. If not then it's broken.
Oct 06, 2009 | Hoover Self-Propelled WindTunnel Bagless...
Self propel does not work and it is real hard to push this way. We checked the belts and they both ok. Not sure what else to look at, the on line manual does not show any information
Hi there SmartAlec from NelsonVacuums.com.au here. Ok on this particular machine the belts strtch quite a bit and make the machine very hard to push even though the belts seem to be ok. I would recommend first making sure that the driving self propell is actually working at all. Tip the machine on its back all flat and turn it on. When you push handle up and down you should see a pair of wheels spinning one way then the other (corresponding to the way handle is pushed or pulled). As long as the wheels are moving then it is just that the wide flat belt just needs changing even though it is not broken. If the wheels are not turning at all even though belts are in place then you have a more sinister problem that will require a technition to check over.
hope this helps!
happy Vacuuming :)
Aug 12, 2009 | Hoover U6616-900 WindTunnel Bagless...
Self Propelled does not work
if you look below the headlamp of your vac you will find a cable that attach's to a piece called the actuator arm. either this piece is likely broke or the cable itself. always work the power drive smoothly or things will break. also could be that the smooth belt is stretched and will cause the same problem. belts should be replaced every 4 months. good news is all parts above should be under $5. dont let anyone tell you that you need a power drive assy, that usually isnt the case. good luck!!!
Sep 24, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Brush won't turn and self propel doesn't work
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40485&thid=619779
Brush won't turn and self propel doesn't work (by 2 users)
Posted by brucelk on May 24, 2008
I have replaced both the v-belt and the larger belt with Hoover brand belts and the brushes still don't turn properly and the self-propel function doesn't work. It seems that when I lower the handle all the way down toward the floor it works fine, but no one can vacuum this way. Is there an adjustment to belts to tighten them up? Otherwise I have to get it in to the only repair shop in town which is an hour's drive.X
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
OK
1 Other User Has the Same Problem Comment by chartsell, posted on May 29, 2008 I have replaced both the belts as well. I have tightened the screws as someone else as suggested. The brush still will not turn unless you lower the handle almost to the ground. Hello,
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover U6437-900 / U6439-900 Windtunnel Vacuum. It is not so much the belts, the 2 belts are only part of the solution. The average belt change is every 4 to 6 months as a rule and to change them @ the same time. The Hoover Self-Propelled works on when the handle is lower to a comfortable position then the self-propelled drive may just need and adjustment. There is a self-propelled rod that controls the self-propelled feature and it either needs adjustment or replacement or the part that hold it may be broken but either one can be fixed. So feel free to contact your local vacuum cleaner dealer with questions. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 24, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Self Propel
Determine if the wheels spin freely or if there is resistance. Sounds like you need a replacement belt for the drive. If you need help with installation, let me know.
Oct 29, 2007 | Kenmore 31913 Progressive Direct Drive...
Self propell feature not working
You can order the lever for the transmission on line for about $16.00. It comes as a cable and lever assembly. I just took the top cover off and replaced the lever without doing the cable. The reason ours broke is because we lifted the vacuum by the handle without the self propel bing turned off, this pulls on the actuator and breaks it.
Oct 28, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Bagless Windtunnel - Self Propel feature not working
I have the same problem with ours. If you lift the vacuum by the handle it breaks the lever on the transmission. You can find a replacement cable and lever on line for about $16.00 it is somewhat involved to repair but can be done by someone with mechanical ability. You can try and find a repair shop but be careful, they sometimes tell you the part is not available and try to sell you something else. I think they should be able to do the job for aprox. $80.00, but they may want more. I did it myself plus the height adj. knob for $24.00
Oct 28, 2007 | Hoover Vacuums
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
264 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
