Question about Spirit Fitness Z500 Treadmill
No power to the console of my Spirit Z500 but power button lights
My power light comes on at the bottom of my Spirit Z500, but no power to the console.
  • april_gibson Jul 16, 2009
    Yes, it is inserted. All Fuses look to be good. Thanks!
    Champion:
  • 363 Answers
Did you insert the safety switch key to activate the console.
Posted on Jul 16, 2009
Treadmill powers off when pressing Incline Increase "br 1" error
You may have a beltand deck problem. Test by the following procedure:
without the poweron stand on the walking belt, push the belt in the, direction it normally turns. If the belt is very difficult to turn (on most treadmill this means that you have high belt/deck friction I first apply silicone lubricant between the belt & deck to see if that clears up the problem. Most problems originate from the belt and deck 75 to 85% of the time
Jun 13, 2010 | Spirit Fitness Z500 Treadmill
My xbox 360 has a red ring around the power button.... how do i fix it????
If you are technically minded, this is very simple to fix, the hardest part is taking the consle apart.
there are many kits with self explanatory instruction available on the web, but try to find an all metal kit, ones with nylon washers only solve the problem in the short term.
once the case is opened, u need to remove the fan shroud and fan assembly, then remove the motherboard from the casing. turn the board upside down, and CAREFULLY!!! prise off the 2 silver x clamps from their locating lugs, the 2 processors/heatsinks can then be removed.
Clean all traces of thermal compound off the board and heatsinks using either white spirit or an alcho solution, if using w/spirit dry thoroughly.
apply new thermal compound, just enough to cover the processors on the board, and using the kit bought from ebay position the screws and washers and re-attach the heatsinks.
Now u need to plug the xbox into the mains, and attach the av cable, turn the xbox on, but dont reconnect the fans as u need the heatsinks to get hot and the console to overheat, this will take between 30 seconds to a coupe of mins, and when hot enough the console will show 2 red lights.... this is perfectly normal!!!!
once the 2 red lights appear, turn the console off by pullin the power cord out, do not use the on/off button. allow the console to cool for about half an hour. reassemble the xbox and hey presto u should now have green lights and the console fixed.
Mar 12, 2010 | Microsoft Xbox 360 Console
Contollers will not work. Lighting will only blink at the bottom of the controllers. Bateries have been replaced.
you need to reset \ resync the remote with the consol. turn off the power to the consol, unpllug it, plug back in, turn on, press the button inside the front flap to resync and press the red sync button on the remote under the battery cover.
Jan 24, 2010 | Nintendo Wii Console
I was updateing my psp when the power went out and noe it wont...
did u try to press the little square button on the bottom of the console next to the music note?
Jun 08, 2009 | Sony PlayStation Portable (PSP) Console
L5 code appears after it stops on the Z500 Treadmill
hi,
LS mean low speed error, Please check the sensor wire( if moor move). if not move please check control board.
Mar 30, 2009 | Spirit Fitness Z500 Treadmill
XBox 360 power problem
The power brick has most likely died.
Dec 14, 2007 | Microsoft Xbox 360 Console
Xbox comes on wont play games
what lights are flashing?
If its one its Hardware Failure
If its two its  Overheating
if its 3 its General Hardware Failure
If its four then AV Cable Cannot Be Found.
Do any numbers come up on the screen like an image with different types of language on with a code at the bottom ?
jon
Oct 17, 2007 | Microsoft Xbox 360 Console
Samsung SGH-Z500
cant send pictures never had problem befor
Aug 03, 2007 | Samsung SGH-Z500 Cellular Phone
Spirit Fitness Z500 Treadmill Logo
284 people viewed this question
Top Spirit Exercise & Fitness Experts
MrJunk
Level 1 Expert
Electro Med Services...
Tom Chichester
Are you a Spirit Exercise and Fitnes Expert? Answer questions, earn points and help others
