Question about Sony KP-57WV700 57" Rear Projection HDTV
Toshiba 42PW33Q rear projection gone blue
Hi, was wathcing my toshiba 42PW33Q rear projection tele and it suddenly turned blue with slightly brighter blue lines running across the screen, all the audio was fine. any help much appreciated.
    Problem Solver:
  • 5 Answers
Re: toshiba 42PW33Q rear projection gone blue
OK to help assist everyone having the BLUE HUE and CURVED LINES Issue on their Rear Projection HDTV no matter their model. Here are the steps to take. The first thing to check is the FOCUS BLOCK or G2 Focus Transformer or CRX F-Pack. I have replaced mine, however it didn't resolve the issue. I am onto the next item the CRT Board for Blue (Which is the board under one of the three color lamps inside your tv) Please see photo below (if photo is not large enough below go to link to review notes as well) If the CRT Board is not it, then the next step will be the Signal Board which is a larger board in the back. In a week I will have a picture of both.
  1. Remove the outside cover
  2. Remove the wood plank/panel
  3. In the front is the G2 Focus Block/Transformer, while set is on turn the top 3 knobs till the screen goes black/dark grey.
  4. adjusting the colors till you receive the desired or normal color/picture.
  5. Once you have received the proper color/picture tap the side of the Focus Block.
  6. IF The colors go out of wack again and the blue comes back strong then this "CAN BE" the Focus Block.
  7. NOTE: IF the color stays stable, then you problem is resolved and you do not need to replace it.
Replace the G2 Focus Block aka Focus Transformer, if Hitachi it's called a CRX F-Pack. This item will cost about $50. Not expensive. You will likely need a soldiering iron. DO TURN OFF & UNPLUG THE TV WHEN INSERTING ANY METAL OBJECTS INTO THE TV!!
FOLLOW THE PHOTOS/DIAGRAM in link below for assistance in the above instructions. I will post my next process since it was not my Focus Block that was an issue.
ONE SOLID PHOTO Go to URL CLICK HERE, click on that image to enlarge. Hope this helps you all out!
Posted on Apr 15, 2008
0 characters
3 Points
Screen turns blue on my sony KP-51WS500
Common issue on this set--locate the master screen / focus block and lower the BLUE screen control until the blue cast is gone, only a slight adjustment will be needed.
Dec 16, 2012 | Sony KP-65WS500 65" Rear Projection...
My tv has a red shadow a around the menu sccreen.
The RED CRT has gone bad and needs to be replaced but you must replaced ALL three CRT's because if you only replaced the RED one, it will be brighter than the Blue and Green CRT's.
Apr 03, 2010 | Samsung HCN4226W 42" Rear Projection...
Toshiba 43hx70 Cinema projection TV-where are the IC relays?
DID you ever get this fixed I am wanting to replace mine, I paid big $$ for this tv back 6 or so years ago, the picture cinvergence isnt real bad, but I cant line u the red and blues in the menu as good as they need to be. I was also wondering If i replace the lamp if the tv would be brighter. I have most my setting turned up but...The picture is not as bright and crisp as it used to be any one have a suggestion on this also..
Jan 02, 2010 | Toshiba TN43V71 43" Rear Projection...
Hi there ive got a toshiba 43vj13p very blue picture
Hello, you can then buy a replacement lamp or lamps Toshiba 43VJ13P? Thank you
Dec 21, 2009 | Toshiba 53H71 53 in. Rear Projection...
I have a LG TV and suddenly blue lines are appearing with slight blue background
blue CRT is shorted crts are no longer available you can have them rebuilt but they never look very good you might want to retire the set
Dec 04, 2009 | Sony KP-46WT500 46" Rear Projection...
Old toshiba
Hi Veronica,
I need to know exact model number of your Toshiba TV to help you out.
You can find it at back of TV on some kind of sticker.
Oct 11, 2008 | Zenith R49W36 49" Rear Projection HDTV
Toshiba 43" Rear Projection tv (Just show's Blue Screen)
Hi Chris,
It sounds like you have a tuner problem. Usally the set will turn blue if there is no signal to the set, which is first generated from the tuner. It could also be the processor on the main board, but I would look at the tuner first.
Good luck and I hope this has helped
Ed Meshechek
NC Electronic
Mills, Wyoming
May 28, 2008 | Toshiba 43H70 43" Rear Projection...
Flickering - Toshiba 62HMX84
it could be as simple as the tv feeding back on itself in a dark room.
it is adjusting the light level because of what it sees ambient in the room.
turn on a light near the tv and see if it stays constant now.
Mar 07, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
Sony KP-51HW40 fades to blue screen
you need change the ic in the soket blue [video out]
Aug 15, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KP-57WV700 57" Rear Projection HDTV Logo
256 people viewed this question
Top Sony Projection Televisions Experts
Steve Sweetleaf
Steve Sweetleaf
Jason Harris
Jason Harris
Are you a Sony Projection Television Expert? Answer questions, earn points and help others
