SOURCE: Will only charge to 40 psi, is supposed to charge to 150
You may have a problem still related to the original reason it was reconditioned.
However, you should have a regulator that you set to the tank pressure you want to maintain. Most have a tool regulator as well and 40 psi sounds like that is what it is set for.
If you do have a tank pressure regulator and it is still not charging above 40 psi, then either take it back or pick up a new regulator for under $20 at Home Depot and replace the gauge you have now.
Also, sometimes the gauge will have a needle tilted so that one end presses against the glass, and if you tap the glass hard with your finger it will move on around to the correct pressure.
Finally, if you are not experienced with small compressors, look under your gauge and see if there is not a black knob that pulls out and pushes in to turn and change the pressure.
Sirwriter
SOURCE: leaking air at regulator
Replace it. Any attempt to repair will not last long enough to make it worth while if you are successful at all. Eric
SOURCE: no air pressure thru quick connect to tools-bag regulator?
I dont know if it is like mine,but if you can let the air out of it and remove the regulator knob,and it`s components,you may can set it to just to be open all the time,in other words,by pass the control knob valve.Shout back at me if I can help.
SOURCE: I need a new belt for my Husky air compressor but I don't know
You may be able to find the belt you need on ebay. There is a seller named "Footballcardcellar" who lists these often and they are alot cheaper than buying the kit from Husky. Just search "Air compressor belt husky"
SOURCE: My porter cable air compressor
The airr pressure cut off switch is not working or out of alignment. What you can do is to adjust the spring with the air pressure reading at your required pressure. Once this is done allow the air to flow so that the compressor will work again to cur off, you will have to trim once again to set it to the correct condition. If the spring assembly is not working well on pressure you can remove and reset. If the contact are dirty , the switch on may not start the compressor, in such case clean the contacts. But if you think that it is not acting responsive, the please replace the unit and do the settting as explained above.
I hope you try this out. Good day
