Question about Navigon 7200T GPS NAVIGATOR PERPW/ FREE TRAFFIC VOICE ENTRY
When plugged in to car charger, my navigon goes into a computer connect mode (picture of a gps linked to a laptop), I can't plug it into charger and navigate at the same time. Why?
You need a stronger charger. I use a gomadic with tipo#24 and it works.
Posted on Nov 13, 2009
Navigon 2100 freezes when plugged in
sounds like you have the wrong charger did you buy a non gen one? you can charge it from the pc with mini usb lead, but will show the same screen
Dec 06, 2009 | GPS
Can my NVG5100 be used for navigation when charging
it should be able to. i have a garmin and it will work while plugged in.
Dec 03, 2009 | Panasonic Navigon 5100
Navigon 2100 displays the computer symbol when connected to charg
Wiring diagram pinout for Navigon GPS charge and concurrent use Pin Pin
Name Description 1 +5V 5 Volts Direct Current 2 Data floating/Not connected 3 Data floating/Not connected X Ident Conneted to Pin 4 (GND) as pure short, no resistor 4 Ground Ground, shorted to pin "X" Use of standard mini-b will place unit in Data Exchange/Synchronization mode. Use of mini-b with a 4-x pure short will allow use of Navigation software and concurrent charging. USB power source must be 1000 ma or above.
Sep 13, 2009 | Navigon 2100 Portable GPS Receiver
7200t thinks it's connected to computer when charging
Bad charger - not powerful enough, Use a Gomadic charger with tip # 24. Works for me.
Aug 29, 2009 | Navigon 7200T GPS NAVIGATOR PERPW/ FREE...
Navigon 5100 When connected to charger, computer icon comes up
you are not using a charger with the right voltage- you need 5 volts 1.2 amps radio shack has a gps charger that will work
Jul 15, 2009 | Panasonic Navigon 5100
NAVIGON 7200T IZ FULLY CHARGED BUT SHUTS OFF
These units have a circuit which detects if the charger is plugged in. It could be a problem with that circuit in which case you would have to get it repaired.
Jan 19, 2009 | Navigon 7200T GPS NAVIGATOR PERPW/ FREE...
Plug in car charger and it shows navigon connected to computer
The problem lies with the fact that a standard mini usb pin-out has + voltage on pin 1 and ground on pin 5. The navigon is programmed to recognize this as a computer. The navigon charger however has + voltage on pin 4 and ground on pin 5. The reason for navigon doing this as opposed to following the standard pin-out is due to the unit requiring a stronger power supply to charge the battery. USB current output on a computer does not have the capacity to do this. As a consequence, you will have to find a charger that has the right pin-out for this device ( + on pin 4 and - on pin 5 ). The tough thing is, there is no way to tell one from the other, they look identical. However, I have found that chargers with a capacity of 1000 ma or greater are pinned-out like above ( + on pin 4 and - on pin 5 ). Other than using a multimeter to verify the pins, the only thing to do, would be to plug it in and see if it works. Hope this helps.
Dec 28, 2008 | Navigon 2100 Portable GPS Receiver
Navigon 5100 gps
Try turning it off and turning it back on while it is still plugged in and see if that works.
Oct 23, 2008 | Panasonic Navigon 5100
Navigon 7200T GPS NAVIGATOR PERPW/ FREE TRAFFIC VOICE ENTRY  Logo
452 people viewed this question
Top Navigon GPS Experts
perdue40
Are you a Navigon GPS Expert? Answer questions, earn points and help others
