Question about Electric Garden
Craftsman model 580.752020 electric pressure washer. First time I used it worked for about three minutes then the motor stopped. I cannot get it to start again. Plugged into a 15 amp gfi circuit which did not trip. The light on the plug is red as per instructions. Unit is beyond warrenty. What to do?
  • 47 Answers
Turn off water and machine electrics.
remove high pressure hose from front of machine, this may be tight if there is still pressure in the system.
turn on water, when water comes out of machine hose outlet turn on machine. does the machine turn on and water flow increase, if so you probably have a blocked lance jet or trigger.
remove lance extension if fitted and fit hose back to machine, try again. If its ok then this proves you have a blocked lance jet, maybea poke about with some stiff wire will free the obstruction.
If this doesnt bring on the machine you probably have a jammed pressure switch on the pump.
this pressure switch turns on the pump when the trigger is pulled and switches the motor off when the trigger is released.
hope this helps.
Posted on Jul 18, 2009
I have an electric greenworks 1700 psi pressure washer that starts then stops repeatedly how do ya fix it
Sounds like the thermal switch is shutting it down. It is either bad or something is causing the motor to run too hot.
Jul 30, 2016 | Greenworks 1700 PSI 1.4 GPM Electric...
What is this problem - Karcher 3.86 electric pressure washer: humming noise, plug gets very hot, then unit shuts down?
Your pressure washer is either not fitted with a run/stop device in which case like mine you have to switch off within a few seconds of closing the trigger. Check your model features?
The humming noise is the motor stalled out against the pump because there is nowhere for the water to go. The shutoff is caused by the safety overload switching off after overheat.
Or, it has a pressure operated run/stop which is not working. Because water and electricity don't mix, I would suggest getting more specific help. You can download Karcher manuals /spares lists online from Karcher specialists but remember electricity is the silent killer.
May 20, 2014 | Karcher Garden
Pressure washer shuts off overheating
If you are using an extension cord this will happen. If using an extension cord make sure it is a 12ga.If you are not using an extension cord then it could be a bad motor or low voltage from the source.
Apr 19, 2014 | PowerStroke 1700 PSI Electric Pressure...
Water flows thru the pressure washer pump and out of wand, when I start the motor flow stops. I have a craftsman model # 580.752060 I've taken pump apart and there are no obstructions that I can...
Let the water run for a longer time. "Walk" the hoses, from the faucet to the pump and then to the nozzle, holding the hoses up to displace any trapped air in the lines through the pump and out the nozzle. What it sounds like is that air is reaching the pump. When it does, it cavitates, and no water can be pumped. Tighten all of your hose fittings securely. Try holding the trigger down while starting the washer. It may be easier with another person helping.
Best regards, --W/D--
Jul 08, 2011 | Craftsman 2500 PSI Briggs Stratton...
Some times the electic motor doesn't work is there a safety stop feature and if so how do you get around it?
There is a safety plate inside the machine so when the machine overheats the plates come apart. If this happens to many times the plates can actually stay apart and the pressure washer will not start or it will work for five minutes and then cut off. An electrician maybe able to help with this problem but I never advise anyone to tamper with the safety features of the pressure washer.
Mar 19, 2011 | Karcher K2.26 Electric Power Washer
My 580.752000 pressure washer now starts and immediately shuts down. It is as if it is full choked and stops due to over rich. Sooty spark plug and muffler replaced. Also new carb installed. Still problem...
This seems to be an electrical problem, replace your spark plug, & lead. make sure your electricals are all OK.
Check your "Points" also check, your magneto too... Ensure you have a good healthy spark.
many problems are caused by bad electrics,and mistaken for all sorts of problems, this all needs to be checked thoroughly.
Also check your air filter too.
troubleshooting link below to assist you.
http://pressurewashers.lifetips.com/cat/61621/troubleshooting-your-pressure-washer/index.html
below is a great site to show you what to do.
http://www.repairfaq.org/samnew/lmfaq.htm
Aug 16, 2010 | Craftsman Garden
Craftsman Electric Pressure Washer 1800 psi. Start then runs for a minute then stops.
The motor overload / thermal protection is likely the cause. Check your hose and wand / nozzle for restrictions. Is this the same hose and wand that it shipped with, or is it from another machine?
Your local Sears store can get you a user manual and diagram for our pressure washer for further troubleshooting.
Jun 27, 2010 | Vacuums
Pressure Washer quit running
I have owned four of those units. Every one of them did what you are experiencing or just wouldn't give me any pressure after only a few uses. The company was certainly no help. I gave up after four and bought a heavier gas model from Lowes. Hope this info helps.
Jul 06, 2009 | Karcher 1750 psi Electric Pressure Washer
I own a 3.86 model and have used it two times. I
was you using the machine on a electic extension & was it full unwoven.
chance thermal overload in switch knocked out.
there is also a little micro switch on the bypass valve that might be stucking , just in clip and test.
Jul 02, 2009 | Northstar Professional Series Pressure...
Garden Logo
1,006 people viewed this question
Top Electric Garden Experts
Steve Oakes
Mike Squire
roeb
Are you an Electric Garden Expert? Answer questions, earn points and help others
