Question about Canon XH A1 Mini DV Digital Camcorder
Please help me...When I connect my canon xh a1 to FCP 6.0 it says Unable to Initialize Capture Device Device is not connected or the capture preset is not setup correctly. You may still log offline clips. This might also happen if you play DV footage in an HDV device. I don't know what to do. I shot lots of film in 30f. PLEASE help...
  • 22 Answers
Try playing the tape before connecting up to the mac with the firewire and before loading FCP up. Usually fixes it for me when using either iMovie to import or FCP
Posted on Jan 21, 2010
  • Al Rush Nov 27, 2013
    FCP will see this camera as either a DV or HDV camera and the Easy Setup needs to match one or the other. If they are different that error will occur.
I am trying to digitize HDV footage using fcp 6.0.6 on an Intel imac with 2gb ram. Trying desperately to get my computer to recognize the Vixia HV 30 camera, but it will not. I have tried changing...
First, confirm what type of video is being output from the camera as HDV cameras can also ouput DV or can Downconvert HDV footage form the camera to DV even if the settings for recording were HDV.
The message is to double check and understand the menu settings within the camera.
Once done FCP will require an Easy Setup that matches the camera output.
If you shot and are indeed outputting HDV, start off with Easy Setup>HDV-Apple Intermediate Codec1080i60, assuming you a an NTSC user.
Mar 18, 2011 | Canon VIXIA HV30 DV Camcorder
I can't initialize on FCP
If you are capturing HD, go into the menu > IN/OUT REC > i.LINK CONV and set it to off, and A/V->DV OUT to off. Go into FCP and go to the File Menu and select "easy setup". In the easy setup menu set the "Format" to "HDV" and set "Use" to HDV - 1080i60. Click "Setup". Now go to File > Log and Capture (command-8). You're now set to capture. Just queue your tape and hit "Capture Now" or set in and out points and capture "Clip".
If you want to capture SD footage, then on your Sony unit, go to the menu and set the i.LINK CONV to "on". In the easy setup menu you will want to set "Format" to "NTSC" and "Use" to DV-NTSC".
Sep 26, 2008 | Sony GV-HD700 HDV VCR
XH A1
Drivers link
user manual link
After reading you manual you will notice on page 11 it states, that you need to use a P.C.it is not Mac compatable!!!!!
This touch screen will not work with Apple Mac
Dec 03, 2007 | 3M MicroTouch M170 17 in. Flat Panel LCD...
Do i need a cord to transfer my canon ax h1 footage to my computer?
Yes you need a IEEE 1394 (FireWire/i.LINK) cable to connect your camera to your computer.
Your computer also should have a Firewire port to connect this to your computer.
Else if you have a video capture card then you can connect the video out cable and capture the video from the camera.
Jan 03, 2011 | Canon XH A1 Mini DV Digital Camcorder
MacBook Pro/FCE does not capture video from XH A1 any more. Message: Cannot initialize HDV deck-please connect camera.
Play the tape on the camera before connecting it to the mac and loading up the software. You could always see if iMovie is giving the same error message too... This usually fixes the problem for me and usually arises when switching between SD and HD on the camera.
Dec 22, 2009 | Canon XH A1 Mini DV Digital Camcorder
When I capture HDV footage from my XH A1 to Final Cut Pro 5, the footage is out of sync. The video is playing like in 110%, or something like that. The original footage is in 24f mode. It doesnt happen in...
Make sure the properties for the project you start after the ingest match the frame rate you used to record. Reads like 29.97 speed setting looking at images recorded at 24f.
Jan 01, 2009 | Canon XH A1 Mini DV Digital Camcorder
Firewire worked once but not anymore...Canon XHA1
Solution? Maybe, but PC's vary greatly. Pass it on if it works for you. If Win-XP. Device manager. Un-install IEE1394. Close & Restart. Let the system restore the 1394 then try to reconnect the unit, cable to the PC first, then to the powered down camera. Power up the cam. What are you using to ingest? I recommed http://scenalyzer.com.
Dec 14, 2008 | Canon XH A1 Mini DV Digital Camcorder
Importing Video to a Mac
XL2s are notorious for issues in interacting with final cut.
Simply put, sometimes it will work, sometimes it won't. But - there's a way around it.
Change the capture settings preset to 'non-controllable device'. Use the shuttle controls on top the handle of the XL2 to play back the footage as you wish. when you want to capture, click 'Capture Now' - It should do the trick.
Apr 08, 2008 | Canon XL2 Mini DV Digital Camcorder
Get Final Cut Pro 5.04 to communicate with my XH A1
Many HDV cameras and decks are able to play and record DV as well as the higher-resolution HDV format. Additionally, many of these HDV devices will attempt to automatically change their settings to match the format of the tape that it's playing. Here are some tips for using these types of devices with Final Cut Pro / Final Cut Express.
Tip: Make explicit settings on your HDV device. Instead of using an "Auto" setting, make your own settings on your HDV device to keep the communication going between it and Final Cut Pro / Final Cut Express. This also helps Final Cut Pro / Final Cut Express keep things running smoothly with HDV devices that handle both DV-NTSC and DV-PAL.
For example, say you're using an HDV deck to capture footage from a tape that was recorded as DV-NTSC. Before capturing in Final Cut Pro / Final Cut Express, make sure that you set the deck to DV mode specifically—don't rely on Auto mode. With some devices, you may need to disconnect it from FireWire to change the mode.
For a common capture workflow, this sequence of steps can provide the best results:
  1. Quit Final Cut Pro / Final Cut Express if it's open.
  2. Insert your tape into your HDV deck or camcorder.
  3. Use the device's menus to set it to match the format that's recorded on the tape.
  4. Connect your HDV device to your computer with a FireWire cable.
  5. Open Final Cut Pro / Final Cut Express.
  6. Choose an Easy Setup for DV or HDV (whichever matches the format recorded on your tape).
  7. Proceed to Log and Capture.
Tip: Quit Final Cut Pro / Final Cut Express before changing modes. It's generally a good idea to quit Final Cut Pro / Final Cut Express before you change the mode on your device from DV to HDV, or from HDV to DV, and then re-open the application again.
Tip: Use an Easy Setup to play back non-default HDV format footage on your HDV device. You can use Final Cut Pro / Final Cut Express to make your HDV device play back footage in its non-default HDV format. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as 1080i50. Or perhaps you have a 1808i50 HDV device and you want to play back footage that was recorded as 1080i60. To do this, follow these steps:
  1. Connect your camera to your computer.
  2. In Final Cut Pro / Final Cut Express, choose an HDV preset Easy Setup that matches the format of the tape's footage (you don't need to restart Final Cut Pro / Final Cut Express).
  3. Your device's LCD display should automatically display a switch to 60 or 50, indicating the type of media that's being played.
Playing back non-default DV format footage on your HDV device You can also use your HDV device to play back footage in its non-default DV format too. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as DV-PAL. Or maybe you have a 1080i50 HDV device and want to play back footage that was recorded as DV-NTSC. If so, follow these steps:
  1. Make sure that your device is in DV/DVCAM mode.
  2. Put your device into Play/Pause mode, then open the Log and Capture window in Final Cut Pro / Final Cut Express.
  3. Make sure that your device's LCD (or other readout screen) displays the same format as your tape or Final Cut Pro / Final Cut Express will misinterpret what type of device you have.
Tip: Avoid recording both HDV and DV formats on the same tape. Use separate tapes whenever you want to record in a different format. If you need to record over existing footage in a different format (for example, you have a tape with DV-PAL on it, but you want to record over it with HDV 1080i50), it's a good idea to black and code the tape, or completely record over the old footage with contiguous recording in the new format. If the tape contains even a second of, say, DV in the middle of an HDV tape (or vice versa), it could cause unexpected results later when you try to capture video from that tape.
For more information, see HD and Broadcast Formats and the Final Cut Pro / Final Cut Express User Manual, available under the Final Cut Pro / Final Cut Express Help menu
Dec 04, 2007 | Canon XH A1 Mini DV Digital Camcorder
Canon XH A1 Mini DV Digital Camcorder Logo
267 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
