Question about Dell Latitude D410 Notebook
HP Pavillion zd8230 lap top. Jumping Cursor
HP Pavillion zd8230. When warmed up for awhile, cursor jumps to "home" position whatever you are working on. If email for instance, keeps jumping to beginning of sentence. If on a web page and scrolling down, keeps going back to beginning of page. Took me four corrections just to write this. Doesn't seem to do it when cold. Just started a couple weeks ago and computer is 3 yrs old. Bad Battery? Motherboard?
How do you stop the cursor from jumping on an elitebook folio 9470m
go to control panel / mouse to open the mouse properties window. along the top of the window should be several tabs. select the tab for touchpad or maybe advanced properties. this tab allows you to adjust the touch sensitivity of the mousepad, momentum, and other properties. adjusting to make it less sensitive may reduce the tendency of the cursor to jump or move on its own. failing that, go for an external mouse!
Aug 14, 2014 | HP EliteBook Folio 9470m 14in LED...
Why is cursor jumping using Gmail or Facebook on windows 8
Your OS is out of date and now obsolete. Win 10 has the patches you require for stability.
Jun 09, 2017 | HP Hewlett Packard 2000-410US 15.6"...
My cursor in windows 7 keeps jumping all over the place when I type or try to click on an icon how can I fix it?
Swap out the mouse.
If there is a ball underneath, remove it and clean the X and Y rollers.
Oct 16, 2012 | HP Computers & Internet
I have a hp pavillion dv 9700 i upgraded it with windows 7 and my mouse keeps jumping around all over while im typing. It did do this before when i had vista and I think that i downloaded a driver to fix...
I believe I can help in what you are experiencing with your jumping cursor concern. you mentioned that you downloaded a driver, try downloading touch freeze, google it it will give you links where to download it and it is free, this should fix your jumping cursor issue
any of the links will lead you to the downloads page for the application.
once downloaded this is what you should see on your task bar, see image below. an icon of a touchpad with a check mark on it.
Hope this helps with your touchpad concern, Have a nice day.
Mar 25, 2011 | Computers & Internet
My cursor jumps around. Why?
(1) If you are using a laptop for typing text and your cursor is jumping around while you are working with a touch pad then it is a common defect in many Laptops. The solution to this is that you disable the touch pad by pressing down Fn key and selecting the appropriate Function key. You have to use a mouse.
(2) If you are using a desktop and the cursor is jumping then it is a very high probability that you have a virus in your computer. Take a updated virus cleaner/remover and scan/clean your system.
Nov 19, 2010 | Microsoft Windows Vista Home Basic for PC
Jumping cursor of a
Hi! I think youre probably having a jumping cursor where the cursor jumps from one place to another while typing an email or something. You may got to control panel - hardware - mouse then look for the check box that you can tick on that says "Tap off while typing" and this should fix the problem. Thanks for visiting FixYa.com!
Jun 04, 2010 | Dell Inspiron 1525 Notebook
Cursor jumps to the buttom right corner of the screen
I've got the same problem. I've personally identified it as the digitizer being triggered by the fan. You'll notice that if you rotate the screen away from the fan area, the jumping will stop. Also, if you don't run the computer too hot, the jumping won't happen. I told HP about the problem a while ago but they ignored me. I've been using my laptop for the past year with the digitizer disabled in the device manager.
Aug 11, 2009 | HP Pavilion TX2000Z Notebook
Back arrow not working and cursor jumping around
you laptop is going through a keyboard failure.
Apr 03, 2009 | Dell Inspiron 2650 Notebook
Jumping mouse cursor
I think some where in the cable there is a broken wire, it is inside the cable, cause there is a certain position that it work properly. You can also test it by tyring other mouse if the problem still the same.
Oct 16, 2008 | HP Wireless Optical Mouse
Dell Latitude D410 Notebook Logo
234 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
