Question about Cerwin Vega CLSC-12S Subwoofer
It keeps blowing fuses - two 12 inch cls subs 1
It keeps blowing fuses - two 12 inch cls subs 1 keeps blowing fuses everytime being replaced took plug from the one that works plugged into the that doesn't work and it still keeps blowing fuses... there must be more to it.
  • 158 Answers
Sounds like the audio stage riving the channel has a short circuit on it.need to go through the amp stage
Posted on Jul 22, 2009
My teac ag-680 fuse keep blowing everytime i replace it and plug the reciever up
are short in the audio output transistors may have been short since a channel 2 or maybe 4, also open resistance check carefully and change them after you put a 75w bulb in series 100w or where is the fuse clearly, you have to remove the fuse when you put the focus if all is well will turn on only a small incandescent and amplifier work well you put audio speakers and there will, if everything is well put the fuse back and ready.
Jan 14, 2013 | Teac AG-680 Receiver
Behringer Europower PMP2000 Fuse keeps blowing when the amp is switched on.
For goodness sakes do NOT replace the fuse... doing so causes more damage inside. Likely one of the power amps has shorted and may have damaged the power supply as well. Also please read my tip on Fixya regarding a HAZARD with channel A if you use 1/4 inch plugs with the speaker cables. Essentially the sleeve of the channel A plug is the hot, and not the tip. Ground the sleeve of the plug and you can blow the channel A amp. YOU WILL NEED TO TAKE THE UNIT IN FOR REPAIR... THIS IS NOT A DIY REPAIR!!!!
Aug 23, 2011 | Behringer Rx 1202fx 12 Channel Line and...
EVERYTIME I PLUG IN THE UNIT AND TURN IT ON IT BLOWS THE 12 AMP 125 V FUSE INSIDE. REPLACED THE FUSE MULTIPLE TIMES WITH THE EXACT FUSE RECOMMENDED AND IT STILL BLOWS. THE UNIT IS ONLY 1-2 YEARS OLD. ...
The compressor has locked up and will not start...this is terminal and will cost more to replace it then the unit is worth...
unfortunately you will have to replace the unit with a new one...
heatman101
Jun 30, 2011 | Amana D545M Dehumidifier
12v outlet fuses keep blowing.
Faulty reciever ,,, Worth checking the plug assy for internal damage . Check that the sat receiver is within the power capabilities of the vehicles acessory plugs < 10amp .
Dec 23, 2009 | 2004 Ford Ranger
How do i wire a fusion 12'' active encloser up to my car?
OK. (1) The RCA's plug into your audio-In on your amp and the other end of your RCA's plugs into the back of your cd player's audio-out. (2) The small blue wire is the "Remote wire" the one end is wired together with a blue wire in back of cd player other end to amp..To attach wire "remove some of the rubber insulator on wire about a 1/2 inch then twist wires together and put electrical tape to cover or wire nut if you have one." (3) "Ground wire" this is the black wire one side to "amp - neg" and the other end to frame of vehicle. " find a bolt in trunk and put the end of the wire around that and tighten bolt" but before putting bolt on take sand paper to the metal frame where the bolt hole is and sand all the paint off! (4) Last Power wire the "red wire". Cut about 12 inches off power wire plug one end to "amp + pos" the other end to the fuse...Now with the rest of the Power wire plug the one end to the otherside of fuse and run that threw car either driverside door or underneath the dash to the "+ pos red" side of battery.
Then your done! Good luck! and wire in that order and you want blow anything! Give me a thumbs up if you like!
Sep 24, 2009 | Car Audio & Video
Psw1200 paradigm sub woofer
If your fuse keeps on blowing after you cg=hanging,that meens that there is a shortage.check it first using the multimeter.good luck.
Dec 28, 2008 | JBL PSW1200 Speaker
Blown fuse??
there is an underlying cause for the fuse to blow. if something shorts out you would rather a 40 cent peice goes then the unit causing a fire. disassembly is require... look for obvious burnt parts first.
Robert
Sep 01, 2008 | MTX SW2 Subwoofer
Subwoofer issues
The fuse blows when the current that passes through it are beyond its rating. This could be brought about by excessive consumption of the load, in this case the amplifier powering the sub-woofer.
Repairs would involve component level and require that you be familiar with electronic components and circuitry, use of a DVM and a soldering iron. Often it is just the finals that needs to be replaced. Of course we cannot discount the possibility of other components or section such as the power supply.
The smoke indicates something heating up such as a resistor or diode or a capacitor.
Should you be uncomfortable opening the unit and doing a DIY (do-it-yourself), then perhaps you need to seek the services of a qualified professional.
Should the downtime and cost of repair be no longer economically reasonable, purchase of a new unit might save you further trouble.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 23, 2008 | Onkyo SKW-200 Subwoofer
Cerwin Vega CLSC-12S Subwoofer Logo
958 people viewed this question
Top Cerwin Vega Audio Players & Recorders Experts
 Grubhead
Grubhead
Joe Lamb
Joe Lamb
Steve
Are you a Cerwin Vega Audio Player and Recorder Expert? Answer questions, earn points and help others
