Question about Baumatic Ovens
Hinge broken on baumatic double oven door can it be replaced
  • Baumatic Master
  • 3,463 Answers
Hi.
Yes it can, no ptob, but you will need to replace the pair, otherwise it will not close properly.
POlerase rate my solution.,
Thanks.
Posted on Jul 16, 2009
Front door as come away
Do yu mean the front door has pulled off it's hinges on one side or both ? if you hold the door on a angle about 12" open then press down towards the floor it will go back into place , if not you may have bent the hinges and the will have to be replaced
Dec 17, 2011 | Baumatic B904SS Stainless Steel Electric...
Repalce a broken door hinge on upper oven
you must remove side panel . if wall oven slide out on a table strong enough to support is during service . mm
Jul 16, 2010 | GE Profile JTP56 Electric Double Oven
Top oven door will not close..appears left hinge not working
The problem will be caused the hinge spring being broken or weak.
The only solution is to replace both oven door hinges to ensure a satisfactory repair.
Trust this helps with your problem.
Dec 15, 2009 | GE Profile JTP56 Electric Double Oven
The right hand side of the main oven has broken
You have not given much information to go on, but I am assuming that you mean the door hinge has broken.
If it is a drop down door, then you will have to replace the hinges as a pair.
If it is not the door that is the prob, then I need more information.
Thanks
Please rate my comments.
Nov 22, 2009 | Stoves 720EF Electric Double Oven
After 2 years, the hinges have already warped and broken. Can they be replaced, or will I need a new oven? Is this a problem with this particular oven?
Generally speaking, it is possible to replace the door hinges on the majority of ovens be they gas or electric.
Please leave feedback.
Thanks.
Nov 13, 2009 | Frigidaire FGB24T3EC Gas Double Oven
I need to remove oven door, cant figure out how
drop the door down as low as it will go look carefully at the hinges as they pass through into the oven chassis you will see a clip on each one that you lift up to lock the hinge you usually lift them up as far as they will go then this will lock the hinges as you close the door the hinges will come away from the oven complete with door.... reverse to refit.
May 06, 2009 | Bosch HBL 755 Stainless Steel Electric...
Baumatic 720 Double Oven - Door has come off hinge.
If you got to:
www.youtube.com
Then click on youtube videos, and in the search box type in: fitting oven door hinge, you should be able to get all the info you need to help solve your problem.
Please leave a fixya rating for my suggested solution.
Thanks.
Feb 07, 2009 | Baumatic B720 Electric Double Oven
I need a bottom door for an electrolux edb876 double gas oven
You will have to get a replacement from the mfr. It is not very difficult to replace, but can be time consuming. First before you buy one, make sure the hinge is broken and not just loose from the frame.
Feb 03, 2009 | Electrolux Ovens
My oven door will not shut tightly
Hi, I take it that this a whirlpool oven? Single or double oven? If it is a double your in luck! Your door hinges need replacing along with the inserts that are located inside the oven cavity. You can exchange the hinges and inserts from the oven doors and hinges if you have a double oven. If not get some new ones and fit them in! Easy job you will just need a little guidence as some models do differ..
Get back to me if this is usefull.....
Dec 30, 2008 | Whirlpool Ovens
Oven door does not close
I had the same problem. The first time the Tech. came out, put a new hinge in and it held until Nov. 07. ( 8 months ). Then the left hinge brakes when I opend the door and it crashes to the floor. Bending the right hinge and the metal doorliner. Jan.7,08 everything was fixed. On 1/11 after no more then 10 openings & closings the hinge broke again. This time I heard the crack of the braking metal after opening the door 2 inches. It now sits in my kitchen propped-up with a stick, waiting for the repairman. I am sorry I have no solution , but there must be a problem with the hinges. I forgot to tell you that it started with a door that did not close, like yours.
Ingrid
Jan 06, 2008 | Jenn-Air JJW8230D Electric Double Oven
Ovens Logo
238 people viewed this question
Top Baumatic Ovens Experts
ashburton
Andy Fraser
Andy Fraser
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
