Question about Brother HL 2140 Laser Printer
Cannot print i receiver an alert that says: printer currently offline. the printer is running. it has ink and paper. if i plug the USB cable into another printer i have no problems. could the USB port be dead? thanks
  • 1,511 Answers
Please restart your computer and then try again... it is usually due to this issue
also make sure that the lights on the printer are not showing any error or warning.
thnx and i hope this helps
please rate this solution
Posted on Jul 16, 2009
Cp1525nw appears offline
If the system is unable to detect the printer, it will put the printer in offline mode. In this condition you won't get any print outs..
1. chk usb cable
2. un plug the usb cable, un install the drivers, plug the usb cable & chk new hard ware found?.. if not there is usb port issue, chk system usb port/s are working or not.. if yes
3. Replace printer formatter assmbly...
This printer network unable printer, why cant use through network? instead of replacing the formatter assembly...
Jan 02, 2014 | HEWLETT-PACKARD CP1525NW Laser Printer
I can not get anything to print on my Epson NX420 using my IMAC. It says the printer is offline and I can't even print a test page. Can you help?
I'm assuming the printer worked previously from the iMac and now it does not. If you never had it connected, please add a comment to this effect, and include your OS version.
First, Open the Print Center (Printer Utility) and check the status of the printer. It may be listed as stopped. If so, delete any extra print jobs (additional attempts to print the page), then click the Start Jobs icon.
You can verify printer connectivity by clicking Add in the Printer List (if that is not visible, select Show Printer List from the View menu). Be sure to select either the USB or wireless network protocol connection. If the NX420 shows up, you have a good connection. In that case, click cancel and skip the next paragraph.
If you are printing via USB, check the cable (I sometimes forget to plug in my printer cable after downloading from my camera). If you are printing via your wireless network, check the status of the wireless connection from the printer.
Also, in the printer utility window, click the Supply Levels icon to verify that all of the ink cartridge levels are high enough to permit printing.
Are there any error messages on the printer display? A fault detection will take the printer offline.
Jun 22, 2011 | Epson Printer
Printer is offline and will not print. Restarting does not help.
When you double click the Printer and Faxes icon in the Control Panel you will see the printer that your computer is currently using. See.... if the printer image is clear it is online and ready to use, if its blurred then its in offline mode and cannot be use.
To correct offline printer.. some possible reasons is on the usb cable.. check if there is no open wire along the cable...Inserting the USB connector on the other usb slot of the cpu sometimes work just wait first until it is read.
If the printer is still blurred and offline after checking the usb connection, the 2nd thing to do is check the properties of the printer if it is set to offline mode. how? Double click your printer icon. It will display the print jobs window. Click on the Printer tab and uncheck on the "Use printer Offline". Cancel all pending print jobs, close the printer window and try again to print.
Aug 10, 2010 | Office Equipment & Supplies
Will not print.
Is the printer light on? Is the USB cable plugged in securely? Go to Control Panel --> Printers and see if your printer is listed. If its offline, right click on the icon and select "Use printer online".
If still it does not print, uninstall it completely and reinstall latest drivers. You will find the latest drivers on this website. Click on "Software & Driver Downloads" to proceed.
Jun 10, 2010 | HP DeskJet F380 All-In-One Printer
My hp deskjet 3745 wont print because it is off line. how do i get it back on line and for it to stay that way. this happens often.
hello lblb45. Under control panel - printers and faxes - doble click on your HP printer and you will see the status of the printer (either printer offline, out of ink, or out of paper, etc. Click on printer option on the top and unselect the "Use Printer Offline" option. That usually happens because the print spooler service looses connection to the printer at some point. Did you try with another USB cable or reinstall the drivers? I hope this helps.
Jun 03, 2010 | HP Computers & Internet
I can't get hp deskjet 600c to work with Vista. Am using a IEEE 1284 to USB cable. HP site states Vista driver will automatically recognize and install printer, but my computer does not. Print manager...
The drivers for the 600C should be there in Vista, it should directly install the drivers. Check if the drivers is not in offline mode, right click and turn it to online mode. If the drivers were installed automatically when you plugged the USB cable, then the USB cable should be good enough.
Jan 27, 2009 | Office Equipment & Supplies
Back again....please help
Try this. Go to Start, Printers and Faxes, right click on your printer. When the menu opens make sure there is NOT a check mark next to "Use Printer Offline".
Jun 18, 2008 | HP Photosmart C3180 All-In-One InkJet...
Printer will not print
From the Control Panel, remove all printers. Unplug usb cable. Reboot. Install drivers. Plug in usb cable.
Geno
Feb 24, 2008 | Office Equipment & Supplies
Hp deskjet 5650 inkjet printer
Click Start - Control panel - Printers & FAXES
Right click on the printer icon Officejet 5600 series -- Select properties - Click on ports tab - Change the port to USB virtual port.
Disconnect the usb cable from the computer.
1. Click Start
2. Click Run
3. Type Services.msc
4. Locate print spooler on the list, right-click and choose stop.
5. Again right-click the print spooler and choose start.
Reconnect the usb cable try printing.
Thanks.
Dec 22, 2007 | HP DeskJet 5650 InkJet Printer
Brother HL 2140 Laser Printer Logo
331 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
