Question about Refrigerators
There is a trench/drain on the back wall behind
Sub Zero 650 - There is a trench/drain on the back wall behind the produce drawer that collects water but does not drain. The water then leaks onto the surface below the produce drawer and eventually after a few days through the door seal and onto the floor. I don't know where/what the drain is supposed to flow into and whether that (whatever it may be) needs to be emptied.Any suggestions?
    Champion:
  • 363 Answers
If you can view to rear of the unit wnd remove the bottom panel, there should be a hose coming from the drain to a pan of some type. If it has clamps on both ends remove the tube, place a vessel under the top tube attach point of trench drain and test the trench drain, if water is flowing freely from the drain to the vessel then clean out the tubing and replace.
Posted on Jul 31, 2009
Does a sub zero freezer has a drain hole
Yes the drain is on the right side top of freezer. There is also a drain behind the drawer, center of rear wall inside the refrigerator.
Jul 30, 2014 | Sub-Zero 650 / O Bottom Freezer...
Refrigerator sub zero 736 TC water leaking under vegetable drawer
Usually from plugged evaporator drain tube.
remove all the drawers and unscrew the frame that holds the drawers. Free the the drain tube (need to unscrew the clamps that hold the tube to the back wall). Pull it up from the bottom hole where it drains into the pan and free it from the top drain pan. Most likely it\'s plugged with crap and fungus and yecchy stuff. Clean it out and reinstall it.
Jul 09, 2014 | Sub-Zero 650 / O Bottom Freezer...
Water is leaking out from the fridge floor onto the ground.
The drain pan in the back evaporates from the heat of the compressor. The freezer drain drains into this pan. If there is water under the bins it sounds like the drain is partially clogged and over flowing into the refrig section. But I need more info, like model , brand.
Nov 17, 2013 | Sub-Zero 700 Refrigerator Freezer...
Water is leaking and collecting under the vegetable drawer. I took out the drawer and saw that the plastic drain tube seemed clogged. But I can't figure out how to clean it or if this is the problem/
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 20, 2011 | Sub-Zero 650 / O Bottom Freezer...
Subzero 650 bottom freezer is pooling water under the veggie drawer
Check you your drain line behind the 2 bottom drawers. Most likely it's clogged. You can try snaking it out with a single foot wire. See if the water goes away from the trough.
Smith Brother Appliance Repair reviews
Apr 12, 2011 | Sub-Zero 650 / O Bottom Freezer...
Ice behind the high humidity compartment
You have clogged train which has frozen over. There is a factory kit to add a heater. You firrst might want to try and defrost the tube using warm water after your remove the ice. You want to make sure that water will flow down that trough and passed the tube. THe watere goes to a drain pan below.
Dec 02, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub Zero 632 leaking water
Had the same problem on the same model (632). Turned out to be a plugged drain tube on the condensate collection trough located on back wall of the refrigerator. Simply pull out the crisper drawer (the drawer below the lowest shelf) and you'll bee the trough. The drip tube can easily be plugged by a vegetable leak or grape, etc which had fallen into this trough. Hope its as simple for you as for us.
Sep 30, 2008 | Sub-Zero 632 / S
Refrigerators Logo
192 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
