Question about Waring WMK300 Professional Belgian Waffle Maker
My Waring Pro waffle maker does not heat up.
After 2 uses, my Waring Pro waffle maker does not heat up. The indicator lights are on but the unit does not heat up.
Jerseybob
  • 11 Answers
SOURCE: Waring pro waffle maker
I personnally just went through this.
If it is less than one year old, and you have the receipt, go to the waring site, and look up the nearest dealer for repair and bring it to them. They should be able to contact waring for you and get you a replacement.
My replacement had a silver body virsus the original black body. The shop told me they have yet had a customer repeat of this problem.
Posted on Apr 02, 2008
  • 7 Answers
SOURCE: Will not heat.
There is a thermal fuse inside the bottom half of the unit, enclosed in a white insulating sleeve. This appears to be the weak part of the circuit. A replacement can be found here on Amazon.com.
Posted on Sep 03, 2009
  • 7 Answers
SOURCE: Waring Pro Waffle Maker
There is a thermal fuse inside the bottom half of the unit, enclosed ina white insulating sleeve. This appears to be the weak part of thecircuit. A replacement can be found here on Amazon.com.
  • 121 Answers
SOURCE: Waring Waffle Maker no heat
Remove 4 Black Phillips Screws 2 on the front near the handle that flips Use a Good fitting Screwdriver These screws have a thread locker on them. They will strip the heads out if proper care is not used when removing them.Then remove the two screws at the rear of the Iron Just rear of the cooking surface. This will remove the chrome cover on the bottom of the cooking surface exposing the wiring. The thermal fuse is located under a section of insulation under a clamp held in by another Phillips screw.Do not cut or Damage the insulation. Gently pull it back exposing the fuse. After replacing the fuse, insulation ,Clamp and screws check to be sure the iron heats and cycles on and off and the ready light works properly. If it does not cycle the new fuse will blow . Good luck
Posted on Sep 24, 2009
Had same issue,found a looks like diode on the black wire leading to the heating elements.It is open circuited.Needs replacing.It is not a diode...maybe a voltage circuit protection device.It is crimped into the black wire under the sleeve clamped down near the handle.Going to radio shack to get a idea,replacement.
Posted on Oct 17, 2009
Diagram to replace thermal fuse in wmk 300 waring pro
The most common reason for thermal fuse failure is running the iron with the top open, especially when set to a higher number (longer cycle time) and/or not flipping the iron over at the strart of a cycle.
Keep it closed except during the 10-15 seconds needed when adding the batter or removing a waffle.
Thermal fuse 240C often available on ebay 4/$2 or Amazon 10/$7-$10
Feb 15, 2014 | Waring WMK300 Professional Belgian Waffle...
I have a wwm200sa waring pro prof belgian waffle maker that will not get hot. The power light will come on but it will not get hot. Why?
HELP WWM200SA IS WAY TO HOT I HAVE IT DOWN TO 1 1/2 STILL ALMOST BURNED CAN SOMEONE HELP ME THANK YOU VICKY
Aug 02, 2011 | Waring Pro WWM200 Waffle Maker
My Waring Mod# 150 Waffle maker went out in the middle of cooking a waffle and stopped cooking. The red light is on ,but the green light wont come on.
there is a thermostat in the waffle maker if its got over heated the thermosts will have cut out,, or burnt out?
Oct 17, 2010 | Waring WW150 Waffle Maker
Will not heat.
Aug 10, 2009 | Waring WMK300 Professional Belgian Waffle...
Jun 02, 2009 | Waring WMK300 Professional Belgian Waffle...
I posted the same problem (no heat) but may have found the answer. There is a component that cuts off the power if the unit gets too hot. My best guess name for it would be a "thermal fuse". If it goes...no heat. (located behind one the waffle grids inside unit..silver and black)(behind the other grid is what I believe to be a variable resistor that varies with heat..used to set heat levels in conjunction with the dial on the front of waffle maker)
When thermal fuse goes it needs to be replaced. BUT I WONDER
what caused the overheating? I will go down to Radio Shack and buy the "thermal fuse" according to the data on the old "fuse" and put it in...then ????waffles or sparks???
the old fuse has printed on it: sheng ping SPF240 TF240 Deg. Celsius 10 amps 250volts 073 and some symbols
Wish me luck
Feb 24, 2009 | Waring WMK300 Professional Belgian Waffle...
Waring Pro Waffle maker
Just spray the grids before each use with something like Pam, or put a thin coat of oil on them. I found it's better to spray before each waffle so it won't stick.
Feb 21, 2009 | Waring WMK300 Professional Belgian Waffle...
No heat on brand new Waring WMK300 waffle maker
Lots of appliance makers include a 1 800 number with the paperwork that comes with an appliance.
I would try to find that number and call them. They owe you a replacement unit. If you can't find the number do a Google search for Waring and they should have a tel number and/or a "contact us" place to send and email.
Good luck Loringh
Sep 21, 2008 | Waring WMK300 Professional Belgian Waffle...
Waffles stick in unit
If you add a 1/4 cup of melted butter or margarine to the waffle mix, they do not stick, mine don't stick at all. There is also a recipe using yeast, butter, etc, that makes excellent waffles, and they do not stick.
Aug 09, 2008 | Waring WMK300 Professional Belgian Waffle...
Waring WMK300 Professional Belgian Waffle Maker Logo
196 people viewed this question
Top Waring Kitchen Appliances - Others Experts
Colin Stickland
Colin Stickland
Shehu Pro
Shehu Pro
Are you a Waring Kitchen Appliances - Other Expert? Answer questions, earn points and help others
