Question about RCA R52WM24 52" HDTV Projection Television
How to hook up dvd player
Tried to hook up dvd player to back it dont work what am i doing wrong
  • Jason Johnson May 11, 2010
    What type of connection are you using? Did you switch it to that video input from the TV/Video button? Did you pick the correct output on the DVD player? Lots of questions we need more info please.
2 Suggested Answers
  • 34217 Answers
SOURCE: RCA DRC247N DVD Player No Audio
The separate DVD player has three output cables: video (yellow), right audio (red) and left audio (white?). These connect to the corresponding inputs on the TV. If your cable box also has three similar output cables, you probably do not have a second set of inputs on the TV so what to do? You can purchase three Y adapters that combine two female RCA connectors into one RCA plug and plug everything into your one set of connectors on the TV. However, if your cable box output connects directly to the TV antenna input, the solution is simpler. Post a comment if this approach is not going to work
Posted on Oct 13, 2012
Oct 13, 2012 | RCA DRC247N DVD Player
Do not know how to get regular T.V. hooked up to this system
try using the red White cables from back of tv to back of dvd player/receiver. Do the same with DTV/dvr or cable box. not sure if cable box has red and white cable outlets, however the DTV-DVR does, The quick patch is from TV to back of dvd (input audio)side,....that should work
Sep 26, 2009 | Coby DVD-937 5.1 Channel DVD...
you dont have to use the dvd inputs if you dont want to , you could use AUX if you have it or any other unused input at the back of the amp
Jun 05, 2009 | Marantz SR7500
Uv8 some seakers dont work in dvd/cd mode
You have the wrong wire hooked up to turn on your amplifire. You used the blue wire but need to use the Blue/White wire!! That is an amp turn on wire Thje blue one is for a power antenna and goes dead when you put in a disc. The tweeters play because they are hooked direct to your Jensen. You'll be jamming in no time.
Larry T
Winona Lae
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html IN
Jan 26, 2009 | Jensen VM9510 Car DVD Player
Can't get picture on TV.
If you were using RCA cables, you may have had them hooked up wrong. I know this may sound like an easy fix, but I still hook them up wrong from time to time. Especially if there are more than one set of RCA hook-ups on the back of the unit. If you were using a S-video cable you shouldn't have to use RCA cables, if you had both hooked up that could cause your DVD/VCR unit to not work properly and only get a partial feed to the TV. I hope this helps a little. Good luck.
Jun 17, 2008 | Gateway AR-230 DVD Recorder
Dvd/tv hook up
plug in dvd player direct to tv yello red white for sound into a input ok vidieo one ect then change input on tv to that input ch2 hit ch down to go into inputs
Feb 10, 2008 | Sanyo DS31590 31" TV
No sound from my clarion vrx755vd
I have a 7in in dash dvd player but it does not want to play cds or dvds. it gives me an error notice. it won't even eject the cds. Where can I fix it?
Thanks
Dec 14, 2007 | Clarion VRX935VD Car DVD Player
Make my dvd work
 Did you hook up the wire harness correctly? Because you are not receiving power to the monitor. check these connections again. Maybe you have the wrong harness. Are you using the one from your car or DVD player? Did you splice the wires together? Do you have a correct color scheme to your vehicles wiring?
you may also need to bypass the monitor in order to view the screen while driving (if you're a rebel against johnny law)
Oct 29, 2007 | Pioneer AVIC-D3 Car DVD Player
Dual Screen not working
I`M TRYING TO HOOK UP THE OTHER SCREEN THE DVD PLAYER PLAYS FINE BUT I CANT HOOK UP THE OTHER SCREEN TO IT HOW DO I HOOK IT UP
Aug 13, 2007 | Power Voice System Venturer PVS1988...
Having trouble hooking up my DVD player
Try looking on your tv's menu for "input" or "input select". This should allow you to switch to your front AV inputs. If that doesn't work hook into the coaxial cable in the back of the set (the one for your cable or satellite input. Plug the cable from the output or to tv side of your reciever into the input of the dvd player and run another lenghth of coaxial cable from the output of the dvd player to the coaxial input where your satellite or cable was plugged into the back of your set. When you want to watch a DVD just turn on the DVD player and the picture should come up. When you turn it off your satellite or cable should come right back.
Feb 20, 2007 | Durabrand DWT1905 TV
RCA R52WM24 52" HDTV Projection Television Logo
26 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
