Question about Toshiba DKT2010SD Phone
The speaker function will not work on phone. Swapped out phone with one that worked on a different ext., when plugged in the speaker function did not work. Model #DKT2010-SD
    Sergeant:
  • 277 Answers
Increase the caller volume in call settings,if persisted unscrew it and service it with methelated fluid,soft mouth brush and reading metre totest component.
Posted on Jul 16, 2009
  • femi john
    femi john Jul 16, 2009
    increase the caller volume in call settings,if persisted unscrew it and service it with methelated fluid,soft mouth brush and reading metre totest component.
How to divert calls
You can forward all to another extension or to an outside number. You can also forward busy/no answer to both of those, but then it'll cancel your busy/no answer to voicemail. Speaker 41 plus ext or 9 plus outside number will set CF ALL, speaker 43 will set CFBNA, 42 and 44 to cancel. These are the default codes for NEC pro II, Elite, and IPK. The DTP phone also works on other systems that have different codes.
Jul 23, 2014 | NEC Dterm DTP 16D-1 Corded Phone
Spr-69 crackling
It may be a bad voice coil. It would make that type noise. If the cone isn't cracked its the coil.
Jan 25, 2014 | Alpine Type-R SPR-69 Car speaker - 100...
Ext in problem
if you are using the ext in then it has to be something wrong with the setup from the pc. The receiver does nothing to the ext in input except amplify it and put it out to the speakers.
Jan 14, 2014 | Denon AVR-1907 Receiver
Hi. My computer says I ejected my WD My Passport external drive but it was not properly ejected. How can I fix this. I need all my thesis files but computer can read the external drive! Help please!
Try to test your WD Ext HDD to a different computer and check if you will get the same problem.
If the same problem persist try to use a different cable for your WD Ext HDD.
If still fails kindly ask the store where you bought the WD Ext HDD on how to retrieve your files and have WD EXT HDD replaced?
If your WD Ext HDD works to a different computer then update the BIOS and Chipset of the computer where your WD Ext HDD connected previously.
Hope this helps.
May 29, 2011 | Computers & Internet
On my tecknics surround receiver only one rear speaker works. im getting 6.6 ohms out of the good one and 2.1 ohms out of the one that is bad. do i need to buy a new receiver?
Ohms readings in that range are generally speaker values. If you're getting vastly different readings between the two rear >>> speakers <<< why would you suspect that means you have a receiver problem?
It sounds more like one of the speakers is partially blown.
Have you swapped the speakers with each other to assess the amplifier's function?
Mar 29, 2011 | Audio Players & Recorders
Cannot get sound from center SL and SR speakers...FL and FR speakers and sub work fine...
find the menu on the reciver. there will be adjustments for each speaker. if not that. change it to a different sound setting like cinama,rock,surround,movie,ext. try each one differ setting use differ speakers
Feb 10, 2011 | Denon AVR-4800 Receiver
HP office jet 330 printer works and copy machine works but it will not fax. Plug a little loose but I plugged it in all the way. No dial tone, please help.
stick a normal phone to wall socket, do we have tone? ...... Ensure you are plugging in to correct socket ie line/phone not ext. on the HP. Try different cable but all depents on my first question?
Nov 04, 2009 | HP Office Equipment & Supplies
Problem with callback function
hi,
u've to reset ur phone.
go to this link PDF's 81 & 82 pages && follow the guidelines.
http://support.avaya.com/elmodocs2/4610/233784_2_2.pdf
Sep 18, 2009 | Avaya 4610
Bose 901 mk11 no sound . i have checked all connections, swapped speakers over.
since that u swapped l/r speakers already,it might not be ur speakers,if u wanna make sure ur 901s are working,feed a 1.5 v battery power to ur speakers,,(device a connector,piece o wire ,etc) if the speakers makes ticking sound upon contact,u got continuity.now..ur eq..make sure it its working,,(see instruction manual)lastly..confirm that ur amp which is powering ur 901s is emitting sound.(hook up a different speaker)
Apr 14, 2009 | Bose 901 VI Main / Stereo Speaker
Tv not playing sound on my surround system
Check if the tv has an option in setup to turn ext speakers off.
If so turn them back on.
Hope it helps.
Nov 26, 2008 | Televison & Video
Toshiba DKT2010SD Phone Logo
145 people viewed this question
Top Toshiba Lands Phones Experts
george  peters
george peters
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
