Question about RCA DRC8300N DVD Recorder/VCR
Shut down and displays "FSV" or "F5V" dialog and get paralysis!
I have the same apparatus by RCA DRC8320N to repair for a guy and it gets an error message as "FSV" or "F5V" and the device shut down! Absolutely nothing is available, is appears completely paralyzed! - Once plugged in the AC outlet, it displays the welcome and "PLS wait" dialogs and shuts down displaying this "FSV" or "F5V" dialog ! What this means and what to do to get the system on?
Thanks for your help!
LHUPA
GSAN
  • 106 Answers
SOURCE: rca drc8030n hello
9 out of 10 the Hello problem lies in the DVD-RW board (I replace this board to correct the problem) and that 1 out of 10 time the problem lies in the main board that the IDEs connect to. I have replaced this board as well to correct such problem. I understand that these spare parts are impossible to come by. If you can make sure that the DVD-RW is fine by hooking it up to your PC and reading from it, then I can send you an RCA DRC8030N with the Hello issue that originates in the DVD-RW (so you can swap out the main board that connects the IDEs) and still have extra parts for later possible problems. If interested, you can contact me via triple w.suncitybargains.ecrater.com Thanks.
Posted on Jul 25, 2008
SOURCE: RCA DRC8320N Appears Dead
a friend of mine asked me to look at his DRC8320N. i found this page, noticed the comment about C232, so i replaced it. it worked!
thanks!
Scott
Posted on Oct 20, 2008
SOURCE: drc8320n rca dvd recorder
This unit appears to have a faulty power supply module. Poor design. I have the same problem with different caps needed to be changed then those suggested by guest Oct 08.
Posted on Nov 10, 2008
SOURCE: drc8320n vcr dvd combo says hello and pls wait over and over
Replacing a simple capacitor on the power supply just brought my unit back from what I thought would be the junk pile....
Read this.
Yes you can do this yourself....
http://forums.afterdawn.com/thread_view.cfm/707232
Posted on Feb 01, 2009
umasatish
  • 3 Answers
SOURCE: When turned on stays stuck in Hello mode and nothing works.
You cant solve this problem . This is internal problem . So you first contact the experienced mechanic. do first
Posted on Jun 02, 2009
My DVD Recorder & VCR (DRC8320N) has Hello on display
Even though the power light may be off the unit is still on. It will be warm on top. Unplug the unit for 30 minutes and plug it back in, that will usually reset it.
Dec 03, 2009 | RCA DRC8320 DVD Recorder/VCR
Need an English language user manual
http://www.curtisint.com/web/browser.asp?productID=DRC8320N&catName=&brand=RCA&manual=DRC8320N
If you click the link above it will take you to the download page, just click on the link for english
Hope this helps FixYa
Chris
Apr 30, 2009 | Televison & Video
Hello?
Symptoms
The unit's remote control and front panel buttons act completely dead. The unit locks up after displaying "hello" on its front panel and refuses to do anything more. In other cases, the front panel display appears completely dead. In this instance, the unit will display "Interface error" or "Interface error! Turn off the power" on the television screen and do nothing more.
In all cases, if a DVD or VHS tape was inserted just prior to the failure, you won't be able to remove either from that point further. They'll remain stuck inside the unit until you've completed the repair contained in the guide below.
Critical information you need to know immediately
If you haven't done so already please unplug the unit's AC power cord and leave it that way until you're ready to begin the repair. Taking this action will guarantee no further extensive electronic or mechanical damage can occur.
Under no circumstances attempt to remove anything stuck inside the unit until the repair has been completed. Should you attempt to do so you'll almost certainly damage its ultra-delicate DVD and VCR mechanisms which are very expensive to replace!
Once the necessary electronic repair has been completed, you'll easily be able to remove them in the customary manner without any problem whatsoever, by simply pressing the EJECT or OPEN/CLOSE button.
Why your unit has recently failed
The cause of all the above symptoms are entirely due to an inherent manufacturing defect in the unit's internal power-supply board, all of which will ultimately fail due to one or more defective capacitors contained on it.
Known brands and models affected
Audiovox DVDVCP01
Durabrand DBDVR01
LG RC797T and RC897T
Memorex MVDR2100, MVDR2102, MVDR2102A, MVCD2102 and MVCD2102A
Panasonic DMR-ES15, DMR-ES30V, DMR-ES35V, DMR-EH55 and more
RCA DRC6200N, DRC6355N, DRC8030N, DRC8040, DRC8052N
RCA DRC8060N, DRC8295N, DRC8300, DRC8300N, DRC8310N
RCA DRC8312N, DRC8320N and DRC8335
...plus many others not yet identified - please contact me if your's isn't listed above
Completely restore the unit yourself in under 20 minutes for just a few dollars
This simple repair doesn't require any prior knowledge or experience with electronics, takes less than 20 minutes from start to finish and typically costs between $1.59 and $5.00 for the replacement parts obtained from your local Radio Shack. All that's involved is simply replacing one (or occasionally just a few more) defective capacitors on the unit's internal power-supply board which are most often running painfully hot to the touch.
The repair guide is provided to anyone who needs it simply upon request
Upon discovering the massive quantity of Chinese manufactured combo recorders having this inherent defect, in addition to the callous manner RCA Thomson and other manufacturers were leaving their loyal consumers out in the cold whose units had completely failed thru no fault of their own, it so enraged me I was compelled to fight back. That was just 3 short months ago and the day this Combo Recorder repair brief was born.
How do I obtain a copy?
Just send an email to my public address provided below. Please include your brand and model followed by "repair brief" in the SUBJECT line. For example, "RCA DRC8335 repair brief" and I'll send it using my private ISP address as soon as possible. Email your request to mikeadams110@yahoo.com
Why don't you just post the repair brief directly on Fixya?
Due to the dynamic nature of its content, the repair brief's constantly being updated on nearly a daily basis, as new information becomes known that wasn't previously. Unless the repair brief is kept at one centralized location, it becomes impractical to manage and keep up to date. Many of the DIY repair forums like Fixya don't even provide the author any way of updating their prior submissions.
Why are your posts often so long?
They're whatever length they appropriately need to be. Nobody likes having to read a long post until it happens to be the one supplying the ideal solution to their problem--in which case it's never long enough!
Can I really do this repair myself?
Over 1,000 combo owners just like you have successfully restored their units using this DIY repair guide during the past 90 days! Below is a tiny handful of the nearly 1,000 follow-up messages I've received to date. Ann's follow-up message is an excellent example demonstrating how new strategic information is provided by your direct feedback and why it's essential the repair brief's kept up to date.
December 27, 2008 received by email from Ann M.
Just like John H, my problem was also capacitor C226, but in my case overheating wasn't the give-away here. Instead, I noticed the bottom of the capacitor appeared melted a little and the top looked like it was slightly bulged. I removed the damaged capacitor and replaced it with a new one rated at 35 volts and now my DRC8335 is working perfectly again!
December 15, 2008 received by email from Mike J.
Mike. Just recently discovered the link to your repair brief posted on AnswerBag and wanted to let you know my previously dead DRC8320N combo recorder is now working perfectly again! Even though I'd never worked with electronics before, following your excellent instructions made the task easy. Bless you for having saved me a pile of money.
December 7, 2008 posted by TinyPeanut on AnswerBag
What Mike says works! My nephew went to Fry's Electronics store in California and got the part he suggested, in our case a 1,000µF 50 volt electrolytic capacitor as that's what they had on hand. He and my brother soldered it in and now my DRC8320N combo's working perfectly again! Thanks so much.
December 04, 2008 received by email from John H.
Mike. Thanks for providing this excellent DIY repair guide. My RCA DRC8335 is now performing perfectly again! In my case, the failure was caused entirely by capacitor C226 which I've just upgraded to 35 volts as advised, purchased from Radio Shack. Thanks again.
December 04, 2008 received by email from Glen
Dear Mike. Simply awesome, my DRC8320N combo's now fixed thanks to you! The only thing remaining I need to do is replace the VCR drive belt so its drawer will lock into place properly. Feel free to share my joy. Thanks again for all your help.
November 25, 2008 posted by Norstar448 on Fixya
I printed out Mike Adam's solution and phoned 2 electronic repair shops who refused to listen to how my machine could easily be repaired. The third said to bring in the info and my machine. He quickly located the part and replaced it and my machine is 100%. Thanks Mike!
November 14, 2008 received by email from Brandon
Mike. Since I last wrote, I've already taken my DRC8320N recorder apart, replaced capacitor #C232 and it's now working great! I repaired it myself without any electronics background or having done anything like this before. It really felt rewarding after putting things back together and plugging it in, to discover everything was working perfectly again.
Dec 28, 2008 | RCA DRC8335
Dead power supply.
Faulty power-supply symptoms:
The front panel display and buttons are completely nonfunctional and appear dead. The unit will do nothing more than display the following messages on the TV screen:
Interface error
(and or)
If a DVD or VHS tape was inserted prior to the error occurring, you won't be able to eject either from that point further. They'll remain stuck inside the unit until you've completed the repair detailed below.
Interface error! Turn off the power <--- explains how to completely restore your combo in less than 20 minutes by replacing a $1.59 part on the power-supply board. mikeadams110@yahoo.com
Nov 17, 2008 | RCA DRC8300N DVD Recorder/VCR
RCA DVD/VCR model DRC8320
Interface error
(and or)
Interface error! Turn off the power <--- explains how to completely restore your combo in less than 20minutes by replacing a $1.59 part on the power-supply board. mikeadams110@yahoo.com
Jul 15, 2008 | RCA DRC8320 DVD Recorder/VCR
For units with no functions, appears dead, power supply gets a leaky capacitor in power supply. Designator #C232 on pc board. It is a 1000uF 16volt capacitor that needs to be replaced.
Dec 03, 2007 | RCA DRC8300N DVD Recorder/VCR
Dvd Recorder+VCR Combo Model#DRC8320N
CALLED 1-866-775-0976..WAS ADVISED IF PURCHASED LESS THAN 1-YEAR AND HAVE RECEIPT..SEND MODEL DRC8320N..TO: VENTURER ELECTRONICS..203 EGGERT ROAD..BUFFALO, NEW YORK 14215.....FOR REPLACEMENT PRODUCT....ANDREW REP..STAED THAT RCA WAS BOUGHT OUT BY AUDIO BOX COMPANY....SENDING MINE..GOOD LUCK....FROM : AFM1PGE.COM...GOOD LUCK!
Sep 12, 2007 | RCA DRC8300N DVD Recorder/VCR
RCA dvd-vrc combo model DRC8320N
RCA MODEL DRC832ON..NEED REFERENCE # FROM SUPPORT TECH 1-866-775-0976 TO REPLACE PROCUCT..RAC SOLD TO AUDIO BOX..SEND DRC8320N TO: VENTURER ELECTRONICS, 203 EGGERT RD, BUFFALO, NY, 14215..WHEN YOU RECEIVE REF #..NEDD TO HAVE RECEIPT FOR PRODUCT LESS THAN 1 YR FOR WARRANTY TO BE EFFECTIVE
Jul 23, 2007 | RCA DRC8300N DVD Recorder/VCR
StorStation fails to boot up - blue screen of death
The beeping alarm could have been overheating. You could try taking the HDD out and putting it in a workstation to run chkdsk on it. Incidently what operating system does this model use? I have an FSV-E1 which seems to run some Unix type system.
Feb 20, 2007 | Sony StorStation FSV-M1 120 GB Hard Drive...
RCA DRC8300N DVD Recorder/VCR Logo
138 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
