Question about HP LaserJet P3005 Printer
How do i change the fuser?
How do i change the fuser for the hp laserjet 3005?
    Problem Solver:
  • 13 Answers
CAUTION: Fuser may be hot. Turn off printer, unplug it and allow it to sit for 20
to 30 minutes before performing these maintenance procedures.
Fusing Assembly Removal and Replacement
1. Remove Back cover:
a.) Open the face up delivery door and press the door down to disengage two door stops
b.) Remove the two screws just above the door stops
c.) Swing the bottom of the cover out first, and then the top
2. Remove I/O cover:
a.) Rotate cover to clear the tabs on right side of cover
3. Remove fusing assembly:
a.) Disconnect black cable above main power cord receptacle
b.) Disconnect two cables on left side of fuser
c.) Remove duplex inlet guide (below fuser) by lifting two locking tabs
d.) Remove four screws from each corner of fuser
e.) Pull fuser straight back
4. Reassemble in reverse order
I have done 15 service calls on these printers
Posted on Jul 27, 2009
  • HP Master
  • 19,396 Answers
Click here and follow instructions HP_Color_LaserJet_3000_3600_3800_Service_Manual.pdf
Posted on Jul 16, 2009
  • Ginko
    Ginko Jul 19, 2009
    I gave you the full repair manual for your printer and you gave a bad rating, well thanks.
    Instructions are at page 31 on manual.
    By the way, let the printer unplugged for one hour and ensure that the fuser is not hot, then do the following:
    Open upper top cover.
    Press the two blue tabs.
    Turn the old fuser cartridge up and pull it out.
    Put in the new cartridge and close the cover.
    I will be grateful if you can change the bad rating given.
    Thanks.
  • Ginko
    Ginko Jul 28, 2009
    I will be grateful if you can change the negative rating given for the free advice.
    Thanks.
    Scholar:
  • 124 Answers
3 Suggested Answers
venexcsd
  • 1185 Answers
SOURCE: need teflon for HP laserjet 3005
www.hp.com seems to be the place to start looking for OEM parts
Posted on Jun 12, 2009
SOURCE: MY HP LASERJET 3005 DISPLAY ERROR 49.2F9D
what
Posted on May 27, 2010
HP 3005 MOVING TONER TO ANOTHER 3005
Sure.... never should be a problem.....Each toner cartridge has a memory card and informs the printer of the amount of toner left.
Dec 07, 2011 | HP LaserJet P3005 Printer
Printer hp laserjet 3005 error 57.05 plase.
Thank you for contacting FixYa with your printer error.
This error indicates a Printer Device Fan has error has occurred.
HP troubleshooting steps include:
Feb 15, 2011 | HP LaserJet P3005n Printer
My HP Laserjet 3005 has faint print on the righthand side for at least the first 2". I have fitted a new toner but this has made no difference. Could this be the fuser unit?
If it happens even after replacing the toner cartridge or if you current cartridge has enough toner, it is most likely be due to dust at the laser reflecting mirrors inside the printers, which partially blocks laser beams and requires cleaning/ servicing by a professional.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 29, 2010 | HP LaserJet P3005 Printer
HP-LASERJET PRINTER PROBLEMS   HP-3005 NO PROPAR PRINT OUT      NOSE PROBLEMS
Check one of the followings:
Paper jammed anywhere visible? Rollers, etc?
All the trays are closed properly?
Toner, Drum Unit or the Fuser Unit don't need changing?
See if you can print out the Printer Status of the Printer from it's menu which would give you some statistics of what needs to be replaced etc.
Contact your HP Dealer nearest you to fix that problem, it could still be under warranty so there'll be no added cost to you.
All the best!
ramatau
Jan 29, 2010 | HP LaserJet P3005n Printer
Hp laserjet 3005 making loud grinding sound when inialising
The problem is the fuser and gears associated it with it.
The mose common solution is to replace the fuser assembly as well as the 4 gears inside the unit where the fuser touches those gears.
This solution works about 85% of the time.
thanks adi
Jan 26, 2010 | HP LaserJet P3005n Printer
Need teflon for HP laserjet 3005
Jun 12, 2009 | HP LaserJet P3005n Printer
Noise form hp laserjet 3005
The gears that drive the fuser assembly are worn out, after replacement grease heavily
I think the part #s are RL1-0077, 78 & 79
Jun 11, 2009 | HP LaserJet P3005 Printer
Its already discussed in one of the forums for Hp.
check :-
https://forums11.itrc.hp.com/service/forums/questionanswer.do?threadId=1158526
Thanks
Jun 04, 2009 | HP LaserJet P3005 Printer
HP LaserJet P3005 Printer Logo
2,043 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
