Ohh,good news,Abctay.com is a Sharp tv parts online store,SHARP RUNTKA903WJQZ QPWBS0398SNPZ(1Y), PSD-0863 POWER SUPPLY BOARD
https://www.abctay.com/original-sharp-runtka903wjqz-qpwbs0398snpz1y-psd0863-power-supply-board-p-1087.html
Check out the links below to eliminate the Inverter circuit
and / or LVDS board
Instruction for LT30FMP
Take a look at the site, sounds like your inverters bed
http://www.shopjimmy.com/lg/50ln5100-ub
I’m happy to help further over the phone at https://www.6ya.com/expert/joshua_ac64e182ed26f66d
SOURCE: lg led tv backlight
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
SOURCE: How can I get my backlights to work on Samsung LCD tv
If your not a TV Engineer , get one to look at it , as you may keep changing the incorrect part.
SOURCE: LG 50LN5700 TV. Why does it have a picture but no backlight?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
SOURCE: 47' (sic) LED TV, model number m470vse. Why doesn't the backlight work?
SOURCE: why is my T.V. loosing backlight but not sound?
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Testimonial: "thanks for your response but as I stated in my description I have replaced the power supply board and the inverter board with no success. so basically you are confirming my question that the main board is the issue? the tv does not shut down the backlights when I use the VGA input only through the HDMI inputs. seems like for some reason when a program/movie changes to a different screen, a blackout frame, the backlights turn off and don't recover."
