Mintek Tv + built-in DVD player Display not working
My Mintek LCD Color TV & DVD Video Player ( Model: DTV-173 ) videohas stopped working. The sound works fine but with no Video, this tv has no use.
When I turn on the TV, it first makes a light ( Black screen to a grey-black screen) but that is all that happens. The menu options does not appear.
Benimur
  • 6966 Answers
SOURCE: Hooking up a DVD player to a Quasar TV/VCR Combo
Yes, for a workaround. The adapter would be 2 RCA female to 1 RCA male. You have to connect both the red and white to the female RCAs and use the male to connect to the TV's Audio INput. The yellow goes to the video. There should be no negative technical effect other than lost of stereo quality. The audio output of the DVD is line level and could normally tolerate this condition.
The correct method is to use a simple line level audio mixer and mix the L& R audio signal to produce a mono signal or to use a stereo amplifier for the sound output.
Hope this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Nov 07, 2007
SOURCE: DVD plays only in black & white
Try turning on component (cable) for the V2 input  on your TV
Posted on Jan 08, 2008
SOURCE: Users manual
i
i am looking for a power adapter and remote control
23" LCD TV modelo DTV - 233
Posted on May 05, 2008
Shuttle83
  • 1139 Answers
SOURCE: polaroid lcd tv w/ built
This denotes a problem with the power supply for the unit. This may be as simple as removing the power board and replacing it or as complex as repairing the board itself. Repairing the board would be the cheaper option, but In either case I would suggest that you let a qualified TV technician perform this task, due to the possibility of electrical shock hazards.
I hope this helps,
Shuttle83
Posted on May 27, 2008
  • 218 Answers
SOURCE: Black box in middle of screen
It's a text box for either closed captioning or demonstration mode. Go into the setup menu and turn off closed captioning. If you have trouble doing that, then just restore factory settings.
Posted on Mar 07, 2009
My Mintek tv is on the blink. The "video menu" popups every 5 seconds on the screen and I canNOT get it to stop. Please help!!
Stuck button on the remote or the TV is the most likely cause. Take the batteries out of the remote and see if it stops. If not, check the buttons on the TV itself to see if any are stuck down, or show signs of getting wet.
Jun 16, 2011 | Mintek DTV-173 17 in. TV/DVD Combo
Mintek DVD LCD combo
There's nothing you can do. The DVD unit and the TV are both controlled by IC2 bus lines that work together. You will have to have the unit repaired or invest in another set. My recommendation is " Never buy a TV with a built in DVD player". They do not last. That is from a professional stand point.
Sep 09, 2009 | Mintek DTV-263 26 in. LCD Television
Parental Control Lock keeps blocking
I have the same tv and the only way to stop it going in to parent safe mode is to get a better signal or use a external source (Digital tuner, Cable box, etc.)
Dec 20, 2008 | Mintek DTV-173 17 in. TV/DVD Combo
I believe I broke the antenna connection on my Mintek TV.
Definitively you broke the connector. Look in the internet the web site of Mintek. But since for a technician is not a big deal to fix, you can take that TV to ANY repair service, because is very easy to do it. I strongly recommend that.
Nov 20, 2008 | Mintek DTV-373-D 37 in. LCD HDTV
Dtv-173
Hi
tell me ur model no and brand so that we can help u clearly
thank you
Oct 12, 2008 | Mintek DTV-173 17 in. TV/DVD Combo
Mintek dvd player, model mdp-1030
Mintek MDP-1030 DVD Player Description:Mintek is one the largest suppliers of DVD players in the global marketplace today. Mintek has taken the next natural step in the evolution of the company's product line combining leading DVD technology with state-of-the-art LCD technology.PRODUCT FEATURES:
Versatile playback formats;
Anti-shock function - mobile or pedestrian;
Built-in stereo speakers;
Auto power off for saving energy;
Quick connect to TV;
Digital Coaxial Output;
AV input/output;
Brightness/Color/Display mode adjustment;
High capacity rechargeable Lithium-ion battery pack;
Full function remote control.
Product Specification: DVD Player DVD Type DVD player Media Supported Kodak Picture CD, CD Portable Yes Form Factor Portable Remote Control Remote control Additional Features Auto power off Audio Features Audio Output Stereo MP3 Support Yes Connectors Composite Video Outputs 2 x headphones ( mini-phone stereo 3.5 mm ) 1 x digital audio output (coaxial) 1 x composite video/audio input 1 x composite video/audio output Power Battery Type 1 x DVD player battery - rechargeable - lithium ion General Product Info Weight 4.6 lbs Also known as Mintek MDP-1030, Mintek Manufacturer Part No. MDP-1030 Company Info Mintek Dimension 1.6 in x 10.1 in x 6.6 in (HxWxD) Model DBMDP-1030
Aug 17, 2008 | Compaq Presario Notebook
TV w/ built in DVD
Hi maybe this might work on your dtv,try load a post card the size of a dvd and hold it in then try the source button to change to tv mode.It worked on my dtv-265-d now all i need is to get a remote control.
Aug 09, 2008 | Mintek DTV-263 26 in. LCD Television
Replacement remote control
Try the web site: http://remotes.com
Your TV remote is listed for $34.99 plus shipping. Just enter Mintek in the search box and click on your TV model number (DTV-173).
Good Luck.
Feb 06, 2008 | Mintek DTV-173 17 in. TV/DVD Combo
Open Questions:
I'm hoping to get some clarification as to whether the below is correct or whether I have been taken for a ride. My LG was picked up by a repair service because it started displaying horizonal lines with the picture hazily in the background. I undertook some research and learned that in most cases of the boards needed replacing and it wasn't a panel issue (usually panel issues are associated with vertical lines). After having my TV for 5 days the repair service advised that it required a new power board and a small repair required on another board. They repaired the small repair and I was going to purchase a new power board however the TV has been returned to me dead. It now doesn't even turn on. The power/channel/indicator lights at the bottom flash on then switch off automatically. After getting consumer affairs involved, I finally received a call from the sub contractor and aside from a number of different excuses given based on my questioning of each explanation, all were contrary to the initial diagnosis discussed with me in early June. I documented the conversation which I summarise as follows: - he contacted numerous times however I never received any voicemail. I asked why - after "numerous phone calls" he didn't send a txt msg to which he replied that he's not allowed to send messages. - he initially alleged that the power board was repaired and video board needed replacing which I was quoted for. I corrected him advising that I was told and quoted for a new power board ($530) and the video board was to be repaired. He then changed his story agreeing with me and alleged that found and apparently quoted me $445 for a generic power board but I declined....Just to clarify, I never received this 2nd quote which is evidenced within the emails and messages I sent after receiving no response over a number of weeks. - he continued to claim that the TV now has panel problems and is now not repairable. - I recited the discussion the owner had with me which was consistent with the information when he provided me with the original quote of $530. He then altered his story replying that "this is a rare case... The owner doesn't know what he's saying". - When I challenged why I was quoted for a power board when he is now claiming there are panel issues, his response was that a new power board was to test if the panel was cracked!! - I replied saying that the TV was delivered to them with horizontal lines and even after testing should've been returned with horizonal lines however is now dead. - his excuse changed again advising that during testing he short circuited the TV and replacing the power board would continue to short circuit the video board..When I again questioned WHY then was i quoted for a new power board (as per the owners conversation with me) he returned back to stating that it was a rare case! - I told him about the screws missing in the back panel to which he commented that "they" wouldn't have put them back in because "they" assumed I would just dispose of the TV. What I find interesting is that this was his understanding whilst I was led to believe the TV was repaired (pending a new power board). It now makes sense as to why the driver who delivered the TV literally dropped it off and ran advising that he didn't know anything. I never received a service report and asked for it again however am yet to see it. Based on this information, can anybody shed light on what they've done to the TV? Prior to them taking the TV the horizontal lines were consistent with had a faint picture in the background and didn't alter at all. They're claiming that they did nothing and the TV - claiming that the reason why the panel doesn't turn on is because it was kept on while they were testing.
Sep 25, 2017 | LG Televison & Video
Televison & Video Logo
106 people viewed this question
Top Televison & Video Experts
Electro Med Services...
