How do I get the message: "The Ink absorber is almost full. Contact the service center" Which I did, and they gave me a service center. Too far away. So I googled some more, and then called Canon Technical Parts to get a new Ink Absorber and they said there is not an Ink Absorber in this model, so it cannot be repaired. I imagine there is a counter someplace, but wanted your expertise before I call technical support back. The manual says - for a Mac (I have a PC) - same printer - to get a replacement part. This is unnerving.
  • 11 more comments
  • donna406 Jul 16, 2009
    In response to Jeep brainy. I am having problems.
    I went through step 3. When I released the power and resume/cancel button, the power alternatively turns green, and the resume/cancel button blinks orange (6,7 or 8 times). This has been going for about fifteen minutes. I cannot get to step 4.
    Also you state, after the function (menu) is selected, press the Power button. I don't have a function(menu) or if I do, I don't know where it is located.
    Please help some more.
    Thanks.
    Donna
    I am now asked to either accept or reject solution, but I have not had a reply back to my reply to jeep brainy. I don't understand what is happening.
    Where do I find my reply to Jeep brainy?
  • donna406 Jul 17, 2009
    The exact model is a Canon PixmaiP1700, Model serial number is HCFA79300.
    I'm using Windows XP.
    I followed your 2nd procedure and for #4, I pressed the reset button 4 times.
    I still get the same message when I try to print.
    Any other ideas?
    I have tried all of your procedures and none have worked - including the downloading of the file and running General Tools.exe
    Is it that this can not be reset?
    In one you said the ink absorber is on the right and it collects ink everytime the printer is used. I original said that Canon parts said there wasn't an ink absorber on this model. I could not find any ink absorber or any ink. I had cleaned out some ink previously.
    I'm really exasperated.
    Am closing down for the night. I would appreciate any other suggestions you have.
    Thanks.
    Donna
  • donna406 Jul 20, 2009
    Thank you for your pictures.
    Without words it is very hard for me to get my printer to look like your pictures. I don't know how to open the bottom, and if I do then do I just mop up the ink? Mine doesn't seem to look like this and in the manual I don't find this.
    I have a pixma iP1700
    Please advise.
  • donna406 Jul 26, 2009
    Sorry for the delay, we have been out of town.
    This didn't work.
    I have a Pixma iP1700
    Do you have another solution? Thanks.
  • donna406 Aug 03, 2009
    None of the suggestions above have worked. I have a Canon Pixma iP1700. Is there a solution to 'The ink absorber being almost filled'? I was told that there is not an ink absorber in this model, so don't understand all these possible ways to correct it. There must be a counter that needs to be reset.
    Can anyone help?
    I have commented elsewhere, but maybe this is the place to respond.
    I have received several possible solutions - None have worked. I have a Canon Pixma iP1700 printer. I have the message 'The Ink Absorber is almost full." I have been told by Canon that there is no replacement part as this model doesn't have an ink absorber. No solution.
    Please let me know if there is no solution to reset the counter or what.
    Please note the model number I have.
    Thanks.
    Donna Crawford
  • donna406 Aug 17, 2009
    I am replying to post from firesnake09. I don't understand why this is not under his message. Anyway, if you look at all the comments the Model number is Canon PIXMA iP1700. It has already been determined that there isn't a ink absorber in this model and that the counter needs to be reset, but all the instructions to reset the counter do not work.
    When it gives me the message to 'cancel print' after it has printed, I just click OK and that way my printing continues. I have no idea how long this will work. I have talked to Canon and they have said there is nothing that can be done because there is no ink absorber in this model. I hope this gets to the right person.
    This is a reply to Jeep Brainy. I have tried to contact the service people in Sacramento, CA that Canon referred me to and I have no answer. Guess I will try calling Canon again. Thanks for all your help. It appears I have too many comments and haven't been consisting checking them. Hope you get this message.
    I did call Canon, and the response was there is no way to fix this, there is no replacement part and there is a pad of some sort in there which is absorbing ink which I can not get to without taking printer completely apart. I have been printing using the Canon since I first started this in July 2009 and I just do a reset and it has been printing just fine. I give up. I really appreciate all your help - but other than taking it completely apart and finding and cleaning the pad I don't see a solution. With an Epson printer costing $39 at Office Depot, I will take that.
    FixYa has certainly been helpful - with possible solutions although most Gurus haven't answered my questions, except you.
    So thanks - I will accept your solution.
    Donna
    As I explained in my comment - there is no solution to this problem other than finding someone to take it apart - probably for a cost of over $100 and I can get several printers for that.
    Jeep Brainy was for helpful whereas some of your other Gurus didn't bother to reply to my comments.
  • 10,515 Answers
I am not sure if you still have the same problem. But i can tell you the solution if you want to get if fixed :-
The ink absorber is at the bottom right of the printer.
Everytime you print something is used to clean the printing heads.
You can clean it using kitchen towel to dab out as much ink as you can from the tank.
Once done you need to reset the error. For that you need to follow this steps (both to make permanent).
Step 1)
1. Turn Off the printer, and then take off the cable power.
2. Push and hold the power button (use your fore finger to hold the power button).
3. Connect again the power cable.
4. Use your middle finger to push the resume button 2 times.
5. Release the power button.
6. Finish. you have finised the first step to reset Ink Tank Full Error (Blink Error).
Step 2)
Download the reset software from:
http://www.startcopy.ru/repair/files/ip1700_1300.rar
1. Run GeneralTool.exe
2. At USB Port choose your printer port.
3. Click Lock Release
4. Check EEPROM CLEAR
5. Put in blank paper for printing. And then click Test Pattern 1 button
6. It’s All Done. Your Printer IP1700 back normal again.
NOTE:
After this your PC will detect it as a new printer. So you willneed to go to the printer folder and make this new printer the defaultone and delete the older.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
DO ACCEPT THE SOLUTION IF 100% SATISFIED.
Posted on Sep 23, 2009
  • 742 Answers
The Ink Absorber is also called an Ink Waste Pad that absorbs all excess ink during print and print head cleaning. I think there is no replacement part for this since manufacturers computed the life span of your printer and it assumes that this errors will occur at the end-of-life of your printer.
but if your printer survived after a long period of time, you might have this error message displayed. so the ONLY way to resolve this is to disassemble your printer and manually remove and wash the waste pad. let it dry and place it back and re-assemble the printer unit.
Posted on Aug 17, 2009
    President:
  • 2,923 Answers
Can you provide me the brand and the exact model number of your printer? The information that you would provide would help me to further assist you.
Some printers are giving out this error message even though the Ink Absorber is new. Those printers needs to be sent out to the manufacturer for repair.
Please get back to me ASAP.
Posted on Aug 16, 2009
Hi there
I'm afraid it sounds like the printer will require servicing.
I can confirm that all inkjet printers such as yours do have an ink absorption pad, but it is true the replacement may not be available.
Your best bet would be to have the printer sent in to a local printer repair store for servicing. Do ask them for a quote first, and some stores charge the price of a new printer!
I hope this helps to conclude.
Best wishes
nLinked
Posted on Aug 03, 2009
    President:
  • 1,462 Answers
Here is the clear instruction for reseting the ink absorber
Pixma IP3000
1. Turn off printer.
2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times!!!
6. turn off printer by button POWER.
It is undertaken from service manual..
Posted on Jul 20, 2009
  • 854 Answers
Here it is..
Posted on Jul 17, 2009
  • 4,472 Answers
The counter is built into the main board itself. I would try these reset procedures first to try and clear the counter.
Reset Printer Canon Pixma iP1700/iP1300 Waste Ink Counter
Turn off printer
Hold down Resume button and press Power button.
Keep holding down Power button and let Resume button go.
Press Resume button 2 times then let BOTH buttons go.
Green lights will flash and then stop blinking.
When green lights are solid, press the Resume button 4 times.
Press the Power button
One of these reset procedures should work on resetting the printer. If this does not work please let me know. I will also contact canon regarding this issue Monday morning to see if they have the exact reset procedures. I would not invest any more money into repairs or such because you can purchase this exact printer for as little as 35$ brand new from ebay. If you have any other questions please let me know.
Thank you,
Lee
Posted on Jul 26, 2009
  • 336 Answers
Not easy for most people to replace or clean ink pads, but this will reset
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button.
(Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button.
(Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons.
(Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
Posted on Jul 16, 2009
  • 4 more comments
  • jeep brainy Jul 16, 2009
    Hi Donna,
    Can you please give me the exact model number of your printer?
    Thanks in advance.
    regards.
    Hi Donna,
    Here another procedure you can try. I hope this will work.
    1.With the printer powered off but connected to a power source,
    press the Power button while pressing and holding the Stop/ Reset button.
    2.When the Power is lit, press the Stop/Reset button two times
    while pressing and holding the Power button.
    3.When releasing the Power button and the Stop / Reset button (regardless of order),
    the printer will move into a service mode. (Waiting for menu selection)
    4.When the on/off lights in green, press the Stop/Reset button the
    specified number of time(s) according to the function listed in the table below.
    (Each time the Stop/Reset button is pressed, the LED lights alternately in orange
    and green, starting with orange.)note: press 4 times for waste ink counter reset.
    The number of the Reset button pressing LED Function Remarks
    0 time Green Power off
    1 time Orange Service pattern print (auto teste)
    2 times Green EEPROM print (dados da EEPROM)
    3 times Orange EEPROM reset (EEPROM reset)
    4 times Green Waste ink counter reset (Absorvente reset)
    5.Turn off the printer.( it must be turn off) then turn it on again.
  • jeep brainy Jul 17, 2009
    Hi Donna,
    Thanks for giving me the model number. I will ask you again to do a new procedure. here is how:
    The ink absorber is to the right of the printer. It collects ink everytime the printer is used to clean the printing heads on the ink cartridges. So, get some kitchen towel and dab out as much of the ink as possible, then do this.
    Procedure to Reset Ink Tank Full Error for Canon IP1700
    6. Finish. you have finished the fstep to reset Ink Tank Full Error (Blink Error).
    Thanks for the patience. I hope it work this time. Oh and take note: This will tell your PC you have a new printer, so you will have to go to the printers folder and set this 'new' printer as the default, otherwise it won't print.
    Kind regards.
    Hi Donna,
    I hope the last procedure I gave arleady fixed you issue. In case not, here the another one.
    1. Download Software Resetter for Canon Printers iP1300 dan iP1700
      http://www.startcopy.ru/repair/files/ip1...
    2. Unrar/Unzip the Software
    3. run GeneralTool.exe
    4. Select the connected USB port number from USB PORT
    5. Click LOCK RELEASE
    6. Select EEPROM CLEAR
    7. click Test Pattern 1
    8. Your Canon Pixma iP1700, iP1300 Printers should respond as normal.
    Cheers!
  • jeep brainy Aug 04, 2009
    Hi Donna,
    After some more research, it appears that your printer doesn't indeed have an ink absorbtion pad though it still have the counter settings in which when reached it will tell that the ink absorber is full (though not present). Since you've already done all the possible solution to reset the counter and didn't work, may I suggest to bring your printer to the nearest service center. They might have other way to fix it. Thanks and goodluck!
    Regards,
    Jeep Brainy
  • jeep brainy Aug 17, 2009
    Hi Donna,
    Goodluck on getting help from canon. Just let me know what will they say and if your problem won't still be resolved please get back to us and we will try to have some experiments and troubleshooting again.
    Thanks for using fixya.
    Regards,
    Jeep Brainy
MFC-J415W says, Ink Absorber Full
your Printer need to RESET Just contact the service center.
Oct 11, 2014 | Brother MFC Office Equipment & Supplies
Canon Printer Pixma MX700 All-In-One/ Alert message received. Ink absorber almost full. Contact service. How to get to? Have to replace?
Ink Absorber Full
This may clear the ink absorber problem. There is ink absorbers located at both ends of the printer where the ink head move.
To dry the ink absorber, power up the printer and open the cover so the ink cartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place it inside the printer over the ink absorber on the far left hand side of the printer to soak up the excess ink. You may need to change the absorbent tissue a few times. Then repeat the same procedure on the right hand ink absorber.
Close the lid and the printer should now function normally.
Aug 19, 2012 | Office Equipment & Supplies
Canon ip3500 series the ink absorber is full contact the service center
This mayclear the ink absorber problem. There is ink absorbers located at both ends of the printerwhere the ink head move.
To dry the ink absorber, power up the printer and open the cover so the inkcartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place itinside the printer over the ink absorber on the far left hand side of theprinter to soak up the excess ink. You may need to change the absorbent tissuea few times. Then repeat the same procedure on the right hand ink absorber.
Aug 07, 2011 | Canon PIXMA iP3500 Printer
"ink absorber is almost full, contact service center" - what does this mean?
Inkjet printer has waste ink absorber inside, sponge alike. The function of waste ink absorber is to localize and keep waste ink safe inside the printer and does not harm the electrical parts.
Waste ink is produced from print head cleaning process and borderless printing. When capacity of the ink absorber raise to about 90% then warning message appears.
You need to bring your printer to the nearest service center to get waste ink absorber replaced.
Source:
Printer Clinic: Printer Tips,tricks,troubleshooting
E-manualshop: Online source of service manual
Aug 08, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
I have problem with my canon ip1980. the ink absorbent is full
you can open the printer case and look underneth the the ink cartridge ther are 2 ink absorbent foem remove it and wash it until ink remove from the foem make it dry and put it back again.
Nov 10, 2009 | Computers & Internet
Its appear " The ink absorber is full. Contact the service center."
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink full" error.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you.
May 11, 2009 | Office Equipment & Supplies
The waste ink absorber is full.
You have to contact the Canon agent to get the waste absorber replaced. or you can continue it with pressing resume everytime.
Apr 23, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Canon MP145 Ink Absorber Full Problem.
I got on error message when started to print.
It’s kept happened and message dialog box “The ink absorber is full” occurred.
Mine is Canon MP145.
Can somebody please help me , on how to fix this problem !
tq
Jan 13, 2009 | Canon PIXMA MP150 All-In-One InkJet...
The ink absorber is full and printer won't print.
Normally when you get the "ink absorber is full" message, you would take machine to a Canon service center. They will either clean the ink absorbers or more than likely they will replace the ink absorbers. After replacement, the ink absorber full message will have to be reset which is done in the service mode.
Inkworks
866-381-0541
Nov 21, 2008 | Canon PIXMA iP1600 Printer
ERROR MESSAGE 2
How do I change the ink cartridge for the Canon Pixma 150
Sep 01, 2008 | Canon PIXMA MP150 All-In-One InkJet...
165 people viewed this question
k24674
jasbo
jasbo
