Question about D-Link AirPlus DI-614+ Wireless Router
Emule connection problem , DI- 614+ revB router
Whenever i connect emule , the internet connection is down after a few minutes. i forward 4662 TCP and 4672 UDP. my DLink router have latest firmware update. i also limit connections to 100 max. still having that problem. thanks.
  • blackdot Nov 19, 2007
    how do i limit . this is my setting. download 96 kb/s. upload 0. download limit 24 kb/s. upload limit 6 kb/s. is tat problem related to firmware. my version is 3.44 updated on 16 Nov 2005. i haven't got 2006 version. that's the result for speed test.
    speed down 2015.50 kbps (2Mbps)
    Speed up 236.83 kbps(0.2 Mbps)
    Problem Solver:
  • 14 Answers
It sounds like to emule client is hogging all your bandwidth. Try and limiting your emule client to only use 70% of your total bandwidth. If you don't know your internet speed, then go to and run a test
Posted on Nov 18, 2007
Port forwarding of Router D-Link DI-634M
Yes this router has a port forwarding capability, to know about that and how it is done from this router check this link.
Feb 23, 2010 | D-Link DI-634M Wireless Router (DI634M)
How to lock my router so neghbours cant connect
Follow the instructions on this D-Link page (it shows DI-614, but it is the same procedure for your model):
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 26, 2009 | D-Link DI 514 Wireless Router (DI-514)
D-link di514
Try the DSL modem directly connected to the PC.No D-Link Router(powered off and disconnected). Verify that the PCcould surf/browse/connect to the Internet. Go to Start, Control Panel,Network Connections, right click Local Area Connection, Properties,scroll down to/highlight Internet Protocol (TCP/IP), Properties button.Get the IP Add, Subnet Mask, Default Gateway and DNS assigned to the PC(write this down. This will be your WAN/Internet IP settings). Then Disable DHCP of your modem if it has one. OK, close, save or whatever is applicable.
Disconnect the DSL modem from the PC. Connect D-Link Router to PC (wired/LAN) without the modem connected to the router.Go again to Start, Control Panel, Network Connections, right clickLocal Area Connection, Properties, scroll down to/highlight InternetProtocol(TCP/IP), Properties button. Tick "Use the following IPaddress". Enter this IP Add, Subnet Mask255.255.255.0,Default Gateway and the DNS from what youhave written down earlier). This will be your LAN IP settings. OK,close, save or whatever is applicable.
Open a browser and log into the D-Link router (, using "admin" as a username and no password). Do not run Wireless Network Setup Wizard. In WAN/Internet/Modem setting of router enable/check Static IP Add.Usethe IP numbers previously assigned to PC that you have written down asthe router's WAN/Internet/Modem IP settings. OK, close, save orwhatever is applicable. Reboot router. Connect DSL modem to router.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Aug 04, 2008 | D-Link DI 514 Wireless Router (DI-514)
Forwarding ports on my router
I'm really not sure if opening those port will increase your internet connection, because if you have a slow connection you better check it from your ISP. You only need to open port if you're having problem with some application like servers and games.
But you really want to try to opening that port check this link how to do it, this is a sample on how to open port on your router.
May 10, 2008 | Belkin (F5D7230-4) Router (587009)
Emule Show Low ID on Client Computer
Dear sir/madam,
You can update the servers it may be become fast. Go this site and add all servers (add to emule) click this link, they automatically update the servers.
OR try this
First of all you need to know the IP of the computer that you use with Emule.
Then go to the router configuration:
- Choose "NAT Settings", and "Virtual Server".
1- If it isn't enabled, enable the "Virtual Server".
2- In "Well-Known Applications" choose de option "User defined".
3- Now the crucial part. Under the Virtual Server List, in the "Local IP" you place the IP of your computer (on the example,, i.e. my emule computer ip), "Port Range" put 4662 and Protocol TCP. "Protocol nº." stays blank, and in the "description" you can put Emule Rule Nº1.
4- Click ADD, to add the rule to the table.
- Again you make the same passes from 3 to add the second rule:
3- In the "Port Range" you place 4672 instead 4662, and on Protocol you place UDP instead TCP. On "Description" you can place Emule Rule Nº2.
4- Click ADD.
5- After making the 2 rules, click Finish, and on the next screen click on Save&Restart button.
In the next time you start Emule, you can acess to the servers without Low ID.
Don't forget to rate the solution
Mar 23, 2008 | Computers & Internet
DI-524 wireless router as wireless switch
You need to disable the DHCP server on your "slave" wireless router ( the di-524 ). In D-link routers this might be called configuring it to be an "Access point".
When this happens, connecting to the second wireless router should cause your computer to obtain an IP address which is in the range of the first router (that is to say, it will use the first router's dhcp server).
You should be able have your laptop connect with an automatic IP address and have it work.
Jan 24, 2008 | D-Link AirPlus DI-524 Wireless Router
How to port forward using Dlink DI-524 for Emule?
DMZ is a feature that is included on some routers but is not in Internet sharing software. A DMZ allows a single computer on your LAN to expose ALL of its ports to the Internet. When doing this, the exposed computer is no longer ?behind? the firewall. Port Forwarding vs DMZ A DMZ is far easier to set up than port forwarding but exposes your entire computer to the Internet. Sometimes TCP/IP applications require very specialized IP configurations that are difficult to set up or are not supported by your router. In this case, placing your computer in the DMZ is the only way to get the application working. Placing a computer in the DMZ should be considered ?temporary? because your firewall is no longer able to provide any security to it.
Oct 03, 2007 | D-Link AirPlus DI-524 Wireless Router
Low ID on eMule
One more thing re low id on emule - try to choose ports between 10000 and 60000 - many isps block the standard ports that emule users choose, and you will see people saying to choose one over 5000, but I'd chosen ports between 5000 and 10000, and still had no luck until I went over10000.
Most isps don't monitor ports over 10000, so if you still have low id problems even after port forwarding and setting up your firewall, this may be the answer to your problem! (I got this info off, and it worked for me)
Feb 16, 2006 | D-Link DI-707P Router (DSDLDI707P)
Configure for emule
You must open ports on your router to allow incoming traffic while using eMule. eMule uses three ports*: 4662 (TCP) 4672 (UDP) 4711 (TCP) Visit eMule here. * To prevent getting a low ID (Firewalled), open additional TCP ports between 4661 and 4665. Also, limit the number of connections in the eMule software. You may need to change the TCP Clientport to something other than 4662.
Configure DMZ Host
enter username admin and password blank (nothing), i got 401 Unauthorized messege 3 times reset the routher DI-524
Feb 16, 2006 | D-Link DI-704P Router
D-Link AirPlus DI-614+ Wireless Router Logo
251 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
