The instruction manual shows 13 wash cycles available, while the unit in our newly rented flat shows 14 cycles.
We chose cycle 11 on the machine and adjusted the water temp to 30 degrees. The water temp is too high. Can someone help me on what to do for a short cycle at 30 degrees
aristonbrand.com/media/WDG-8629-User-Manual-19510586801_AU.pdf WASHER-DRYER ! This symbol reminds you to read this instruction manual. ... from its packaging. 2. Make sure that the washer-dryer has not been damaged.
Have you tried using google in question form with brand and model # to see where you can get a users manual? You might also contact the manufacurer or the landlord from whom you are renting from.
RF_Tim I feel you have a Clutch malfunction a very common problem with the machine.If you want to DIY the fix see my Clutch Fix post. FAV6800A/FAV9800A Service Manual for reference.Sears Parts Direct for reference. If you need some additional help just shout back……..Rich
According to the instruction book - it appears the machine has been stopped mid cycle then re-started. Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
