Question about Sport & Outdoor - Others
99 BAJA Sidewinder
Just purchase........when I fill up with fuel.......fuel comes out just below what looks like over flow air vent. Is this suppose to have a cap on it?
Chuck
  • 32 Answers
I believe that its supposed to have a cap on it.
Posted on Aug 03, 2009
Why does my 99 zx6r keep stalling when coming to a stop?
Hi, William and the usual suspects are:
1. Idle circuit and transfer ports clogged.
2. Air fuel mixture adjustment too lean.
3. Pilot jet clogged.
4. Faulty accelerator pump.
5. Float level too low.
6. Float bowl contaminated old fuel, water, dirt, rust, etc.
7. Float bowl vent or overflow tube clogged.
8. Fuel flow to carburetor restricted.
9. Intake manifold leak.
10. The gas cap is not venting properly or fuel tank venting system blocked.
11. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
12. Needle and seat stuck closed in the float bowl.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
http://www.newninja.com/forums/f161/1999-zx6r-dies-when-coming-to-a-stop-12706.html
1998 1999 Kawasaki Ninja ZX 6R Service Manual ZX600 G1 H1 Moto Data Project
OEM Parts for Kawasaki
Kawasaki Ninja Owners Manuals
Oct 11, 2016 | kawasaki ZX-6R Ninja Motorcycles
Were is the fuel vent? Were does it exist the boat?
A lot of boats have a sag in the fuel hose which will cause slow filling. Also in a older boat the hose can deteriorate and block flow. Boat on trailer? walk around the boat looking usually near the fill on the side of the boat, Up near the rub rail. Can be round or shaped. It can get clogged. There is usually a screen on the outside of the openings. Wasps can clog. Test. Very carefully, remove fuel cap. Put the DISCHARGE of a small vacuum blowing in the whole and listen for the air coming out.
Sep 20, 2014 | Boating
F/spd cont fuse missing and loosing power when accelerate uphill
vent valve is stuck closed causes fuel not to fill correctly fuel pump module sucks air on grades to steep for pick up to keep fuel flow steady
Apr 01, 2014 | 1998 Pontiac Grand Prix
Yamaha XJR 1300 combustion chamber filling up with fuel
Hi, Peterlucia and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
8. Damaged petcock diaphragm allowing fuel to flow through the vacuum line into the combustion chamber.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Fuel Coming Out Of My Airbox Workshop Help
vacuum fuel tap
Yamaha XJR1300 99 Service Manual
OEM parts for Yamaha
YAMAHA XJR1300 Owner Manual
Aug 15, 2010 | Yamaha XJR 1300 Motorcycles
99' cavalier, gas line problem?
for petrol to flow into the tank air has to leave it but the air pressure on the filler nozzle willstop the flow,so dont put the nozzle too deep so air has a chance to escape
Jul 07, 2010 | 1999 Chevrolet Cavalier
I have a 2006 F250 which I have lots of aggravating problems with trying to fuel up. No matter which gas stations or method of inserting the nozzle into the fill tube I use, I am frustrated by the time it...
where the filler neck goes to tank didnt it have seperate tube which is vent or with filler neck hose off at tank look inside tube for another hose it is vent hose take fuel cap off and blow air from tank end towards the filler cap area we have had two ford vehicles lately in our shop when we blow shop air backwards thru hose several little round pieces of foil off of fuel injector cleaner bottles somehow they had become lodged in vent line and one customer had vehicle towed from gas station because they were on empty and would accept no gas you may want to check this doesn,t have to be cleaner bottle tops could be any sort of debris but ours came flying out of fuel cap when when blew air thru you could pump gas with handle all the way down she was happy
Mar 24, 2010 | 2006 Ford F-250 Super Duty
Put new in line fuel filter, but will not fill filter up with gravity flow. needs air to get the fuel flowing. is there a special filter to use on this?
The Lincoln Gxt 250 is supposed to have an electric fuel pump. Check to ensure the fuel pump is working correctly. Most of the inline filters I deal with dont fill up. There is always a good size amount of air present in them even during operation. I know it doesn't make sense, but they do work.
Jan 13, 2010 | Lincoln Electric Ranger Gxt 250 Amp...
No air flow to dash vents and feet vents
99% of the time when they do that it is the control head. that is the thing you adjust all your temp settings on. have to purchase from dealer. have last eight digits of vin # when ordering.
Dec 09, 2008 | 2001 Chevrolet Tahoe
Sport & Outdoor - Others Logo
70 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
