Question about IBM Wheelwriter 30 Typewriter
Our ibm 6787 types the wrong letters. we took out
Our ibm 6787 types the wrong letters. we took out the batteries, turned it off and unplugged it but that didn't resolve the problem.
  • 125 Answers
Hi:
Make sure that the Lang function is not on.
Andrew
Posted on Jul 17, 2009
The power comes on. There's a humming noise but nothing works. The display is interuppted dark lines. It quit mid typing. What's wrong?
Need to get more information. Turn off the machine and wait 5 seconds and then turn it back on. Do any of the lights on the right side of the keyboard come on and or blink? Does the carriage move at all or does the display have anything showing or are there just dark lines? Does the machine beep and if so, how many times? The answers to these questions will help diagnose the problem(s).
Dec 16, 2014 | IBM 6787 - 6787 Wheelwriter 30 Series Ii
The bottom half of the letters typed dont show up
Press down firmly on both ends of the platen (black rubber roll) it should snap into place, if it comes back out one of the latches is broken and will need replaced.
DickyO
Feb 17, 2014 | IBM 6787 - 6787 Wheelwriter 30 Series Ii
I have an IBM Lexmark Wheelwriter 6 Series II 6784 Typewriter that is not typing the correct letter/number and at times, is not typing anything at all (no letters/numbers are appearing that I'm typing) We...
Try cleaning the sensor that lays behind the printwheel that tells the machine the wheel is in the home position, the sensor is in the print carrier. take wheel out and look down and you will see the sensor, clean it off with clean cloth. also put some white out on the top of the printwheel and see if it stops at the same place every time when you turn on and off.
Oct 05, 2017 | IBM Lexmark Wheelwriter 6 Series II 6784...
Caps lock is off but it is typing in capital letter nad when caps lock is on it is typing in small letter
Unplug the laptop and remove the battery, leave for 30 mins and try again.
hope it helps
Aug 31, 2010 | IBM ThinkPad T42 Notebook
PROBLEM WITH MY IBM TYPWRITTER MODEL 6787.BEEPS
This code does not appear in the users guide. You might try removing the batteries turn off for 30 sec. and restart. This will reset everything to factory defaults.
THIS WILL CLEAR THE MEMORY!!!
DickyO
Jun 29, 2010 | IBM Wheelwriter 30 Typewriter
MY IBM SELECTRIC II TYPES THE WRONG LETTERS. I CHANGED THE RIBBON, AND THE CORRECT TYPE. WHEN I PUT THE ELEMENT ON, IT STARTING TYPING THE WRONG LETTERS.
Not good. You probably turned the element while removing it and if you are lucky had it come off one of the pulleys, but more likely it came off the wheel under the element. Then you will need a tech.
DickyO
Feb 02, 2010 | IBM Wheelwriter 30 Typewriter
IBM wheelwriter types wrong letters
Try holding the code key and pressing the "L". If that dosen't do it remove the batteries turn it off wait a minite and restart this will put everything at default setting and clear the memory. If you still have the problem Press code "L" hold down the "L" type 001 to set the keyboard to U.S. If this works you need a keyboard for a permanent repair. For a keyboard contact Geo. Beyers Co.
@ 800-392-8085.
DickyO
Dec 14, 2009 | IBM Wheelwriter 30 Typewriter
Typing characters that are not intended
Try these troubleshooting suggestions for your problem:
Wrong Characters Print or Characters Space Incorrectly:
1. Turn the typewriter off, wait 30 seconds, then turn the typewriter
on again and try typing again.
2. Make sure the LANG indicator is off.
3. Try a new printwheel.
4. Look for objects In the path of the carrier.
5. Make sure the printwheel is changed when there is a language
change.
6. If you are playing back, make sure you use the same pitch
printwheel you used when you typed the text.
You can download the Operator's Guide for your typewriter from here (it takes a little while for the download to begin):
Wheelwriter Typewriter 30 Series II (6787) Operator's Guide
Aug 20, 2009 | IBM Wheelwriter 30 Typewriter
IBM personal wheel writer 2, wrong letter is typed
Try code "L" it will get you out or the language mode
DickyO
May 11, 2009 | IBM Office Equipment & Supplies
IBM Wheelwriter 30 Typewriter Logo
186 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
