Question about Office Depot Ativa 802.11g Wireless Cable/DSL Router With 4-Port Switch (AWGR54)
Ativa lets me connect to internet, but most websites come up address unknown. When I bypass the router I can get to the site. All the router settings are good ? This happens to any pc using the wireless
    President:
  • 623 Answers
That sounds very much like a DNS problem, if the address translation is not working properly.
One way to check on your DNS settings is ito open a command prompt (WIN-key+R), type "cmd" and hit "Enter". In the opening window type "ping www.google.com". The Result will look similar to this:
Pinging www.l.google.com [74.125.19.105] with 32 bytes of data:
Reply from 74.125.19.105: bytes=32 time=32ms TTL=52
Reply from 74.125.19.105: bytes=32 time=33ms TTL=52
Ping statistics for 74.125.19.105:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 32ms, Maximum = 33ms, Average = 32ms
Now type google's IP address (in bold) into the address bar of your browser.Hit "Enter" and you should see google's search page. This means that your computer (or router) can't translate "human" addresses (like www.google.com) into IP addresses (like 74.125.19.105)
First check your computer:
Go back to your command prompt and type "ipconfig /all". The output will show the settings from all adapters and will like this:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Intel(R) PRO/Wireless 3945ABG Network Connection
Physical Address. . . . . . . . . : XX-XX-XX-XX-XX-XX
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . : Yes
IP Address. . . . . . . . . . . . . : 192.168.2.100
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.2.1
DHCP Server . . . . . . . . . . . : 192.168.2.1
DNS Servers . . . . . . . . . . . : 192.168.2.1
Lease Obtained. . . . . . . . . . : Thursday, July 16, 2009 09:41:52
Lease Expires . . . . . . . . . . : Friday, July 17, 2009 09:41:52
Note here that the bold entries all point to my router. That meeans that
1. My default way to the outside world (internet) is through my router.
2. My computer gets it's IP address from the router (DHCP).
3. DNS requests are handled by my router.
Your router has the default IP address of 192.168.2.1 - this should be the number you see.
If that is not the case, here is how to change it:
  1. Open Windows Start menu.
  2. Open Control Panel.
  3. Classic view: Open Network Connections / Category view: Select Network and Internet Connections, and then Network Connections. (This opens the Local Area Connections Properties window)
  4. Double-click on your active LAN or Internet connection.
  5. Click Properties. (This opens the Local Area Connections Properties window.)
  6. In the General tab, highlight the Internet Protocol (TCP/IP) item, and click Properties. (This opens the Internet Protocol (TCP/IP) Properties window.)
  7. In the General tab, click "Obtain an IP address automatically", and "Obtain DNS server address automatically":
  8. Click OK.
  9. Click OK to close each window. (The last one might take a second or two, because it is applying the new settings
Now to your router...
How to set up DNS on your router:
Look at page 34 of your router manual. If you don't have one, you can download it from here.
There are several options which DNS server you want to use. One very popular service is OpenDNS (see link here). Their DNS server have the addresses
  1. 208.67.222.222
  2. 208.67.220.220
Enter these numbers in the WAN>DNS settings of your router.
Don't forget to save your new settings and you should be good to go.
Sorry for being so lengthy, but I wanted to walk you through all steps. If you have any more questions or something is not clear to you, just come back here and leave a comment - I'm happy to help.
Posted on Jul 16, 2009
Tv will not connect to internet
It sounds like your router is not assigning an IP address to the TV. If you have already have DHCP turned on, in the router's settings, then you may need to increase the range. If you are not using DHCP by choice, then you will need to assign a static IP to the TV. You may also need to configure the TV's MAC address in the router's settings, if you are using MAC address filtering.
Are you the person that set up the router, and is this your router? Some additional information is required, to be able to assist you.
Sep 16, 2014 | Computers & Internet
Ativa g wireless router awgr54 default ip address failure
NEED A CONNECTION WITH THAT LOOK UP 192.168.1.1
AND USE INTERNET EXPLORER
Jan 30, 2012 | Computers & Internet
How to block facebook
BLOCK WEBSITES
Step 1 : Connect - Router - Computer ( Wired )
Step 2 : open Router Setup by typing http://192.168.1.1 on the address bar of internet explorer
Step 3 : Click Access Restrictions
Step 4 : At the Bottom you can find Website Blocking by URL Address
Step 5 : There type http://www.facebook.com and click save settings
Let me know if it works
Dec 22, 2010 | Linksys Wireless-G WRT54G Router
I have D Link DIR-300 Router. It was working fine cuople of days back but now Its not letting me connect to the Internet. I am able to connect to internet if I bypass the router and directly connecting to...
If a router was working flawlessly but suddenly stops working in the way you describe the most common issue are either connections that have become faulty [check wiring, swap out cables to see if any have gone bad] or settings/firmware have become corrupted.
If the latter bypass the router and go to the D-Link support site: http://www.dlink.com/support/
download the latest firmware for your router and follow the instructions provided for flashing the ROM to correct any corrupted code.
Remember to use the administrative functions through the browser access [usually accessed by typing this address: 192.168.0.1 into the browser for D-Link routers] to save all your settings to a file so you can replace them after flashing the routers ROM, for doing so will have reset those settings back to factory defaults.
Hope that helps.
Feb 04, 2010 | D-Link DIR-300 Wireless Router
Lost Ativa Wireless G router manual dont know how to set up please help
You can get the user manual on the manufacturers website
Here is:
http://www.ativasupport.com/product/?pid=AWGR54
All you need is :
1. Open up IE or Firefox. On address bar, type in "192.168.2.1" and click enter.
2. Ativa wireless setup should load up.
On top right, there is a Log In button.
If this is your first time login in, leave it blank and submit.
3. Check up on the following: a) Internet WAN > Connection Type > select Dynamic; b) Wireless > Channel and SSID > Disable ESSID Broadcast, also set wireless channel to AUTO; b) Wireless > Security > set up your security, use wep or wap or others
4. Now for the most important thing.
Click Firewall, and DISABLE IT!! By doing this, it said that you'll will be vulnerable to hacker etc...blah blah, but with security keys to access wireless and virus program/window firewall should be enough to make you stop worrying. Apply changes, then the thing restarts and you are good to go.
ok try this and let me know.
Any other help or clarification you are most welcome.
Cheers
Uttam
Jan 31, 2010 | Computers & Internet
Does anyone know how to change a belkin router settings
you have an address like: 192.168.1.1 or 192.168.0.1 (there several possible addresses). you will find in the prospect of your router.
type the address in a browser.
it will ask you for a user name and a password. you can have the following combinations: admin-1234; admin-admin; admin-0000; unknown-unknown, or admin- blank (leave the password field blank). but have a look in your prospect for this information also.
then you will have the configuration of the router. (lan, wan, setting your internet connection). it usually has a wizard that helps you in configuring the device. note:clone your mac. it will help you.
hope this helps
Dec 17, 2009 | Belkin (F5D7230-4) Router (587009)
Dlink WBR 2310 cannot connec to internet
Try to bypass the router and connect to your modem. Make sure you have Internet connection.
>If you have Internet connection. connect back your modem to the router.
>access the configuration page of your router.
>If you are given a specific IP by your Internet Service Provider, use that one.
>Login to your Dlink (type in on the address bar 192.168.0.1)
>Click Setup and Internet > Click on Manual Configure
>My Internet connection would be Static IP
>Type in your IP address, Subnet Mask, Default Gateway, Primary and Alternate DNS
>Click on Save Setting on top.
but if your Internet Service Provider did not provide you those informations
> Under My Internet connection Type choose DYNAMIC IP
>Click on Clone Your PC MAC address
>Click on Save Settings
>If it ask you to reboot, click on Reboot.
>At the very top click on Status
>Under Status look for WAN
>Under WAN look for IP address
>If you have values beside from zero it means you have Internet connection otherwise, call your dlink manufacturer for manual configuring your router for Internet connection.
Jan 30, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Ativa router wont connect with linksys adapter
Definitely..i can give you step by step instructions ..it might help..
1.Connect the modem to router (in the WAN slot),the router to computer& just reset the router for 20secs..it should work,if it doesnt,try this..
2.First connect the modem to your computer& check if u can go online.
If you can,check the ip address (on ur keyboard,press the windows logo with letter "R",in the box type "cmd",ul get a black window,type "ipconfig"& ul get ip address..make note of it)
please tel me who is ur internet service provider?
3.once you have this,connect the router&again check the ip,it should be 192.168.2.1.
again press windows+R & type in http://192.168.2.1.&enter.
4.You will get the router page,to the left u will get a column with options in it,click on "conection type"(if it asks for password,leave it blank&press enter)
5.here you will get several options,click on dynamic,click next,then click on "clone mac address","apply changes".the page should say "connected" at the top right corner..,if it doesnt,unplug the power to both ur modem& router,wait 30 secs& plug in modem first,20secs later,the router's power&check.
Please check if it gets you online..
Nov 11, 2008 | Office Depot Ativa Wireless-G USB Network...
Ativa router
ok, fine....
Reset the Ativa router to factory defaults. This is normally accomplished by holding the reset button down for 10 seconds or more with power on for most routers.
Once you do that, you need to connect the computer directly to the motorola modem and configure it to be in "bridge mode".
Putting your modem into bridge mode means to bypass the router function and make it work as a simple modem. And, yes, if you do that then you must configure your wireless router to make the internet connection. If you don't want to do that, you can leave the modem as it is, I think the Ativa wireless router can still work even if your modem is still in PPPoE & you can still configure the router as an ethernet switch & wireless access point.
Now you can connect the router (after powering EVERYTHING down), turn on the modem, wait for steady connect, turn on the router, wait two minutes, boot the connected PC.
After you get a wired machine connected, you can enter the Ativa setup and configure the wireless security.
Ativa wireless setup should load up. On top right, there is a Log In button. If this is your first time login in, leave it blank and submit.
Check up on the following: a) Internet WAN > Connection Type > select Dynamic; b) Wireless > Channel and SSID > Disable ESSID Broadcast, also set wireless channel to AUTO; b) Wireless > Security > set up your security, you should know what to do.
Now for the most important thing. Click Firewall, and DISABLE IT!! By doing this, it said that you'll will be vulnerable to hacker etc...blah blah, but with security keys to access wireless and virus program/window firewall should be enough to make you stop worrying. Apply changes, then the thing restarts.
*** also leave MTU setting to 1454 & set it to auto connect; leave the DNS & MAC settings alone; also leave LAN settings as it is.
i would greatly appreciate if you could give me the modem's exact model no. (such as SB4200, 2100 etc.) and the router's as well....
Apr 23, 2008 | Computers & Internet
Ativa router and at&t
there is a link in the motorola UI that allows it to be put in "bridged mode" so you can configure the router. however, before you do this, i suggest you have to make the motorola (is it 2100?) modem work with your computer, connect this modem to your computer using ethernet connection, access the UI (192.168.1.254), type your user id & password in the login page, then connect. make sure that you are able to connect to the internet. then access the UI again, click on "advanced" choose PPP location. in the PPP location page, click on bridged mode, that will restart the modem automatically, & you will notice the modem's internet light will turn off. then you can connect the ativa router to this modem using manufacturer's instructions. you can now login to the router's page and make the necessary changes.
Apr 20, 2008 | Computers & Internet
Office Depot Ativa 802.11g Wireless Cable/DSL Router With 4-Port Switch (AWGR54) Logo
602 people viewed this question
Top Office Depot Computers & Internet Experts
k24674
Vernon Taylor
Are you an Office Depot Computer and Internet Expert? Answer questions, earn points and help others
