Question about Garden
My rider has no spark wont start - Garden
    President:
  • 1,776 Answers
I would take a look at the armature. Check the gap between the rotor and stator. Normal gap ranges are .006" - .010" and .010" to .014". The armature itself could be bad, but before changing a suspected bad armature, check for any bad electrical switches or a wiring problem. Broken or charred insulation will sometimes point out a bad wire. Check the flywheel for any damage and that it doesn't have a key sheared off. Not common, but it happens. Hope this helped.
Posted on Jul 16, 2009
Dirt bike wont run. I have replaced the stator and pickup coil, the regulator, grounded out the neuatral safty switch, and bypassed the kill switch. I get a great spark about every 6 to 10 kicks
7 Things To Do When Your Dirt Bike Won't Start - All
www.instructables.com/.../7-Things-To-Do-When-Your-Dirt...
InstructablesSometimes when your dirt bike does not get used, it won't start.Here are some ways to start a "mad motor."
What To Do When Your Bike Won't Start - Dr. Dirt - Dirt Rider ...
www.dirtrider.com/features/protips/141_0803_dr_dirt_bike_wont_start
Apr 6, 2009 - Tech How-To****There are few things more frustrating to a rider ready to ride than a motorcycle that won't start. But a silent machine need not ...
So, Your Dirt Bike Won't Start? - Cannibal Cycle
Dec 15, 2015 | Motorcycles
Kawazaki kdx 125 wont start
KICK HARDER TRY PULL STARTING IT..IN SECOND GEAR..DOES IT HAVE ENOUGH COMPRESSION TO START?IT SHOULD START PULLING IT...START OFF WITH NO THROTTLE THAN IF NOT STARTING CRACK THE THROTTLE SO LIGHTLY AND SHE SHOULD FIRE OFF WHILE IN GEAR BEING PULLED OF COURSE BE CARE FUL NOT TO RUN INTO. WHO EVERS PULLING YOU..USE A LONG TOW ROPE..IF YOUR NOT A SEASONDED RIDER AND KNOW YOUR BIKE VERY WELL I WOULD NOT ATTEMPT THE PULL START...IF NOT CHECK YOUR COMPRESSION AND TIMING..MAJOR VACUUM LEAK MAYBE AT BASE GASKET..IS ENGINE SUCKING TO MUCH AIR? GOOD LUCK..
Mar 02, 2013 | kawasaki KDX 125 Motorcycles
I changed the spark plugs in my dyna and now it knocks and wont start
Have you checked to see if the spark plugs might be longer then the ones you took out? If they are too long they can hit the top of the pistons and the electrodes can bend.
Oct 30, 2012 | 2000 Harley Davidson FXDL Dyna Low Rider
My john deere L130 riding lawn tractor has spark and gas going to the carb but wont start. it has new spark plug and fuel filter When starting fluid is sprayed into carb it runs till its burnt up and...
I had a JD 111 rider that may have had the same problem. Turned out to be the fuel line had a weak area and would **** together and not allow the fuel through. It's a cheep place to start.
Good luck!!
Jul 11, 2011 | John Deere Garden
John deere lane rider la135 wont start.
You don't mention if they are on and are bright or are week. Do they dim when trying to cranks the motor? I would start with checking the ground wire at the battery and where it connects to the frame. Make sure both are clean. From there, have the battery tested and then the starter.
May 02, 2010 | Garden
98 rm wont start
hi fellow rider, you may want to check on the links below:
http://www.thumpertalk.com/forum/archive/index.php/t-726715.html
http://www.allthingsmoto.com/forums/f-62/rm-125-wont-start-31198/
http://answers.yahoo.com/question/index?qid=20081201165114AADfYoC
Sep 10, 2009 | 2003 Suzuki RM 125
Mower wont start.
I have a 927 series rider and just put a new battery,and spark plug.Has spark and still wont start. What else can I try?
May 03, 2009 | Ariens 34 In. Zoom Series Riding Mower
Toro lx425 rider mower wont start
If a small engine wont start its usually one of two problems, its not getting gas, or its not getting spark. easy way to find out if its getting a spark is to remove the plug, put it back back in the connector and just let it hang down while you try to start it. you should see a bright blue spark, if you dont try changing the spark plug. if its getting a spark come back on this site and i'll help you trouble shoot it.
Oct 05, 2008 | Garden
Garden Logo
89 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
