My computer will not turn on - Computers & Internet
  • lisamxny Jul 16, 2009
    hp pavilion zv6000
  • sabharish
    sabharish May 11, 2010
    May I know the model of your Laptop please?
  • 1,511 Answers
Sir please make sure that the power cords are properly tugged in and the main power supply is on
If done above and no result that please tell me about any error messages or beeps that your hear
Thnx and i hope this helps
Please rate this Solution
Posted on Jul 16, 2009
Error 210 Stuck key 69
Hello Scott,
Make sure that there are no objects placed on the keyboard, or
if you have one, the external keyboard. Turn off the computer,
and turn off all attached devices. Turn on the computer first;
then turn on the attached devices.
If an external keyboard is connected, do the following:
v Turn off the computer and disconnect the external keyboard;
then turn on the computer. Make sure that the built-in
keyboard operates correctly. If it does, have the external
keyboard serviced.
Make sure that the external keyboard is connected to the
correct connector.
Please feel free to ask me if you any further questions or concerns.
Also please rate me if you like my answer, that helps me alot.
Thanks.
Apr 19, 2012 | Lenovo ThinkPad R400 Notebook
I have a ASUS P8P67 LE motherboard, intel i5 - 2310 processor, kingston DDR3 RAM and ASUS ENGTX560 DC/2DI/1GD5 graphic card. When I turn on the PC i get one long and then three short beeps, and the...
> one long and three short BEEP
Something is wrong with some of your hardware.
Turn the computer off.
Disconnect the AC power.
Remove the graphic card.
Connect the AC power.
Turn the computer on, to see if the pattern of BEEP has changed.
Remove the RAM -- all of it.
Reinsert one stick of RAM.
Reinsert the graphic card.
Jul 16, 2011 | ASUS P8P67 LE LGA 1155 P67 SATA 6 Gbps and...
Compute turns on, lights light up, and fans move, but there are no beeps or bios showing up.
Computer turns on but no display. This issue is commonly caused by electrical static on the motherboard. Try doing a power drain.
If this computer is a laptop:
1. Turn the computer off by pressing the power button for a bout 5seconds.
2. Take the battery out of the computer.
3. Unplugged the ac adapter.
4. Press and hold the power button for about 30 seconds. (without any power source)
5. Put the battery back in and plug the ac adapter back into the computer.
6. Turn the computer back on.
If this computer is a desktop:
2. Unplug the power cable from the computer.
3. Press and hold the power button for about 30 seconds. (without any power source)
4. Plug the power cable back into the computer.
5. Turn the computer back on.
Thank you for choosing FixYa! have a good one!
Jun 02, 2011 | Computers & Internet
Can't print - computer keeps saying that printer is off
unplug from computer and turn off printer. turn computer off. turn computer on. turn on printer. plug printer back into computer in different USB slot. Computer should find it.
Mar 13, 2011 | HP Office Equipment & Supplies
Describe your sony vaio PCG-C1VRX/K Problem: O/S not found...cannot enable usb/cd use to fix/load new O/S
What do I do if the message "Operating system not found" appears when my computer starts, and why won't Windows start? ? Make sure the computer does not have a "non-bootable" floppy disk in the floppy disk drive (if applicable). ? If a non-bootable floppy disk is in the drive: 1. Remove the floppy disk. 2. Restart the computer and confirm that the Microsoft® Windows® operating system starts properly. ? If Windows still does not start, follow these steps to initialize the BIOS: 1. If there is a disk in the floppy disk drive, then remove it. 2. Turn off the computer. 3. Remove any peripheral devices connected to the computer. 4. Restart the computer. Page 1475. Press F2 when the VAIO logo appears. The BIOS Setup window appears. 6. Press the Right Arrow key to select the Exit menu. 7. Press the Down Arrow key to select Get Default Values. The message Load default values for all SETUP items appears. 8. Press Enter. The Setup Confirmation window appears. 9. Select Yes, and press Enter. 10. Select Exit (Save Changes), and press Enter. The Setup Confirmation window appears again. 11. Select Yes, and press Enter. The computer restarts. What do I do if my computer stops responding? Why can't I turn off my computer? It is best to turn off your computer using the Turn Off Computer option on the Microsoft® Windows® Start menu, located on the taskbar. Using other methods, including those listed below, may result in loss of unsaved data. ? Click Start on the Windows® taskbar, select Turn Off Computer, and then click Turn Off. ? If your computer does not turn off, press the Ctrl+Alt+Delete keys simultaneously. When the Windows Task Manager dialog box appears, click Turn Off from the Shut Down menu. ? If your computer still does not turn off, press and hold the power button or slide and hold the power switch until the computer turns off. ? If your computer stops responding while playing a CD or DVD, press the Ctrl+Alt+Delete keys simultaneously. You can turn off the computer from the Windows Task Manager. Pressing the Ctrl+Alt+Delete keys simultaneously or turning off the computer with the power button or switch may cause loss of data. ? Remove the AC adapter and battery.
Dec 13, 2010 | Sony VAIO PCGK45 PC Notebook
Mx75 monitor turns off when I awaken my computer
right click on desktop select properties(screen saver ) select monitor button in that select turn monitor never.(configure carefully)
Nov 24, 2009 | HP Pavilion MX75 17" CRT Monitor
My Dell Dimension 4600 will not turn on. Steady Amber Light
Disconnect the Power cable / A/c adapter/Battery from computer.
Disconnect External peripherials.
Hold down the power button on the computer for 10 seconds.
Reconnect the power cable or A/c adapter and battery or the computer
Try to turn on the computer
check for Led's on the computer
If still no display ,shut down the computer,disconnect power cable.
Open the computer tower,remove memory modules,reconnect power cable and turn on the computer.If you get a beeping sound after turning on you should be getting beeping sound suggesting the mother board is not bad.Turn on the computer and disconnect power cable from computer.
Reseat 1 memory at a time if you have 2 memory module or if single memory module reseat in different memory slot,swap memory module.
Reconnect the power cable and turn on the computer if it boots to desktop possible issue with 1 of the memory module.
Disconnect the harddrive ide cable from the harddrive .Turn on the computer.
If still unable to power on .Shutdown the computer and disconnect power cable.Remove video card,sound card ,modem card if any .Connect just the vga cable from monitor to the integrated video port.
Connect power cable and turn on the computer.
If computer turns on possible issue with one of PCI or PCI express card.
If still unable to power on.Disconnect the power connector pin from the motherboard and reconnect it back.Turn on the computer check power power led on motherboard,also check if the processor fan is spinning. if no go then issue with motherboard.
Sep 03, 2009 | Dell Dimension 4600 PC Desktop
WHEN I PRESS POWER BUTTON NOTHING HAPPENS
If still unable to power on.Disconnect the power connector pin from the motherboard and reconnect it back.Turn on the computer check power power led on motherboard,also check if the processor fan is spinning. if no go then issue with motherboard. GOOD Luck.!!
Aug 27, 2009 | Insignia D400a PC Desktop
No powering on
Resolution:
Aug 24, 2009 | Dell Computers & Internet
Mouse and keyboard not recognized on second computer
Solution for the mouse. I have 8 KVM's. Most of my computers work with the KVMs. On 1 inland KVM the logitect and Microsoft optical mice do not work on one computer (but work with the other computers). They both are USB. I hook them up with a USB to PS2 adapter. If I use a ps2 ball mouse connected to the KVM the mouse works. All the Mice work if I directly connect them. Since I do not want a ball mouse I got a Frisby optical PS2 mouse. It works with all the computers on the KVM's.
I do not have a solution for the Keyboard yet. 1 computer (ASUS MB) on my trendnet or belkin 4 postion KVM does not recognize the keyboard.
Aug 25, 2008 | D-Link DKVM 2K (DKVM-2K) 2-port KVM Switch
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
