Question about Dell 3010cn Laser Printer
I can't get the color cartridges removed to replace them. They all seem to be stuck and Yes, I have lifted the lever up to unlock the cartridges and the color needed to be changed is in front. It all seems to be OK but no one can get the cartridges to come out
    President:
  • 547 Answers
Mine is pretty stubborn about letting go of the cartridges too. The best answer I can say is DON'T FORCE IT!
For mine, after turning the lever to unlock, I push the whole cartridge to the left slightly, then pull on the right (side with the lever)
If it doesn't let go, try turning the lever to lock it, then unlock it and try again.
I honestly don't know how I get it to release the cartridges, but it's never let one go on my first try, and it's always (eventually) let them go without forcing anything.
Posted on Jul 16, 2009
Replacing ink cartridge
Hello!
1. Start with your printer turn on.
2. Lift the ADF scanning unit together with the flatbed scanner glass unit.
3. Wait for the cartridge carriage unit to position itself in the middle.
4. Once ink cartridge carrier in the middle, lift up the carrier lock lever.
5. Remove the black or colored cartridge and replace it, once lever is unlock.
6. Once replaced, return back the lock lever, then return back the top cover lid.
Aug 28, 2011 | Canon PIXMA MX310 All-In-One Printer
How to change the ink cartridge in a Canon iP1900 printer please
1•Protect your desk, printer stand or work surface by placing an old newspaper in front of or next to the printer. The newspaper will provide you with a place to work without getting ink anywhere you don't want it. It seems as though no matter how careful or neat you are, a little bit of ink always manages to escape when replacing an ink cartridge.
•2
Prepare the new ink cartridge for installation. Remove the replacement cartridge for your Canon printer from all of its packaging. You may need scissors to remove the heavy wrapper. Leave the protective orange cap or tape in place for now. Set the new cartridge aside on the newspaper.
•3
Remove the old ink cartridge from the Canon printer. With the printer on, open the front door or panel of the printer. Wait a second or two and the ink cartridge holder should move to the opening where it is accessible. If it does not move, shut the door, turn the printer off for a moment, turn it back on and try again. Lift the small lever that secures the ink cartridges within their holder. On most Canon printers, it is colored green and located on the right side of the ink cartridge holder. Gently lift the old ink cartridge out of the printer.
•4
Place the new ink cartridge in the printer. Remove the plastic cap or tape protecting the ink cartridge, being careful not to touch the black and gold "sensor" area of the cartridge. Gently but firmly push the new cartridge into the empty slot left where you removed the old ink cartridge. The label should be facing outward. You should feel the cartridge pop into place. Then push the lever back down that you lifted in Step 3. Close the printer door. Use paper towel or wet wipes to clean any ink from your hands.
Aug 18, 2010 | Canon Office Equipment & Supplies
How do I change the toner?
The Fax-2480c does not use toner cartridges.
This is an inkjet and so uses ink cartridges.
There are 4 cartridges, black, yellow, cyan (blue) and magenta (red). If any of these cartridges are empty, you need replace them.
This machine takes LC-51 cartridges.
You're probably out of warranty so jsut get refills... it's cheaper
Mar 25, 2010 | Brother IntelliFax-2480C Fax
I just need to know how to put the ink cartriges in correctly?
Lift the cover. Lift (unlock) the lock lever, remove the cartridges. Remove the seal from the new cartridge, insert in the vacant space. Lodk the lock lever. Close the cover.
Mar 06, 2010 | HP Officejet 6310 All-In-One InkJet...
I have a Brother MFC-620CN just changed the ink cartridges but the printer still says ink is empty and won't print
Hi
I have looked it up for you and what I found is.
Title:
I replaced my ink cartridge, but the LCD is still displaying "Ink Empty". What can I do?
Description: This is typically caused by an incorrect selection made during the LCD prompting after a cartridge is replaced. When an ink cartridge(s) is replaced, the LCD will ask, "Have you removed Blck? 1 Yes 2 No". This question will be asked for ALL 4 colors in sequence, regardless if the color was replaced. If "1 Yes" is NOT selected for the color(s) that was replaced, the LCD will return to "Ink Empty". Do the following to clear the message:
  1. Pull the scanner cover release lever located below the control panel and lift the top cover.
  1. After 15 seconds, re-close the top cover and then re-close the control panel cover.
  2. The LCD will then display Have you removed Blck? 1 Yes 2 No.
    The LCD will display this question for ALL 4 colors (not just the ones replaced). BE SURE to select 1 YES for each ink cartridge that was replaced.
    If 1 Yes is selected, the LCD will then display Change to new (color)? 1 Yes 2 No. Again, BE SURE to select 1 YES.
Note "Change to new (color)?" will only appear if 1 Yes is selected for "Have you removed (color)?" If 2 NO is selected for the "removed" question, the LCD will then move on to the question for the next color.
Feb 02, 2010 | Brother MFC-620CN All-In-One InkJet...
The printer does not recognize a new cartridge when I install it. Also, I think the old ink cartridge was still good.
Title:
I replaced my ink cartridge, but the LCD is still displaying "Ink Empty". What can I do? Description: This is typically caused by an incorrect selection made during the LCD prompting after a cartridge is replaced. When an ink cartridge(s) is replaced, the LCD will ask, "Have you removed Blck? 1 Yes 2 No". This question will be asked for ALL 4 colors in sequence, regardless if the color was replaced. If "1 Yes" is NOT selected for the color(s) that was replaced, the LCD will return to "Ink Empty". Do the following to clear the message:
Jan 27, 2010 | HP Photosmart 3310 Printer
Replacing a cartridge
Title:
Oct 11, 2009 | HP Photosmart 3310 Printer
Cannot remove old cartridge
steps for removing and replacing the toner cartridges:
-before removing the toner cartridges, disconnect the A/C power cable from the back of the system & remove the printer's top cover
-rotate the securing lever upward to unlock the toner cartridge
-lift the cartridge out of the chassis, each toner housing and cartridge is color-coded and labeled for easy identification of toner cartridge color locations
-just reverse the previous steps to replace the toner cartridges
Jul 09, 2009 | Dell 5110cn Laser Printer
Replace belt CG
Set Belt CG The OPC belt cartridge needs replacement.
Replacing the Optical Photoconductor (OPC)
Belt Cartridge
Replace the OPC belt cartridge at least once every 12 months, or when
the control panel display indicates that replacement is necessary. The life
of the OPC belt cartridge for the T8106 is about 60,000 images (15,000
color pages), at a 5% toner coverage rate on letter-size paper.
1. Turn the power switch off.
2. Unlock the lever to open the front
cover. This releases the pressure on the
toner cartridges.
3. Unlock the lever to open the top cover
fully.
4. Pull the green OPC belt cartridge lock
levers up until they unlock.
5. Pull the used OPC belt cartridge
upward and out of the printer carefully
to avoid spilling toner.
6. Discard the used OPC belt cartridge
Caution! Do not touch or wipe off any powder that is on the OPC belt, nor expose
the OPC belt to light.
7. Remove the two shipping pins from the
new OPC belt cartridge.
8. Remove the protective sheet that covers
the photosensitive belt.
9. Slide the new OPC belt cartridge downward
into both green lock-lever guides
and into the printer carefully.
10. Push the green OPC belt cartridge lock
levers down until they lock.
11. Close the top and front covers carefully
until they both lock.
May 28, 2009 | Tally T8106 Laser Printer
Replacing Print Cartridge
Where the gray and blue areas of the printer meet there is a place you can lift up to reach the ink cartridges. The left side is for the color, which is larger and the right side is for the black. There is a lever on top of each. Lift up and then pull the cartridge out. Remove the protective strip on the new cartridge and place in the same way you just removed the old cartridge. Once in, push down on the lever on top. Close the computer. Follow any other instructions indicated on the readout on printer (i.e. alligning).
Don't be afraid of pulling up (at a slight angle) on the cartridges as you remove them, they do fit snuggly. The levers on top fit firmly to make sure the cartridges are seated properly. They won't go down if the cartridge is not in place.
Aug 29, 2008 | HP PSC 750 All-In-One InkJet Printer
Dell 3010cn Laser Printer Logo
102 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
