Question about Kenmore Refrigerators
I have a 3 year old kenmore fridge withfreezer on the bottom and water in the door. The water only trickles out even ater replacing the filter. What's wrong?
    Champion:
  • 363 Answers
It sounds like the water tap from the source is clogged, or the vinyl tubing running from the water source is crimped somewhere. I would check the tap first to make sure the valve is not clogged. You close the valve clockwise ,then remove the tubing. Have a bucket handy. Open the valve counterclockwise a little at a time until water started to drip. Place the bucket under the valve to catch the water. Open the valve a little more and let the water go into the bucket. Do this until you are satisfied that the tap valve is not clogged. If this does not solve the problem then check the tubing to see if you have crimps in the line. Then close the tap valve clockwise down tight. remove the tubing from behind the frig and if you have enough slack, take that end to the tap valve and the bucket, place the frig end of the tubing in the bucket, open the tap valve until you are satisfied the flow is nomal., close the tap avel and hookup the frig end. Open the tap valve an the test the water dispenser for flow.
Posted on Jul 16, 2009
Water does not flow
Sounds like air in the line.....the filter may be cracked/damaged, or not quite seated...?
since you've tried 2 new ones....I'm gonna bet they are not quite the correct ones for your fridge.
Sep 07, 2012 | GE GSHF5KGXBB (254 cu ft) Side by Side...
Ge side by s
found norcold #160107210--new #160107200-----on E-Bay ,under RV Thermostate-----thru seller---- eastcoastrv---Lexington,South Carolina
Oct 26, 2009 | GE Refrigerators
Water comes out of the water dispenser in a trickle. Side by side model, icemaker in the door. Water filter was just replaced; water was only coming out in a trickle before replacement. Model 106.57033602
Sounds like the solinoid valve in the back of the fridge is not closing all the way.usually located at the the bottem right. replace the valve. It will have a 1/4 inch plastic hose line attached to it. shut off the water source first, then remove the valve, be sure to write down the model and serial number before you go to a appliance shop.
Jul 03, 2009 | Kenmore Refrigerators
Kenmore elite refrigerator water dispensor not working
If you just got this unit, did you purchase it new? Or if it's uner a year old then you should call sera for service under the war. Also, when you first start the unit water has to go through the water tank and it takes 3 - 5 mins before the water starts to work when first hooked up, then should be ok after that. There are several things that can cause the problem. Could have a kinked line in the ref, a bad water valve or even a frozen water tank. Also, did the water ever work since you had it?
Nov 23, 2008 | Kenmore 73503 Stainless Steel Bottom...
Kenmore Fridge - Bad Testing Water
Your refrigerator definitely has a water filter. If you have gone 5 years without replacing the filter, you and your family have probably been drinking contaminated water, for some time. Water filters should be replaced every three to six months. On some refrigerators, and in cases of higher water consumption, the filter must be changed every 60 days. Sears sells replacement filter cartridges for Kenmore refrigerators.
The water filter on your refrigerator is located at the front base of the unit, in the grille, below the freezer door. There, you will see a round cap. Turn the cap counter-clockwise, until the handle is vertical.Then, pull it out of the grille. The filter cartridge is attached to the cap. After removing the cap and filter, slide the cap off from the existing filter cartridge. Slide the cap on to a new cartridge, and re-insert with the cap handle in a vertical position. Push it in, firmly. Then, turn the cap clockwise, until the cap handle is horizontal.
Oct 24, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
WATER DISPENSER,
GSH25JSTASS -- I have a one year old ref..Same problem..Ice comes fine, no water. Changed filter..defrosted Freezer compartment. Kept the light ON for a couple of days, .used compressed air to check water tube between water disp to bottom of the freezer. Not frozen...
What could be wrong with this SMART water filter from GE!
Aug 02, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Water filter not working
Freezer too cold, tube in door frozen. This happens to my freezer when my children turn the freezer temp too low.
Mar 20, 2007 | Kenmore 54362 / 54364 / 54369 Side by Side...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
