Question about Polaroid FLM-323B Television
I have no volume
My tv is on, the mute button is not on, but there is no volume. Could I have pressed something inadvertently? Help
  • 616 Answers
Try using the front panel controls on your tv , if this doesn't work then you might need to go in the menus and "turn" the speakers on. Also check to see if the tv has an on-off switch in the back. Good luck! Julio at Millenium tv (702) 736-1091. milleniumtvsvc@gmail.com
Posted on Jul 19, 2009
How do you un-mute tv settings
Try pressing the mute (speaker symbol with diagnol line) or just press up/down volume button
Sep 08, 2014 | Televison & Video
No sound. changed channels and adjusted volume settings but not joy. video works fine.
If you are on a satellite system, well they have a recurring problem that cuts the sound off. You may only need to unplug the satellite receiver for 30 seconds. I have seen this happen so many times. Also be sure you have not inadvertly pressed the mute button. And be sure the speakers are on in the sound menu. The worst and last problem is a bad audio circuit failure in the TV.
May 28, 2011 | Toshiba 32AFX61 32" TV
Can't hear caller but they can hear us.
press "MUTE" button. I suspect someone inadvertently pressed it causing it to shut off volume to caller.
Mar 07, 2011 | Uniden Cordless Phone
29 inch RCA Entertainment Series TV I was watching it when picked up remote and it muted the sound and I can't get it to unlock the mute in the menu can anyone help me figure this one out???
Hi try pressing either the mute button again or simply increase the volume to unmute the TV. most TVs respond to this procedure. Pressing the volume buttons on the tv will have the same effect if the remote has failed
Aug 13, 2010 | Televison & Video
TV/media/volume/buttons
go to control panel and then check the option
sound and audio devices and check on mute
may be is the mute option
Aug 18, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
People on other end of connection cannot hear me, although I can
Check the volume...
Ringer volume
3 levels (high/low/off) are available.
Make sure the handset is idle.
Press {FUNCTION}.
2 Scroll to “Ringer volume” by pressing {down} or {up} repeatedly, and press {right arrow}.
3 Press {down} or {up} repeatedly to select the desired volume.
4 Press {right arrow}.
This is the handset volume
To turn the ringer OFF:
Press {down} repeatedly until “Ringer off” is displayed in step 3.
Regards
Richard.
Mar 28, 2009 | Panasonic KX-FPG376 Plain Paper Thermal...
TX SR705 Receiver not respomding to Remote
for your mute button:
check your setup:
*press setup
*go to Miscellaneous
*go to volume setup
*go to muting level
*make sure that the muting level is on minimum (press the left arrow or the left preset button)
*if it shows a negative infinite sign (its measured in decibels) its ok.
you can now mute it without the loud noise.
Abaout Remote:
Please make sure that the remote ID is set to 1. this would be on the setup menu of the receiver. The remote ID on the receiver should be the same as your remote. Please refer to page 94 and 98 of your owners manual. it would give you the exact procedure in how to set it.
Jan 11, 2009 | Onkyo TX-SR705 Receiver
Toshiba Regza 32C3000A tv sound keeps droping out, the mute button when pressed on and then off brings it back on. seems as if the tv is auto muting itself?
Could be a contact piece of the MUTE button from your remote that is causing it.
Go out and Big Lots or Radio Shack to get a cheap universal remote control(big lots would be between $5-$10) Pick up the code for it,and when the tv happens again,your the OLD remote MUTE button to turn it back on and then put away this remote control and use the new universal remote control.
However,if the problem is coming from the manual MUTE button on the TV,you need a repair tech, to fix it!
solutiondoct
Nov 10, 2008 | Toshiba Televison & Video
Making my SIR-T451 remote work with my Zenith TV.
Push the Set button and enter the following codes and enter one of theese codes: 018, 020, 193. If one doesn't work try the next one. You have to push set each time you enter a new code.
Jan 11, 2008 | Samsung SIR-T451 DirecTV DTV Receiver
Polaroid FLM-323B Television Logo
153 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
