Question about Palm Tungsten E2 Handheld
I purchased a used Palm it works fine but I have no sound for calendar alerts. I can't even play the alerts to see which one I want. Can this be fixed.
  • halupnm Jul 17, 2009
    Headphones do work. I removed the back and cleaned the contacts between the PDA and external speaker and that did not help. Have you got anymore suggestions. Thanks for your help so far.
  • 547 Answers
If you plug in headphones, do you have sound in them?
If so, then the problem is either the built-in speaker or the headphone jack.
If it's the speaker, then you're in for a pretty involved fix involving soldering little tiny wires. Do-able, but not for someone just learning how to use a soldering iron.
If it's the jack, then you might get lucky and fix it by inserting and then removing your headphone's plug.
I've had this style of jack get a bit of dust in it before, and basically think headphones are plugged in even when they're not.
Let me know if you've got sound in headphones, and we can take it from there.
Posted on Jul 16, 2009
Calendar alert does not ring when event is planned
Good morning to you
Ijust know onething about setting alarms and that is. To do it in the right order. When I set mine (nokia)firstly I find software in software there is a clock. New alert- alerts- world clock
I click on new alert then on the screen fill in what is asked.
I can also do this trough the calender- check if this works for you..
also check if alarm sound is on if not put it on.
all the best
Kolbrun
Feb 24, 2012 | Motorola Mobility Motorazr2 V9x Cell Phone
Putting contacts on the SIM card
When I migrated from my Palm Centro (best smartphone ever) to my current BlackBerry, I did the following: 1) Export Palm contacts from the Palm Desktop software to CSV (comma separated values or tab-delimited text) format. 2) Import the CSV file to your Google Contacts account. 3) Wirelessly sync Google Contacts to your new phone using the free Google Sync app (link below). 4) Verify data was transferred appropriately.
Google Sync works with iPhones: http://www.google.com/mobile/sync/
You should be able to follow the same process for your Palm Calendar by exporting your Palm Calendar from the Palm Desktop software to a file (save the exported file to your desktop, or an easy to find location on your computer), then import the Calendar file into a NEW Google Calendar, not your primary calendar (in case there's conflicts or problems, you can delete the secondary Google calendar without losing your primary Google calendar items). Google Sync should allow you to choose more than one Google Calendar to sync with your iPhone.
Apr 25, 2010 | Palm AT&T C/PHONE PALM CENTRO S64801
Transfer calendar info from Tungsten/E Palm to iphone 3GS
The best way is to transfer the Calendar and Contacts to Outlook. The iPhone can then be synced with Outlook.
Unfortunately, tasks and memos do not transfer. You will need to find other 3rd party apps that are supported on the iPhone and transfer your data to them.
Two examples are:
1. Evernote - This is good for memo. You can export your memos and then import them into Evernote. unfortunately, when I did this, it was a bit tricky. I even had to write a little PERL script to create the format that it wanted.
2. RemembertheMilk - this is a todo application
Jan 03, 2010 | Eforcity Apple iPhone 3GS 16GB / 32GB...
Notification alert for calendar items on Samsung i780
Hi there!
Try to click the bell icon when you set your alarm and see if you have checked the box for "play sound".
Also, verify if your volume is up and not in "Off" mode.
Also, go to Settings, click Sounds and Notifications. Verify if you were able to check the "Enable sounds for programs" box and make sure the notifications box is checked.
And on the notifications tab select "Reminders" from the drop down menu for "Event" and ensure that "Play sound" and "repeat" are checked.
Hope this will solve your problem!
Mar 11, 2009 | Samsung SGH i780 - Microsoft Windows...
How do I fix my Outlook Calendar synchronization problem?
Palm tech fixed my problem. It turned out some items in Outlook Calendar were corrupted, thus preventing a synch with LifeDrive. The fix is to export the Calendar items and import them. This process fixes corruption. After doing that I successfully synchronized Calendar with LifeDrive. More specifically. I moved Calendar items to a different folder, thus emptying the main Calendar folder. I exported the Calendar items in the new folder to a CSV (Windows) file. Then, I imported that CSV (Windows) file into the main Calendar folder. Finally,I did a synch and all worked perfectly.
Sep 13, 2005 | Palm LifeDrive Handheld
Calendar Not Syncing
OK. Hope this helps you because it fixed my problem. Go into palm desktop. Go to hot sync, click on custom Go to Calendar (Outlook) and double click on that. At this point click on settings. Under conflict resolution choose "outlook wins". Then go out and check syncronize files and set as default. Click done and this should resolve the issue. Reply if this is confusing.
Sep 12, 2005 | Palm Treo 650 Handheld
Treo 650 won't sync with Outlook calender on my Windows XP Pro desktop?
I was tring all the possible ways to resolve the issue. At last got a solution for my problem. Hope this will work for you all. Download the "OutlookConduitUpdater.zip" and install. This will resolve the calender "do nothing" while sync.
My Outlook Calendar is not synching with the Datebook on my Tungsten C, why?
Go into your desktop software and make sure your outlook is programmed to transfer back and forth.
Sep 07, 2005 | Mapopolis GPS for Palm Tungsten T, C &...
Palm Tungsten E2 Handheld Logo
61 people viewed this question
Top Palm Computers & Internet Experts
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
