Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
My clock and date are set correctly, i have the pump set to turn on at 7 am and turn off at 8 pm all days, it is turning off at approx 11:00am
  • 128 Answers
Check for other programming. You might have a second program shutting off at 11
Posted on Aug 23, 2009
Date and time arror
When you turn your machine on for the first time, the display
prompts you to enter the current date and time. After entering,
it will not appear anymore.
NOTE: When turning on the machine after turning it off for a
long time, you need to reset date and time.
1 Press Menu until "Machine Setup" appears on the top line
of the display.
2 Press the scroll button ( or ) to display "Date & Time"
on the bottom line and press Enter.
3 Enter the correct time and date using the number keypad.
Month = 01 ~ 12
Day = 01 ~ 31
Year = requires four digits
Hour = 01 ~ 12 (12-hour mode)
00 ~ 23 (24-hour mode)
Minute = 00 ~ 59
NOTE: The date format may differ from country to country.
You can also use the scroll button ( or ) to move the
cursor under the digit you want to correct and enter a new
number.
4 To select "AM" or "PM" for 12-hour format, press the or
button or any number button.
When the cursor is not under the AM or PM indicator,
pressing the or button immediately moves the
cursor to the indicator.
You can change the clock mode to 24-hour format (e.g.
01:00 PM as 13:00). For details, see "Changing the Clock
Mode" on page 2.10.
5 Press Enter when the time and date on the display is
correct.
6 To return to Standby mode, press Stop/Clear.
Changing the Clock Mode
You can set your machine to display the current time using
either a 12-hour or 24-hour format.
of the display.
2 Press the scroll button ( or ) until you see "Clock Mode"
The clock mode currently set for the machine displays.
3 Press the scroll button ( or ) to select the other mode
and then press Enter to save the selection.
4 To return to Standby mode, press Stop/Clear.
May 14, 2014 | Samsung SCX 4521F All-In-One Laser Printer
How do i set the Barbie Glamtastic alarm clock radio
Barbie Glamtastic Alarm Clock Radio 11765268
There are four (4) buttons on the back:
  • Mode
  • Set
  • Scan
  • Reset
Everything regarding setting dates and times is done starting with the Mode button, and using the Set button to adjust various settings.
Set Year
  1. Press Mode until the date appears.
  2. Press Set. The year will begin to flash.
  3. Press Mode until the correct year is reached.
  4. Press Set.
Set Date
  1. Press Mode until a date appears in the form of MM-DD.
  2. Press Set. The year may flash first. Press Set again. The month (MM format) will begin to flash.
  3. Press Mode until the correct month is reached.
  4. Press Set. The day (DD format) will begin to flash.
  5. Press Mode until the correct day is reached.
  6. Press Set.
Set Time
  1. Press Mode until the time displays.
  2. Press Set. The hour will begin to flash.
  3. Press Mode until the correct hour is reached. Keep in mind the AM/PM indicator in the far left of the screen. Make sure that the hour to be selected is with the correct AM/PM indicator.
  4. Press Set. The minutes will begin to flash.
  5. Press Mode until the correct minute is reached.
  6. Press Set button.
Set Alarm
  1. Press Mode until the the Alarm screen displays. The Alarm screen has an AL in the far right of the screen.
  2. Follow steps 2-6 above under Set Time (these same steps are just being done on the Alarm screen).
Turning Alarm On and Off
The left side of the radio has an On/Off dial (for the radio) at the top, and a slide selector button (for turning the alarm on and off) at the bottom.
  • Sliding the selector to the far left will result in Barbie's voice as the alarm.
  • Sliding the selector to the far right will result in a piercing noise as the alarm.
  • Sliding the selector to the middle slot will result in the muting of the alarm.
There are graphics on the left side of the clock that denote each result above.
Mar 28, 2014 | Barbie Glamtastic Alarm Clock Radio...
How to set time on the TIMEX t309t
Please follow these instructions:
Setting the Clock
1. Press and hold the 5 Time Set Button until the display begins flashing.
2. Press the 10 Reverse or 14 Forward Button to set the time. Holding a button for a few seconds will advance or reverse the time rapidly. Set the correct AM/PM time, shown by the PM Indicator on the display.
3. After setting the time, press the 15 Enter Button or wait about ten seconds for the unit to beep twice and the display to return to the normal mode.
Setting the Calendar
1. It is important to set the correct date in order to use the 7-5-2 Alarm settings. Press and hold the 6 Date Set/7-5-2 Button until the display flashes and the year replaces the month/day at the bottom of the display.
2. Press the 10 Reverse or 14 Forward Button to set the correct year, and then press the 15 Enter Button. The unit will beep and the display will show the month and day. Again, press the 10 Reverse or 14 Forward Button to set the current date.
3. After setting the date, press the 15 Enter Button or wait ten seconds to return to the normal display mode.
I hope I could help.
Thanks
Nov 26, 2011 | Timex T309TT Clock Radio
Find manual for woods 59028 programmable timer switch
1) Set current time:
Press reset button to clear all programs , display should flash 12:00 AM Monday
Press and hold CLOCK button.
Press Hour, minute and day buttons until current hour minute and day display.
Release Clock button.
Next step is to program the timer
Example shows how to turn on at 5PM each day and turn off at 11 PM each day.
2) Programming review: Each program requires ON time to be set, and then OFF time to be set For example you set Program1 ON 5:00PM for ALL days. And then you set Program1 OFF 11PM for ALL days. Minimum on-off set time is 1 minute.
3) Programming steps: Press PROG button until Timer 1 ON appears on display Use Hour button to set 5 PM Use MIN button to set :00 Default selects ALL days (If you want other days, press DAY button until display shows correct block of days) Press PROG button again to save Program1 ON 4) Now for Program1 OFF 5) To set Program1 Off Press PROG button until Timer 1 OFF shows in display. Use Hour button to set 11 PM Use MIN button to set :00 Default selects ALL days (If you want other days, press DAY button until display shows correct block of days) Press PROG button again to save Program1 OFF 6) Program 1ON and Program1 OFF have been set ... so press the CLOCK button to return to current time. If you want to set another program, press PROG button until Timer 2 ON displays 7) After setting programs, press Clock button so current time shows. 8) The manual shows one more thing ... if you program the timer during the hours 5-11pm, and the timer should be ON during those hours, you have to 'tell' the timer to turn ON by pressing the manual override ... after that the timer will operate normally.
Nov 21, 2011 | Woods 59028 Programmable Timer Switch...
How to set time and date
Hi janssen4,
You can change the time and day of your Timex watch by following the steps below.
1. With the time and date showing, press the top left button.
2. Press the right top button (this sets seconds).
3. Press the bottom left button. This flashes the hour; press the top right button until you have the correct hour (there is no symbol for am, pm will show if pm).
4. Press the bottom left button, minutes flash. Press the top right button until correct minutes.
5. Press the bottom left button, month flashes. Press the top right button until correct.
6. Press bottom left button, date flashes. Press the top right button until correct.
7. Press bottom left button, day flashes. Press right top button until correct.
8. Press bottom left button, time format flashes (can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished).
To turn off the chime and alarm: Press bottom left until in the alarm screen. Then press the top right button repeatedly until the CHIME or CH symbol is gone and/or ALARM or ALM to disappear, then press the bottom left button to go back to main time.
Hope it helps.
Thank you for using FixYa.
Jun 02, 2011 | Timex 1440 Nylon watch
Hi aremoresun,
You can set the time and date your Timex watch by following the steps below.
Hope it helps.
Mar 23, 2011 | Timex 1440 Nylon watch
Clock is set properly. I want to turn on outdoor lights at 5PM everyday. In addition I want to turn off the lights each night at 11PM. Problem - When I go thru the process of turning on the lights it...
I answer questions for free.
I know timers and electrical devices, and have tested most of the brands.
You posted under the Woods 7-day timer 59018 or 59028.
Here is the manual:
http://waterheatertimer.org/pdf/Woods-59018-59028.pdf
There are several programmable timers today that look like Woods, and each brand has different programming.
If you do not have Woods, add a comment and I will walk through programming your brand
1) You have the clock set correctly which implies the wiring is correct. Good job!
If you need more assistance, add a comment.
If instructions help, give it a 4-thumb
Nov 10, 2010 | Woods InWall 7 Day Digital Programmable...
SET THE TIME
: 1. With the time and date showing, press the top left button. 2.Press the right top button (this sets seconds) 3.Press the bottom left button. This flashes the hour; press the top right button until you have the correct hour (there is no symbol for am, pm will show if pm). 4.Press the bottom left button, minutes flash. Press the top right button until correct minutes. 5.Press the bottom left button, month flashes. Press the top right button til correct. 6. Press bottom left button, date flashes. Press the top right button til correct. 7. Press bottom left button, day flashes. Press right top button til correct. 8. Press bottom left button, time format flashes (can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished). To turn off the chime and alarm, press the top right button repeatedly until the CHIME or CH symbol is gone, then press the left top button. Repeat for alarm but watch for the bell icon or ALARM or ALM to disappear, then press the top left button.
Feb 16, 2008 | Columbia All Sport watch
Timex Indiglo Acqua watch
For analog Acqua watches adjust date when month has less than 31 days:
3-Position Crown: Pull crown to "MIDDLE" position and turn CLOCKWISE or
COUNTERCLOCKWISE until correct date appears.
2-Position Crown: Pull crown to "OUT" position and turn CLOCKWISE until date
changes (approx.1:00 a.m.). Then turn COUNTERCLOCKWISE to 7:30 p.m. Repeat until correct date appears.
Dec 05, 2007 | Watches
Date and time
To set your clock and calendar do this:
1. press shift
2. press set
3. enter 2 digits for month 01-12
4. enter 2 digits for day 01-31
5. enter day of week ( 1-7) 1 is for sunday, 2 Mon, ect
6.enter 2 digits for hour from 1-12
7. enter 2 digits for minute from 00-59
8. enter AM or PM (* for AM) (# for PM)
9. a short ring will be heard to signal you completed it
successfully
Sep 11, 2007 | IBM Corded Phone IBM412CID
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
80 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
