Question about Maytag Dryers
Drier mod MDE16PDAYW two driers want to vent 28ft. header to a common vent outside. What size pipe do I need to run ?
  • gsoper Jul 16, 2009
    from drier outlet 10 rise including 2 ells then 2 more ells to outside. If I step up to 6 in. will it work better?
    maytag MDE16PDAYW two driers venting must go up 10ft. with two ells header together run 18ft. with two more ells to outside. What size pipe should be run?
    President:
  • 1,714 Answers
A 6" pipe will work just fine.
Posted on Jul 16, 2009
  • 441 Answers
You only need to run 4" round for that, with that length of a run you are pushing what the dryers can handel but it should not be a problem
  • John Riley Jul 16, 2009
    No, I would keep them at a 4". Going up to 6" would make the dryers need to push harder to vent & open the dampers on the outside
Installation diagram
240 volt electric cord, and a flexible usually 4 inch, exhaust hose.
Install cord to drier.
Install flexible hose to driver using the clamps provided.
Install plug into the 50amp drier outlet.
Install the other end of the exhaust hose to the vent going outside.
Carefully move the drier back into position almost against the wall without crushing the vent hose..
May 07, 2014 | Dryers
Kennmore 70 series drier mod 110.6675201 I have to run it throw 2 cycles to dry the clothes
venting issue #3:
http://www.applianceaid.com/general.html#vent
Feb 16, 2011 | Dryers
Dryer takes hours to dry a load. I must run it through several cycles. Not much air coming out of outside vent so repairman suggested it be cleaned out. My husband completely removed it and found no...
My only thought is to look at the back of the drier. Check the hose coming out the back to the out side vent, and then run the drier with out the hose for a few moments. See if you have air moving then, if you have no air moving with out the hose attached. Your driers fan blades are ether clogged with lint or they have broken off some how.
Aug 22, 2010 | Electrolux EIGD55H Dryer
Dryer taking to long to dry cloths, all vents are clear
sometimes a element that heats the dryer breaks giving it only power till were it broke /then will cause no or very little heat these run about 30-34$ depending on what type of brand of dryer you have
Apr 10, 2010 | Maytag PYE2300AY Electric Dryer
UNIT RUNS AN EXCESSIVE AMOUNT OF TIME AND AIR IS COOL NOT COLD COMING OUT OF VENTS CARRIER 58DLA / 58DLX CENTRAL AC FAN AND COMPRESSOR ARE OPERATING BLOWER IS WORKING UNIT IS TURNED ON TO AC TEMP SET AT 76...
DOES THE HOUSE FEEL DRIER IF IT IS 80 OUTSIDE WITH ALOT OF HUMIDITY THE UNIT WILL RUN FOR A LONG TIME TO REMOVE THE MOISTURE(HUMIDITY) OUT OF THE HOUSE BEFORE TEMP DROPS DRAMATICALLY IS THERE WATER COMING OUT OF THE DRAIN PIPE OUTSIDE
May 03, 2009 | Carrier Heating & Cooling
My drier is a Maytag, it is not heating up the way it should be.
There is a chamber that the air blows down before hitting the vent pipe. It may need to be cleaned. But you want to make sure when you push your dryer back, that the vent doesn't kink. good luck. Overall you drier works, your just having a venting issue.
Apr 04, 2009 | Maytag Neptune MDG5500AW Gas Dryer
GE profile dryer not drying completley
Check that the vent outside (especially in northern climates this time of the year). Then check the hose that goes from the drier to the outside vent. Finally, check the drier itself, that there is no obstructions getting to the hose. Check the lint trap. Is it full or is it installed properly? If all this checks out, then try replacing the heating element. These are usually inexpensive, and fairly easy to replace. The manual for the drier should have diagrams on how to access it.
Jan 12, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
Whirlpool Duet Dryer getting very hot, tripping breaker
what size is your breaker how many amps it should say on breaker are you cleaning the lint screen with it on top if the drier is getting too hot there is a device in it that's called a thermal limiter that would blow before the breaker would trip what kind or you in a house or apt. now on high heat can you hold your hand on the side of the drier.or cant touch it look at the vent under your house and tell me 1is it hanging down under the house then coming up to the hood 2whats its diameter3whats it made of we will go from there ok.there are three thermostats in that drier the first one runs at about 150 160 max second is a safety in case the first one fails it cycles at about 250 third is a safety if the drier exceeds 300 it will shut the heater down and wont rest it has to be replaced
Jan 10, 2008 | Dryers
Kenmore dryer
this promblem is about always a vent promblem or not cleaning the drier filter if your using the plastic vent check if its mashed behind the drier you must have 4inch of vent all the way throuch if its mashed or folded over its cut down to 2inches if it hangs under your house then comes up to the outside vent housing it can fill with water if the outside hood door isnt oping that will do it too its in your vent some where what i tell cust to do is run 4inch pvc from out side hood up through floor then run short metel vent to pvg attach with clamp to confirm vent restriction take vent loose for one load and see if it dries in right amount of time
Dec 28, 2007 | Dryers
MINE BLINKS HE
you got a vent restriction look behind your drier with a flash light and see if vents too long or mashed go outside when drying clothes see how much air flows comming out best way to do vent is 4in pvc drain pipe from hood out side to floor then 90dgree elbow up through floor short peice of pipe then foil drier vent from back to pipe with clamps your air flows blocked backing heat up in drier
Nov 12, 2007 | LG DLE2532W Electric Dryer
Dryers Logo
48 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
