Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
My Whirlpool Ultimate Care II goes thru the wash cycle but does not spin or drain. What may be the problem? The washer fills with water, however, after the wash cycle, it stops, will not drein the water or spin.
  • 5,911 Answers
Check your lid switch to make sure it is functioning. This is a common symptom. If your washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle or drain, the problem is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
If you have any questions about this repair, or if you need additional assistance, please let me know. I hope this helps you.
Posted on Jul 16, 2009
Whirlpool Ultimate Care II LSQ8543JQ0, the washer fills will water on all cycles but does not do a wash, drain or spin.
This is usually caused by the lid switch. These are inexpensive and easy to replace. There are videos at www.appliancehelponline.com/servicemanual.html that will walk you thru testing and replacing this part. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
May 17, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Won't spin, won't drain
Hi...
If your washer does not drain, you need to check this:
  • Inspect the drain hose for kinks
  • Test the timer control
  • Test the lid switch (some models)
  • Inspect the water pump
  • Inspect the drive belt (belt drive only)
  • Inspect the motor coupler
If it does not spin check also this:
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
Good luck !!!
Regards
PCmania
Jul 14, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Stops in the middle of wash cycle
Hi!
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine does go thru spin cycle or drain water.
If the washer does not spin, take off the rubber bumbers inculding the little washers attached, inside the lid. It lowers the lid, which takes care of the problem. I had the same problem. Not anymore! Trust me, if nothing is wrong with any other part of the washer, this will work.
Apr 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Excess water in clothes after spin cycle
Unblock the outflow pipe from the machine that goes into the sump under the sink. (have a pot ready for water overflow) This will help drain the water. If the spin cycle is making a screetching sort of noise then it is possible that the carbon brushes will need changing. This affects the spinning if the brushes are worn.
Nov 05, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Jul 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer LSQ9549LN0 problem
you have a problem in the transmission of the washer
May 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
191 people viewed this question
Dan Webster
Dan Webster
Sal De
